    MagicMirror as a website
    8 Posts 5 Posters 5.4k Views 5 Watching
    • L Offline
      levon @broberg
      @broberg “Or that you open it up to the web (which I don’t recommend).”
      I’m new to MM, could you elaborate on this please? Is this because it doesn’t render well, or is slower, or … would someone be able to tell if the browser was in full-screen mode?
      Just curious - thanks.
        sdetweil @levon
        @levon u potentially open your network to internet hacking…
        • L Offline
          levon @sdetweil
          Thanks @sdetweil but just to clarify, only if you do port-forwarding and make that site available outside your personal/home network, right?
            sdetweil @mosheva
            @mosheva you could run all 4 on one pi, with different ports, but the same config structure
            and you could use the linux command (ln) to link a common folder to the one used by a module to display your messages
            so all four are taking from the exact same content
            each ‘tv’ is viewing one MM config (port)
            all vs having 4 pis… don’t know what your objective is yet. where the tvs are, etc…
              sdetweil @levon
              @levon yes, we didn’t get the all in one building network
              if u only want to display one page, then u don’t need MM at all.
              mm is intended to allow you to combine multiple info sources on the same page at the same time.
