    Module Border Removal Issue
    Scheduled Pinned Locked Moved Solved Custom CSS
    14 Posts 3 Posters 4.4k Views 3 Watching
      matt216
      Hi.
      I have used custom.css to remove the border lines between modules by inserting:
      header  {
              border-bottom: none;
      However just one module is still showing it - the MMM-MyCommute module, bottom left of screen. Can anyone advise how I might remove?
      Mirror and custom.css below.
      S ankonaskiff17A 3 Replies Last reply Reply Quote 0
        sdetweil @matt216
        @matt216 I don’t know the answer. but which one are you using? there are two
        • ankonaskiff17A Offline
          ankonaskiff17 @matt216
          @matt216 Maybe some version of
          .module.mymodule .header { yada yada }
          SWAG on my part in some respects.
            sdetweil @matt216
            @matt216 appears it is using a separator line between destinations
            ankonaskiff17A 1 Reply Last reply Reply Quote 0
              ankonaskiff17 @sdetweil
              @sdetweil When you address header as in the question above are you not speaking to the page as a whole?
              Some modules have headers effectively turned on while others have header turned off.
              I know that it pays to look at how each individual module is configured by its author.
              If author of module in question is setting that property in their module CSS which one will take precedence, the
              header { property}
              or
              .mymodule {property}
              The following is from my big screen nightmare project via @Piranha1605 and is for setting border color but I think would be applicable to other module properties as well.
              .module.MMM-CalendarExt2,
              .module.weather,
              .module.currentweather,
              .module.calendar,
              .module.MMM-Pollen,
              .module.MMM-SystemStats {
               background-color:#2a313b;
               border-radius:8px;
               padding:8px;
               box-shadow: 0 4px 8px 0 rgba(0, 0, 0, 1), 0 8px 20px 0 rgba(0, 0, 0, 0.19);
                sdetweil @ankonaskiff17
                @ankonaskiff17 notice I didn’t say header… I said separator…
                I do not know how it is formed
                open the dev window, per the linked topic, select the elements tab, and the pointer,
                move the mouse to the line, and click
                look at the classes definition on the right for that line
                in the upper right use display:none to turn it off…
                if the class has module defined classname use that in custom.css
                else use the
                .modulename .??? whatever class it is {
                display:none;
                css setting
                you can lso copy/paste the top right window of css styles into a css entry in custom.css without retyping them
                  matt216
                  Thanks for your help.
                  For more context there are two different commute/traffic modules (I’m testing out the accuracy of the two side-by-side) - MMM-MyCommute and then MMM-Traffic.
                  I have set border-bottom: none addressing header to address the page as a whole, yes. I do not want any of the modules to display the separating line between them.
                  The module MMM-MyCommute is the one with the border-bottom showing. Thanks for the dev tools tip - I can see the page loading:
                  .MMM-MyCommute .row {
                    position: relative;
                    padding: 1px;
                    border-bottom: solid 1px #222;
                    min-height: 35px;
                    min-width: 390px;
                  However if I put the following in custom.css it doesn’t change anything…
                          border_bottom: 0;
                  Thanks again
                    sdetweil @matt216
                    @matt216 its
                    none	Specifies no border. This is default
                    border-bottom:none;
                    you should be able to provide that in the dev window,
                    top right window type border-bottom and none
                    hit enter
                      matt216
                      Got it!
                      I had border_bottom in the custom.css whereas I need border-bottom … classic typo.
                      Interesting I need the line specifically calling out that class. The header address which sorts the rest of the page doesn’t seem to apply to the MMM-MyCommute module.
                      Thanks for recommending browser dev tools - helped me identify the class.
                      Matt
                        sdetweil @matt216
                        @matt216 said in Module Border Removal Issue:
                        yes, and it really eliminates the ‘try this, nope, try this, nope… loop’
                        AND if u set the style in that upper right window that does what you want,
                        you can swipe select them all and copy /paste them into your css entry
                        (whose name would be listed at the bottom of the middle panel)
