    config file errors?
    11 Posts 2 Posters 3.0k Views 2 Watching
      adamhrastich @BKeyport
      @bkeyport I ran that code and it says the file is not found
      • BKeyportB Offline
        BKeyport Module Developer @adamhrastich
        @adamhrastich Like this:
        pi@officemirror:~ $ cd MagicMirror/
        pi@officemirror:~/MagicMirror $ npm run config:check
        > magicmirror@2.16.0 config:check /home/pi/MagicMirror
        > node js/check_config.js
        [08.07.2021 16:19.03.333] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
        [08.07.2021 16:19.03.575] [INFO]  Your configuration file doesn't contain syntax errors :)
          @bkeyport I did and this is what came up.
          ‘’'pi@raspberrypi:~/MagicMirror $ npm run config:check
          [08.07.2021 18:14.40.549] [ERROR] File not found: /home/pi/MagicMirror/config/config.js
          /home/pi/MagicMirror/js/check_config.js:38
          throw new Error(“No config file present!”);
          Error: No config file present!
          at checkConfigFile (/home/pi/MagicMirror/js/check_config.js:38:9)
          at Object. (/home/pi/MagicMirror/js/check_config.js:73:1)
          at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
          at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
          at startup (internal/bootstrap/node.js:283:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! magicmirror@2.16.0 config:check: node js/check_config.js
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.16.0 config:check script.
          npm ERR! /home/pi/.npm/_logs/2021-07-08T23_14_40_681Z-debug.log
          • BKeyportB Offline
            @adamhrastich Well, there’s your problem. The config file should be config.js - if you’re trying to use the sample as a base, change to the correct by using mv config.js.sample config.js
              @bkeyport said in config file errors?:
              pi@raspberrypi:~/MagicMirror $ mv config.js.sample config.js
              mv: cannot stat ‘config.js.sample’: No such file or directory
              • BKeyportB Offline
                @adamhrastich in your config subdirectory. ~/MagicMirror/config/
                  @bkeyport oh I’m stupid… thanks so much I can not believe I didn’t see that
                  • BKeyportB Offline
                    @adamhrastich It’s alright. Once you get it working, you might want to look into MMM-Config as well. @sdetweil does a hell of a good job automating a ton of this.
