    MMM-cryptocurrency - v1.4
    77 Posts 21 Posters 112.5k Views 25 Watching
      matteodanelli @fox
      @fox Because in the ranking is too low. You should change limit from 100 to at least 1000 in getTicker function to get it working.
      F 1 Reply Last reply
        canadrian @fox
        @fox said in MMM-cryptocurrency - v1.4:
        @canadrian
        thank you i will give it a try. But i have to maintain the link after every trade?
        Yes, you have to update your portfolio (holdings) and coinfolium url changes.
        • F
          fox @matteodanelli
          @matteodanelli thank you. That did it for me
          @canadrian
          Some of us have still problems with iFrame reloaded :)
          https://forum.magicmirror.builders/topic/4607/show-webpage-iframe-and-reload
          Issues With MMM-WatchDog known?
          https://forum.magicmirror.builders/post/29827
          Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
          • F
            fox
            @crypto Friends :-)
            possible to use the daily chart instead of the 7days?
              Baxer
              Is Bitcoin Cash available?
              M 1 Reply Last reply
              Reply Quote -1
                matteodanelli @Baxer
                @Baxer Yes!
                Just add bitcoin-cash to your config file.
                • F
                  fox @matteodanelli
                  @matteodanelli danke dir nochmal.
                  Wie kann ich
                  • die Schriftart (in gelb) und
                  • Den Abstand (rot)
                  ändern?
                  Bild Text
                    matteodanelli @fox
                    @fox Well, css is the right place.
                    You should get the class and fix in css file. Let me know if you need help.
                    • F
                      fox @matteodanelli
                      @matteodanelli
                      Thank you. But i dont find the distance. Only the font size for some entries
                        matteodanelli @fox
                        @fox Yes, because padding is set at default value. You should set it explicitly where needed.
                        • F
                          fox @matteodanelli
                          @matteodanelli
                          Would it be possible that you could give me an example? I dont know how to work with padding.
                          Thank you in advance
                          • H
                            Honsbeek
                            where can i find the sparkline id’s ?
                            is it possible to add the NLG.
                            https://coinmarketcap.com/currencies/gulden/
                            thanks
                            C 1 Reply Last reply
                              canadrian @Honsbeek
                              @Honsbeek go to coinmarketcap, in the list where you see all of the coins, right click on the graph of the desired coin, “open image in new tab” (in chrome), read the number from the url
                              for gulden is 254
                                marinswk
                                hello! can someone explain me how can i add a coin that is not in the list of coins? (by the way great module!!)
                                  marinswk @marinswk
                                  @marinswk well i managed alone at the end…you just need to increase the limit
                                  • F
                                    fox @marinswk
                                    @marinswk said in MMM-cryptocurrency - v1.4:
                                    Yes! And the symbol you take from Coinmarketcap, thats all for now
                                    E 1 Reply Last reply
                                    • E
                                      E3V3A @fox
                                      @fox Yes, and from the GH issue I filed, he added the first 100 coins, its easily scriptable to add all.
                                      “Everything I do (here) is for free – altruism is the way!”
                                        bocapie
                                        Could someone add Vertcoin?
                                        • E
                                          E3V3A @bocapie
                                          @bocapie File an issue and ask the repo owner, he’s really friendly and helpful.
                                            bocapie
                                            Is there a way to display your coin amount?
                                            • 4 / 4
