    Run MM2 from within Home Assistant
    10 Posts 6 Posters 3.4k Views 6 Watching
      Moriarte
      Hey everybody!
      Total noob here.
      I’m trying to find out if there is a working method for installing MM2 as an add-on in Hass.io.
      I want to be clear : I am not looking for a Magic Mirror Module. I am looking for a way to install the MM2 server on my HomeAssistant instance and load the MM2 front end onto my rpi zero w as a webpage.
      Is this possible? I found a repository that seemed to have worked at one point but it’s currently locked. https://github.com/hassio-addons/addon-magicmirror
      FLhTF S cowboysdudeC 3 Replies Last reply
      • FLhTF
        FLhT @Moriarte
        Me too :-)
        Though I haven’t thought through it as well as @Moriarte yet.
        Can I run MM2 & Hass.io on the same RPi at the same time?
          sdetweil @Moriarte
          @Moriarte so, fork it(worked for me) , and make whatever changes u need…
          G 1 Reply Last reply
            sdetweil @FLhT
            @FLhT depends on what u expect your MM to do… display calendar sure…
            play youtube videos? maybe not
            • G
              gkchimz @sdetweil
              @sdetweil - what does it mean to ‘fork’ it?
                sdetweil @gkchimz
                @gkchimz on github, top right is a button called fork
                means make a connected copy
                now you can change yours all u want… and IF you have something u want to contribute back, you create a PULL request , for the author to PULL your changes into their master copy…
                • cowboysdudeC
                  cowboysdude Module Developer @Moriarte
                  @moriarte You can but what I did is install it on the same server as HA and run it on its own. I did that so I can run HA and MM which I can then display either or on my bathroom mirror. ;)
                  I didn’t want MM running with HA, I wanted them independent of each other.
                  D 1 Reply Last reply
                  Reply Quote 3
                    dmolony @cowboysdude
                    @cowboysdude Do you have a way of toggling between HA and MM?
                    • cowboysdudeC
                      cowboysdude Module Developer @dmolony
                      @dmolony I running both on Brave Browser so at the moment I have tabs set up one for each and when I want to look I change out of full screen mode and look.
                      Yes I know, NOT very practical but it does work for me because my MM install really isn’t made to be seen other then the other mirrors I have set up in my house and the ‘server’ is really for HA as it’s a 32" touch screen.
                      I just have it installed that way because my ‘server’ is a mini-ITX that runs a real CPU and 8 gigs of ram :) Some of my modules for MM cannot run on a pi as to get my data it’s very taxing soooooooo… a mini ITX it is :)
                        @cowboysdude Cool. 32" HA touch dashboard sounds awesome!
