    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 158.6k Views 19 Watching
      sdetweil @JohnGalt
      @johngalt u are going here, https://dev.fitbit.com/apps/new, right??
      have to go to the DEV site not normal fitbit.com
        JohnGalt @sdetweil
        @sdetweil: THANKS, I knew it was something simple… I guess i read the instructions [“Go to Fitbit …”] and just went to Fitbit, using my usual approach of launching it via my password manager. When I instead went to the dev site, it was straightforward to create an app. Thanks again!
        • TipponT Offline
          Tippon @Vizulize
          @vizulize said in MMM-Fitbit2:
          @tippon Hopefully this is fixed: https://github.com/m-roberts/MMM-Fitbit2/commit/e958665dcf63900d38f5405961a1a176d5ba2fcf
          Thank you :)
          It seems to have solved the Python issue, but I’m still not seeing the calories I’ve eaten.
          I’m really sorry. Please ignore me, I’m an idiot! :confounded_face:
          I just noticed on the log that there was no figure set for my calorie goal, so I went through my profile on the Fitbit site, and the calorie goal wasn’t listed there either. I set it up sometime last year when I originally started trying to diet, but for some reason, the goal has gone and I have no idea why. It still shows up on my phone as I’ve got everything linked to everything else, so it must be populated from another app.
          I feel like a muppet, but on the bright side, I’ve probably just burned of a few hundred calories just from embarrassment :beaming_face_with_smiling_eyes:
          Please forgive me if I'm slow to reply, I'm currently experiencing memory issues, and sometimes forget that I've asked a question >.<
          • TipponT Offline
            Tippon
            Sorry to be a pain, but my calories in is wrong again. I set a goal of 1,400 calories per day after my last post, and entered 51 calories of snacks to test it. It worked perfectly, and as well as showing my calories in on my mirror, the browser log showed the correct details being fetched (caloriesIn (data/goal): 51/1400). At some point today the goal has disappeared. It’s now showing caloriesIn (data/goal): 0/0.
            I’ve opened the Fitbit dashboard and set up a food plan, in case that was the issue, but it hasn’t made a difference. My food has been logged and is showing correctly in my Fitbit dashboard, but it’s not transferring to the module.
            I adjusted my weight and added some water, and both showed up immediately, so the module is obviously getting data, but I can’t figure out why it’s not getting my calories in.
            Thanks for looking :)
            • TipponT Offline
              Tippon
              Sorry, I can’t edit my last post.
              It’s past midnight, and my calorie in goal is showing again. It’s back to zero and showing the full amount of calories available for the 14th. I’ll check tomorrow and see if it changes or disappears, and see if it changes once I add my breakfast or dinner.
              TipponT 1 Reply Last reply Reply Quote 0
              • TipponT Offline
                Tippon @Tippon
                Seems to be working properly. Apparently Fitbit doesn’t like it when you set your own calorie goals.
                  JJW
                  ./Init.sh ISSUE
                  I’m new to modules etc, so sorry if this is a dumb issue. When I run ./init.sh in the terminal I get the error message
                  npm ERR! must provide string spec
                  npm ERR! /home/pi/.npm/_logs/2021-06-05T13_55_01_431Z-debug.log
                  The debug log
                  0 verbose cli [ ‘/usr/bin/node’, ‘/usr/local/bin/npm’, ‘install’ ]
                  1 info using npm@7.16.0
                  2 info using node@v10.23.1
                  3 timing npm:load:whichnode Completed in 8ms
                  4 timing config:load:defaults Completed in 11ms
                  5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 11ms
                  6 timing config:load:builtin Completed in 13ms
                  7 timing config:load:cli Completed in 13ms
                  8 timing config:load:env Completed in 2ms
                  9 timing config:load:file:/home/pi/MagicMirror/modules/MMM-Fitbit2/.npmrc Completed in 2ms
                  10 timing config:load:project Completed in 6ms
                  11 timing config:load:file:/home/pi/.npmrc Completed in 1ms
                  12 timing config:load:user Completed in 1ms
                  13 timing config:load:file:/etc/npmrc Completed in 0ms
                  14 timing config:load:global Completed in 1ms
                  15 timing config:load:validate Completed in 2ms
                  16 timing config:load:credentials Completed in 9ms
                  17 timing config:load:setEnvs Completed in 7ms
                  18 timing config:load Completed in 66ms
                  19 timing npm:load:configload Completed in 67ms
                  20 timing npm:load:setTitle Completed in 2ms
                  21 timing npm:load:setupLog Completed in 12ms
                  22 timing npm:load:cleanupLog Completed in 17ms
                  23 timing npm:load:configScope Completed in 0ms
                  24 timing npm:load:projectScope Completed in 2ms
