    oneweathermap
    20 Posts 5 Posters 7.7k Views 5 Watching
      Ray
      Hello everyone.
      First off I want to let you know I am new to all this and I’m learning a lot from everyone and having a lot of fun doing it.
      I recently installed oneweathermap, The newer version where you just use your coordinates as well as your apikey. I did sign up and got my free key, but my problem is is always a hit and miss. Some days it’s very accurate and other days it’s off as much as 4 to 3°. What I have noticed when it gets to 68, It stops working. All other weather stations say it’s in the 70s am I doing something wrong here.the Coordinates that I’m using are Walnut Creek, California 37.9101,-122.0652 , which I got from Google search the original coordinates from oneweathermap showed the same response
      			module: "MMM-OpenWeatherForecast",
      			header: "Forecast",
      				apikey: "Mykey", //only string here
      				latitude: 37.9101,            //number works here
      				longitude: -122.0652          //so does a string
      defaults: {
          apikey: "",
          latitude: "",
          longitude: "",
          updateInterval: 1, // minutes
          requestDelay: 0,
          language: config.language,
          units: "imperial",
          displayKmhForWind: false,
          concise: true,
          iconset: "3c",
          colored: true,
          useAnimatedIcons: true,
          animateMainIconOnly: true,
          animatedIconStartDelay: 1000,
          mainIconSize: 100,
          forecastIconSize: 70,
          updateFadeSpeed: 500,
          showFeelsLikeTemp: false,
          showSummary: false,
          showCurrentConditions: true,
          showExtraCurrentConditions: true,
          extraCurrentConditions: {
            highLowTemp: true,
            precipitation: true,
            sunrise: true,
            sunset: true,
            wind: true,
            barometricPressure: false,
            humidity: true,
            dewPoint: false,
            uvIndex: true,
            visibility: false
          forecastHeaderText: "Forecast",
          forecastLayout: "tiled",
          showHourlyForecast: false,
          showHourlyTableHeaderRow: false,
          hourlyForecastTableHeaderText: "Hourly",
          hourlyForecastInterval: 3,
          maxHourliesToShow: 3,
          hourlyExtras: {
            wind: true,
            humidity: false,
            dewPoint: false,
            uvIndex: false,
            visibility: false
          showDailyForecast: false,
          showDailyTableHeaderRow: false,
          dailyForecastTableHeaderText: "Daily",
          maxDailiesToShow: 3,
          dailyExtras: {
            sunrise: false,
            sunset: false,
            wind: true,
            humidity: false,
            dewPoint: false,
            uvIndex: false
      I’m thinking it’s because it’s a free subscription and is limited
      Hope you can help
      Ray
        sdetweil @Ray
        @ray please wrap text from config.js in the code block…
        mark the text, and then hit the icon above the editor that looks like </>
          Ray @sdetweil
          @sdetweil I’m not sure what it is that you’re talking about.
          I put in from:config.js just so everybody knows where I got my information from
          I’m new at all this so please excuse my ignorance
            sdetweil @Ray
            @ray so, I asked you to edit your post to make it more readable
            I have done it for you
              Ray @sdetweil
              @sdetweil thank you very much I appreciate that I’m learning so please be patient with me but I’m having a lot of fun doing it
              please forgive my ignorance
                CheapDad
                If I’m correct, this means you’re pulling new data every minute:
                “ updateInterval: 1, // minutes”
                Since free is limited, I wonder if you’re pulling too frequently. You could change the pull to every 10 minutes to see if that changes anything.
                W R 2 Replies Last reply Reply Quote 0
                • W
                  Wenike @CheapDad
                  @cheapdad @Ray It looks like you’ve updated the default values in MMM-OpenWeatherForecast.js rather than putting them into the config section of your config.js? Its generally recommended not doing that because that makes it harder to update the module in the future (you have to save your copy of the file elsewhere, update the module and put your changes back and hope you didn’t break anything by putting your changes back).
                  In this case, being on the free tier with openweathermap shouldn’t cause issues, as they limit that to 60 calls/minute or 1,000,000 calls/month and you’re only going to hit around 44,640. Unless you’re using multiple modules hitting openweathermap, at which point you could be hitting issues.
                  Can you try deleting that MMM-OpenWeatherForecast.js file (or at least rename it to not be that name) and do a git pull in that folder, which should pull it down again. Put your changes in the config.js instead and see if that fixes your issues?
                    Ray @CheapDad
                    @cheapdad well, you are correct. I did try doing one minute.
                    I have also gone as high as 240, which is roughly 4 hours with still the same results for one minute was only an experiment to see what has changed between one minute and 240 and like I said I still get the same results they seem to always be a hit and miss.
                    I’m new at programming, but I am learning
                      Ray @Wenike
                      @wenike thank you very much for your response.
                      That’s one thing I have not tried. I will take your recommendation and make all my changes in the config file instead. I have no problem with deleting the program and then reinstalling it is not an issue.
                      I did not know that all changes are supposed to be done in the config file not the main file. I know it now, and I will fix it and let you know
                        Ray
                        Hello everyone, I thought I give everybody an update.
