    FYI new weather_plus onecall module
    17 Posts 3 Posters 3.6k Views 2 Watching
      scumbelly
      I downloading the new weather_plus onecall module to test it out.
      Once configured, etc. I rebooted and the screen area where I assigned it was blank.
      No loading error, nothing.
      I toggled the developers tool and saw 1 error (1 warning re: Electron security). Console showed an error for "Uncaught SyntaxError: Unexpected token ‘:’ module.js:43.
      I opened up the .js file and noticed that defaults had 2 showHumidity listed, one false and one true. I edited out the false showHumidity.
      The apiBase: was set as https:://api.openweathermap.org/data/, so I edited it to “https:://api.openweathermap.org/data/”,
      Ultimately I made additional changes to the .js
      - Define required scripts. Removed “font-awesome.css” (font-awesome already loaded).
      - Define required translations. deleted en&ro.json and made return false (en.json error).
      The weather_plus.css contains 2 addresses. I deleted these as 5.14.0 is a 404 error.
      @import url(“https://cdnjs.cloudflare.com/ajax/libs/font-awesome/5.14.0/css/font-awesome.min.css”);
      @import url(“https://cdnjs.cloudflare.com/ajax/libs/weather-icons/2.0.10/css/weather-icons.min.css”);
      I think that’s everything I did.
      My config is -
      module: “weather_plus”,
      position: “top_right”,
      lat: “xx.xxxxxx”,
      lon: “-xx.xxxxxx”,
      showWindDirectionAsArrow: false,
      appid: “bunchofnumbers”,
      I’m not sure if I had to do all the changes but it’s loading.
      Nice module Hangorazvan.
      Cheers
        A Former User @scumbelly
          scumbelly
          @hango
          Hi.
          I deleted my existing weather_plus module and did a “git clone”.
          On the reboot the module came up “loading”.
          Developers Tool showed 2 errors and 1 warning.
          First error was “Failed to load resource the server responded with a staus of 404 font-awesome.min.css:1”
          Second error was “Error on loading stylesheet: modules/weather_plus/weather_plus.css loader.js:215”
          The warning was the Electron security message.
          I removed the 404 error "import url("https://cdnjs.cloudflare.com/ajax/libs/font-awesome/5.14.0/css/font-awesome.min.css");" from the .css file.
          On reboot the module loaded.
          I tried to visit “https://cdnjs.cloudflare.com/ajax” to update the link but a “resources not found” message was returned.
          Only “https://cdnjs.cloudflare.com/” exists.
          Cheers.
              scumbelly @Guest
              @hango
              The latest https://cdnjs.cloudflare.com/ajax/libs/font-awesome/5.15.3/css/fontawesome.min.css did not throw a 404 error
              https://cdnjs.cloudflare.com/ajax/libs/weather-icons/2.0.12/css/weather-icons.min.css returns a 404 error. For fun I tried 2.0.11 to no avail. However 2.0.10 still works.
              Another odd thing is that with showSun: true and onlyTemp: false there is no sunriseSunsetIcon displayed.
              Cheers.
                  scumbelly @Guest
                  @hango
                  O.K. The time is displayed just no icon.
                  Thanks for the information.
                  Regards.
                      scumbelly @Guest
                      @hango
                      Adding the space worked. Icon now presented.
                      Cheers.
                      • cowboysdudeC Offline
                        cowboysdude Module Developer @scumbelly
                          scumbelly @cowboysdude
                          @cowboysdude
                          Nice. I think I saw that module in another post.
                          Has this module been made public?
                          Cheers.
                            scumbelly @Guest
                            @hango
                            I powered off my test system for the day. Today, when I powered it up, everything loaded except the weather_plus module.
                            It is stuck at loading.
                            I toggled the dev tool and found no errors.
                            I guess I’ve got some investigating to do.
                            Cheers
                              scumbelly @scumbelly
                              @hango
                              I have some data corruption. When I powered down last night - via a momentary switch, the system did not want to shutdown right away. It took multiple presses to get the system to shutdown.
                              Time to rebuild.
                              However, something I did was edit the .js file to change (“FEELS!”) to (“FEELS”) and edit the en translation from changed.\nPlease to changed. \Please
                              Later.
                              Cheers
                                  scumbelly @Guest
                                  @hango
                                  I changed a typo in a output string. It will not impact the performance.
                                  Cheers
                                      scumbelly @Guest
                                      @hango
                                      O.K. Thanks for the explanation.
                                      Cheers