                  25 timing npm:load Completed in 113ms
                  26 timing config:load:flatten Completed in 18ms
                  27 timing arborist:ctor Completed in 5ms
                  28 timing idealTree Completed in 35ms
                  29 timing command:install Completed in 146ms
                  30 verbose stack TypeError: must provide string spec
                  30 verbose stack at new Edge (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/edge.js:48:13)
                  30 verbose stack at Node.[_loadDepType] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:781:9)
                  30 verbose stack at Node.[Arborist.Node._loadDeps] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:765:23)
                  30 verbose stack at new Node (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:232:20)
                  30 verbose stack at Arborist.[rootNodeFromPackage] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:365:18)
                  31 verbose cwd /home/pi/MagicMirror/modules/MMM-Fitbit2
                  32 verbose Linux 5.10.11-v7+
                  33 verbose argv “/usr/bin/node” “/usr/local/bin/npm” “install”
                  34 verbose node v10.23.1
                  35 verbose npm v7.16.0
                  36 error must provide string spec
                  37 verbose exit 1
                  Any help with the issue would be greatly appreciated thank you.
                  • V Offline
                    Vizulize Module Developer @JJW
                    @jjw A quick Google search for this error suggests to me that it is related to your node/npm versions, but I can’t offer any more input than that I’m afraid!
                      JJW @Vizulize
                      @vizulize No worries, thank you. :beaming_face_with_smiling_eyes:
                        sdetweil @JJW
                        @jjw looks like npm v7…
                          JJW @sdetweil
                          @sdetweil sorry for the lack of knowledge, but what does that mean/what do I have to change.
                            sdetweil @JJW
                            @jjw from the commandline do
                            npm install -g npm@6.14.10
                            MAY need sudo in front if it fails for permissions error
                            after then check
                            npm -v
                            then redo the steps u were trying to do before
                              JJW @sdetweil
                              @sdetweil said in MMM-Fitbit2:
                              Will try now, thank you very much.
                                JJW @sdetweil
                                @sdetweil Thank you for your help, have the Fitbit module displaying on the monitor now, however, just says loading.:grinning_squinting_face:
                                  sdetweil @JJW
                                  @jjw now we need to look for messages in the place u start MM
                                  npm start or pm2, if pm2, then the pm2 logs --lines=100 command will show
                                  and the developers window on the MM screen
                                  ctrl-shift-i, select the console tab, and add part of the module name to the filter field , fit
                                    JJW @sdetweil
                                    @sdetweil I ran “pm2 logs --lines=100” in the command line and the only returns I got were for the calendar.
                                    0|MagicMir | [05.06.2021 18:31.09.798] [INFO] Calendar-Fetcher: Broadcasting 10 events.
                                    I’m sorry I don’t know what you mean by developer window, but when I use ctrl+shift+i out of the cmd I take a screenshot and then when I’m in the cmd I just rename the box.
                                      JJW @sdetweil
                                      @sdetweil I ran another test for 1000 line and the only mention of Fit is:
                                      0|MagicMir | [05.06.2021 18:22.00.914] [INFO] Checking git for module: MMM-Fitbit2
                                      After that, it moves onto multicast.
                                        sdetweil @JJW
                                        @jjw on the magicmirror screen, not commandline
                                        press ctrl-shift-i together
                                        a new window will open 1/2 the Mm screen
                                        in that window there is a tabbed interface,
                                        here showing error from one of my modules, part of name in filter field
                                          JJW @sdetweil
                                          @sdetweil Ah, I think because I’m accessing my Pi via VNC viewer, that’s what makes it take a screenshot instead of opening that menu, even when on the MM screen, is there another way to access this? If not work directly through the Pi.
                                            sdetweil @JJW
                                            @jjw well, you could access from your pc, if the address/ipWhitelist settings in config.js allow it
                                            then use chrome to view and open the dev window
                                            • 3 / 5
