    How Can I Mount my smart mirror to a wall?
    18 Posts 5 Posters 7.0k Views 5 Watching
      sdetweil @PeterPang
      @peterpang he said about 6.5 pounds. not much
      • DentraxD Offline
        Dentrax Module Developer @sdetweil
        @sdetweil said in How Can I Mount my smart mirror to a wall?:
        @dentrax how much space is left between the outside of the case and the back sliding panel?
        it’s exactly 10 mm, vertically 52 mm. Would C is most suitable in this situation? What can I do alternatively?
        alt text
          sdetweil @Dentrax
          @dentrax C requires 2 fasteners, which will put a twisting force on the side of the frame as well as the weight force, which is why I suggested A. it can rotate a little to point towards the loop center point(s).
          DentraxD 1 Reply Last reply Reply Quote 0
          • DentraxD Offline
            Hmm, you are right. I think we don’t want to put twisting forces on the side corners.
            I guess I need to find a hanger hook at (10mmx52mm) size and with just one screw so that it is able to rotate to point towards the center point?
            So, something like this?
            alt text
              sdetweil @Dentrax
              @dentrax u would mount it on the BACK surface, not the TOP
              red is the wire from the two hangers
              to keep the unit appearing flush against the wall, you would need to add two bumpers at the bottom
              same thickness of the a mount on the back…
              the A hanger will rotate toward the wire centerpoint
              • DentraxD Offline
                Oh, I see now. Thanks for the illustration! That’s makes sense. But… I’m not sure if I can screw it into that narrow slider. It’s exactly 7mm. The sliding system will be broken, if the screw is long enough. 🤔 But at the same time, the hanger needs to be attached strongly. That’s my concern. :(
                alt text
                  sdetweil @Dentrax
                  @dentrax you are not screwing into the space with the slot, more the outside edge, in the 10mm NOT slotted
                  that is why I said its a shame, you don’t need so much slot… but too late now
                  u need the back panel to slide out without removing any fasteners… u said that in the beginning
                  but the slot is why you do not want to use C as the twisting could break the slot…
                  • DentraxD Offline
                    Thanks! I brought 2 Cs and 4 As yesterday. I’m sharing pictures to confirm if I fully understand what you’re proposing. :)
                    Making two screws to Cs will apply twisting force. I agree that. I guess a use-case like the first picture I drew is a bit risky, right?
                    Also, I’m thinking that is it more risky to attach a single screw both sides, since we only 10mm area, which is why we need to use strong screws, i guess. I just want to be sure that it’s reinforced enough as well.
                    I’m sorry that I keep pinging you about this thread. I hope this thread will help other people as well from whom come from search engines. (Or maybe it’s just a specific case for me, lol)
                    alt text
                    alt text
                      sdetweil @Dentrax
                      @dentrax last pic, correct, in that 10mm space.
                      you want the weight to be hanging, so the mounts nearear the top
                      and for 1st pic, no C, just wire from A to center point and back down to A on the other side,
                      the A closest to the top
                      A will rotate a little on its screw to point to the center of the cable
                      you could use C as well, using only the bottom screw… so it rotates…
                      this would allow the loop of cable at C to be in the open space behind the mirror, reducing the protusion from the wall to just the thickness of the mounting flange
                      strong screws, yes, but make it long too… at least 1/2 the thickness of your side panel
                      they make them for holding kitchen cabinets which are indestructible…
                      but this is not much weight
                      u want a flat head screw , to keep the protrusion small as well
                      there is not much force pulling away from the back surface, only sideways to the center
                      DentraxD 1 Reply Last reply Reply Quote 1
                      • DentraxD Offline
                        Thank you so much! I’m just thinking if I don’t want to use a “hanger wire”, can i do it this way? And for the wall (hanging) side, I can go with something like “L screw hook hanger”, as the following in the second picture. What do you think?
                        alt text
                        alt text