                        So I decided to wipe everything out and start over from scratch. I had a lot of fun doing it and learned a lot. Everything seems to be running much better. And all my changes are now in the config file. My email even gets retrieved faster than my phone, How funny is that.
                        onewhethermap though was doing perfectly with only a 1° and 2° off until it reached 81°. Then everything started going downhill. It is still 86° outside but it is displaying 79 so I don’t know what’s going on.
                        I change the updateInterval: from 10 to 20 and we’ll see how that works.
                        I also wanted to thank everyone for helping me out . I did not know all changes were supposed to be in the config file only. So once again, thank you for that information.
                        TipponT 1 Reply Last reply Reply Quote 0
                        • TipponT
                          Tippon @Ray
                          @ray Hi Ray :)
                          Try changing your weather location in the config file. Instead of using the latitude and longitude, try using locationID and using the value from the Open Weather Map site for your area here (from the end of the url):
                          https://openweathermap.org/city/5406990
                          So in your case it would be
                          locationID: 5406990
                          I found that this worked for me when the latitude and longitude didn’t :)
                          Please forgive me if I’m slow to reply, I’m currently experiencing memory issues, and sometimes forget that I’ve asked a question >.<
                            Ray @Tippon
                            @tippon I have actually tried just that When I first installed it and use that exact same number along with the coordinates that onewhethermap suggested but since I upgraded to the newer version. The newer version doesn’t use that anymore. Not to say I can’t add it
                            I actually change the retrieval time from 10 to 20 so far it seems to be working. I’m getting anywhere between 1° and 2° off which I can accept that even the professionals who give us the weather are sometimes off by 1° and 2° from different stations. So keep your fingers crossed that that will be consistent throughout today.
                            Thanks for your suggestion though, since I’m new on here. I’m open to any kind of suggestion
                            • TipponT
                              Tippon @Ray
                              @ray Try just using the location ID and see if it’s more accurate. I’m pretty sure I had problems when I tried to use both.
                              You can comment out the coordinate lines by putting // in front of them, so you don’t have to delete and retype them :)
                                Ray @Tippon
                                @tippon okay, that’s an idea. I didn’t think about. I will give it a try and let you know
                                  Ray
                                  So I think I found the problem, but don’t know how to fix it. It’s been off as much as 3 to 4°. According to other reliable weather like local news. when I restart Magic mirror it is now only one degrees off so I’m not quite experienced enough yet, but I think it has something to do with retrieval data or I think they call it, call for data which I sent back to 10 minutes
                                  If I didn’t explain that right. I apologize. I’m still learning
                                    Ray @Tippon
                                    @tippon unfortunately, I have the newer version so location ID is no longer there just coordinate
                                    • TipponT
                                      Tippon @Ray
                                      @ray said in oneweathermap:
                                      I’ve got the up to date version too. You can put the locationID in yourself. This is the config for one of my weather modules, with my personal data removed:
                                            module: 'weather',
                                            position: 'top_right',
                                      		weatherProvider: 'openweathermap',
                                                      type: 'current',
                                      		apiKey: "xxxxxxxxxxxxxxxxx",
                                      		locationID: 1234567
                                      As you can see, I’ve removed the coordinates lines and added in the locationID line instead.
                                      You can use the options from the documentation here to change the config to suit your needs:
                                      https://docs.magicmirror.builders/modules/weather.html#configuration-options
                                        Ray @Tippon
                                        @tippon well, that’s interesting. So I tried your method and it Just keeps saying loading, which it never did. I verified my location ID just to make sure it was correct and it was.
                                        What I’m finding out is when I use my current setting. When it reaches 70 or 80°. It starts losing accuracy as much as 5°
                                        anything below those temperatures. The accuracy is between 1 and 2°
                                        also, just to let you know I’m running this on Lennix mint
                                        if I can get it to be constant 1 or 2° difference. I would be perfectly happy with that
                                        • TipponT
                                          Tippon @Ray
                                          @ray I’m really sorry, I’ve got things wrong.
                                          I’m not sure why, but I thought you meant that you were using the Open Weather Map configuration for the default weather module, which is what I’m doing. At least that explains why our experiences don’t match up.
                                          Sorry :confounded_face:
                                            Ray @Tippon
                                            @tippon no problem. I actually just caught that a few hours ago and I’ve been trying to figure out how to fix it.
                                            According to oneweathermap with my current settings. The temperature is correct 97, but where I’m currently at it is 102
                                            what’s funny about it is when you look at the map on their website. My area is not listed so I don’t know where it’s getting it’s coordinates from and no matter what coordinates I use it always comes up with the same temperature that oneweathermap wants to use so I’m confused.
                                            ps I was actually getting ready to send you a message letting you know that I was no longer using the default whether
                                            I’m new at all this so I’m learning as I’m going
                                            so I hope everyone is patient with me. I even got a another message going about Gmail
                                            Anyway, I appreciate all your help and I’m always looking for suggestions
