    MMM-cryptocurrency - v1.4
    77 Posts 21 Posters 108.3k Views 25 Watching
      matteodanelli @fox
      @fox Well, css is the right place.
      You should get the class and fix in css file. Let me know if you need help.
      • F Offline
        fox @matteodanelli
        @matteodanelli
        Thank you. But i dont find the distance. Only the font size for some entries
        Issues With MMM-WatchDog known?
        https://forum.magicmirror.builders/post/29827
        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
          matteodanelli @fox
          @fox Yes, because padding is set at default value. You should set it explicitly where needed.
          • F Offline
            fox @matteodanelli
            @matteodanelli
            Would it be possible that you could give me an example? I dont know how to work with padding.
            Thank you in advance
            • H Offline
              Honsbeek
              where can i find the sparkline id’s ?
              is it possible to add the NLG.
              https://coinmarketcap.com/currencies/gulden/
              thanks
                canadrian @Honsbeek
                @Honsbeek go to coinmarketcap, in the list where you see all of the coins, right click on the graph of the desired coin, “open image in new tab” (in chrome), read the number from the url
                for gulden is 254
                  marinswk
                  hello! can someone explain me how can i add a coin that is not in the list of coins? (by the way great module!!)
                    marinswk @marinswk
                    @marinswk well i managed alone at the end…you just need to increase the limit
                    • F Offline
                      fox @marinswk
                      @marinswk said in MMM-cryptocurrency - v1.4:
                      Yes! And the symbol you take from Coinmarketcap, thats all for now
                      • E Offline
                        E3V3A @fox
                        @fox Yes, and from the GH issue I filed, he added the first 100 coins, its easily scriptable to add all.
                        “Everything I do (here) is for free – altruism is the way!”
                          bocapie
                          Could someone add Vertcoin?
                          • E Offline
                            E3V3A @bocapie
                            @bocapie File an issue and ask the repo owner, he’s really friendly and helpful.
                              bocapie
                              Is there a way to display your coin amount?
                              • F Offline
                                fox @bocapie
                                @bocapie said in MMM-cryptocurrency - v1.4:
                                Yes --> https://github.com/SpoturDeal/MMM-crypto-portfolio
                                • O Offline
                                  olexs
                                  Coinmarketcap changed the URLs to their sparkline graphs some time yesterday. Old URLs still load but don’t update anymore. I created a pull request with the updated URL.
                                    causerino
                                    Hi, I am trying to add a newish token to this, but can’t seem to get it to work. I have added the token name and ID to MMM-cryptocurrency.js in the sparklineIDs section, and then added it to my config.js using the name, but it still doesn’t show up.
                                    Am I missing something out?
                                    MMM-cryptocurrency.js - I added ‘summit-koda-token’: 9966,
                                    config.js - I added ‘summit-koda-token’ to the currency section.
                                    My eth, bitcoin still show fine.
                                      Jessendelft @causerino
                                      @causerino Hi!
                                      I know it’s been a while, but I’ve done this as well.
                                      Make sure the SparklineIDs name corresponds with the slug name provided by CoinMarketCaps API.
                                      For example, I wanted to add Elrond’s eGLD.
                                      The ID for this token is 6892, while the slug is elrond-egld. As this includes a hyphen symbol, it needs to be surrounded by quote marks.
                                      So my addition looks like this:
                                      'elrond-egld': 6892,
                                      I also made 2 symbols, which are not required but look pretty.
                                      • 4 / 4
