    Need help creating CSS for newsfeed
    2 Posts 2 Posters 785 Views 2 Watching
      CheapDad
      I’d like the newsfeed to appear in the lower right corner of my MM. I have it set to bottom_right, but that simply left justifies it. I also have word wrap enabled.
      In short, I’d like it appear in a box similar to weather or the calendar, with both the article title and description wrapping as needed. I realize that I likely have to reduce the font to accomplish that as well.
      Can anyone give me a head start?
      CheapDad
        sdetweil @CheapDad
        @cheapdad well, its only a start
        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1619795022054
        css is an enormous topic… this is the fastest way to see what works… (altho because it changes the topic, its hard to work on some of it… )
        https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1611671889049
        you will need to change the width of the surrounding elements.
        newsfeed already provides a couple css styles (which you can override in custom.css
