config file errors?
/* Magic Mirror Config Sample
*- By Michael Teeuw https://michaelteeuw.nl
- MIT Licensed.
- For more information on how you can configure this file
- See https://github.com/MichMich/MagicMirror#configuration
var config = {
// - “0.0.0.0”, “::” to listen on any interface
// Default, when address config is left out or empty, is “localhost”
port: 8080,
basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],useHttps: false, // Support HTTPS or not, default "false" will use HTTP httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true language: "en", logLevel: ["INFO", "LOG", "WARN", "ERROR"], // Add "DEBUG" for even more logging timeFormat: 24, units: "metric", // serverOnly: true/false/"local" , // local for armv6l processors, default // starts serveronly and then starts chrome browser // false, default for all NON-armv6l devices // true, force serveronly mode, because you want to.. no UI on this device modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "c2647e77b86f9ed7922d3cb499204d0" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "YOUR_OPENWEATHER_API_KEY" } }, ]};
if (typeof module !== “undefined”) {module.exports = config;} -
it says when I run npm run config:check says it’s missing
@adamhrastich the way you posted it, the forum corrupted it.
Please place ``` around the code next time.
That being said, go to the magicmirror directory, and type:
npm run config:checkIt’ll help you solve the errors.
@bkeyport I ran that code and it says the file is not found
@adamhrastich Like this:
pi@officemirror:~ $ cd MagicMirror/ pi@officemirror:~/MagicMirror $ npm run config:check > magicmirror@2.16.0 config:check /home/pi/MagicMirror > node js/check_config.js [08.07.2021 16:19.03.333] [INFO] Checking file... /home/pi/MagicMirror/config/config.js [08.07.2021 16:19.03.575] [INFO] Your configuration file doesn't contain syntax errors :) -
@bkeyport I did and this is what came up.
‘’'pi@raspberrypi:~/MagicMirror $ npm run config:checkmagicmirror@2.16.0 config:check /home/pi/MagicMirror
node js/check_config.js[08.07.2021 18:14.40.549] [ERROR] File not found: /home/pi/MagicMirror/config/config.js
/home/pi/MagicMirror/js/check_config.js:38
throw new Error(“No config file present!”);
^Error: No config file present!
at checkConfigFile (/home/pi/MagicMirror/js/check_config.js:38:9)
at Object. (/home/pi/MagicMirror/js/check_config.js:73:1)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
at startup (internal/bootstrap/node.js:283:19)
at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! magicmirror@2.16.0 config:check:node js/check_config.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.16.0 config:check script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2021-07-08T23_14_40_681Z-debug.log
@adamhrastich Well, there’s your problem. The config file should be
config.js- if you’re trying to use the sample as a base, change to the correct by usingmv config.js.sample config.js -
@bkeyport said in config file errors?:
pi@raspberrypi:~/MagicMirror $ mv config.js.sample config.js
mv: cannot stat ‘config.js.sample’: No such file or directory -
@adamhrastich in your config subdirectory.
~/MagicMirror/config/ -
@bkeyport oh I’m stupid… thanks so much I can not believe I didn’t see that
@adamhrastich It’s alright. Once you get it working, you might want to look into MMM-Config as well. @sdetweil does a hell of a good job automating a ton of this.
