Run MM2 from within Home Assistant
10 Posts 6 Posters 2.1k Views 6 Watching
    Moriarte
    Hey everybody!
    Total noob here.
    I’m trying to find out if there is a working method for installing MM2 as an add-on in Hass.io.
    I want to be clear : I am not looking for a Magic Mirror Module. I am looking for a way to install the MM2 server on my HomeAssistant instance and load the MM2 front end onto my rpi zero w as a webpage.
    Is this possible? I found a repository that seemed to have worked at one point but it’s currently locked. https://github.com/hassio-addons/addon-magicmirror
    F S C 3 Replies Last reply Oct 13, 2020, 2:47 PM Reply Quote 0
    • F Offline
      FLhT @Moriarte
      Me too :-)
      Though I haven’t thought through it as well as @Moriarte yet.
      Can I run MM2 & Hass.io on the same RPi at the same time?
      S 1 Reply Last reply Oct 13, 2020, 2:50 PM Reply Quote 0
      • S Away
        sdetweil @Moriarte
        @Moriarte so, fork it(worked for me) , and make whatever changes u need…
        G 1 Reply Last reply Nov 3, 2020, 4:11 PM Reply Quote 1
        • S Away
          sdetweil @FLhT
          @FLhT depends on what u expect your MM to do… display calendar sure…
          play youtube videos? maybe not
          • G Offline
            gkchimz @sdetweil
            @sdetweil - what does it mean to ‘fork’ it?
            S 1 Reply Last reply Nov 3, 2020, 4:13 PM Reply Quote 0
            • S Away
              sdetweil @gkchimz
              @gkchimz on github, top right is a button called fork
              means make a connected copy
              now you can change yours all u want… and IF you have something u want to contribute back, you create a PULL request , for the author to PULL your changes into their master copy…
                cowboysdude Module Developer @Moriarte
                @moriarte You can but what I did is install it on the same server as HA and run it on its own. I did that so I can run HA and MM which I can then display either or on my bathroom mirror. ;)
                I didn’t want MM running with HA, I wanted them independent of each other.
                D 1 Reply Last reply May 11, 2021, 3:30 PM Reply Quote 3
                  dmolony @cowboysdude
                  @cowboysdude Do you have a way of toggling between HA and MM?
                  C 1 Reply Last reply May 12, 2021, 1:29 AM Reply Quote 0
                    cowboysdude Module Developer @dmolony
                    @dmolony I running both on Brave Browser so at the moment I have tabs set up one for each and when I want to look I change out of full screen mode and look.
                    Yes I know, NOT very practical but it does work for me because my MM install really isn’t made to be seen other then the other mirrors I have set up in my house and the ‘server’ is really for HA as it’s a 32" touch screen.
                    I just have it installed that way because my ‘server’ is a mini-ITX that runs a real CPU and 8 gigs of ram :) Some of my modules for MM cannot run on a pi as to get my data it’s very taxing soooooooo… a mini ITX it is :)
                    D 1 Reply Last reply May 12, 2021, 2:35 AM Reply Quote 1
                      @cowboysdude Cool. 32" HA touch dashboard sounds awesome!
