    MMM-cryptocurrency - v1.4
    77 Posts 21 Posters 112.5k Views 25 Watching
    • F
      fox @matteodanelli
      @matteodanelli Thank you! It worked and again - what an amazing module. Thank you very much.
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      • F
        fox
        @matteodanelli , @Klizzy
        a portfolio view would be amazing, what do you think?
        Like on the iOS app delta or on cryptocompare or etc. portfolios.
        But its harder to implement i think because its the view of each MagicMirror User’s portfolio ?!
        C 1 Reply Last reply
          canadrian @fox
          @fox said in MMM-cryptocurrency - v1.4:
          alternate way, use maybe coinfolium.com, generate your link and use iframe in the mirror
          F 1 Reply Last reply
          • F
            fox @canadrian
            @canadrian
            thank you i will give it a try. But i have to maintain the link after every trade?
            @matteodanelli
            what is my problem with bitcoin-gold?
              currency: [
                       "bitcoin",
                        "monero",
                        "iota",
                        "eos",
                         "bitcoin-gold"
            and the
              sparklineIds: {
                bitcoin: 1,
                ethereum: 1027,
                ripple: 52,
                litecoin: 2,
                'ethereum-classic': 1321,
                nem: 873,
                stratis: 1343,
                iota: 1720,
                monero: 328,
                eos: 1765,
                'bitcoin-cash': 1831,
                'bitcoin-gold': 2083
            But is does not appear on my Magic mirror :/
            M C 2 Replies Last reply
              matteodanelli @fox
              @fox Because in the ranking is too low. You should change limit from 100 to at least 1000 in getTicker function to get it working.
                canadrian @fox
                @canadrian
                Yes, you have to update your portfolio (holdings) and coinfolium url changes.
                • F
                  fox @matteodanelli
                  @matteodanelli thank you. That did it for me
                  @canadrian
                  Some of us have still problems with iFrame reloaded :)
                  https://forum.magicmirror.builders/topic/4607/show-webpage-iframe-and-reload
                  • F
                    fox
                    @crypto Friends :-)
                    possible to use the daily chart instead of the 7days?
                      Baxer
                      Is Bitcoin Cash available?
                      M 1 Reply Last reply
                      Reply Quote -1
                        matteodanelli @Baxer
                        @Baxer Yes!
                        Just add bitcoin-cash to your config file.
                        • F
                          fox @matteodanelli
                          @matteodanelli danke dir nochmal.
                          Wie kann ich
                          • die Schriftart (in gelb) und
                          • Den Abstand (rot)
                          ändern?
                          Bild Text
                            matteodanelli @fox
                            @fox Well, css is the right place.
                            You should get the class and fix in css file. Let me know if you need help.
                            • F
                              fox @matteodanelli
                              @matteodanelli
                              Thank you. But i dont find the distance. Only the font size for some entries
                                matteodanelli @fox
                                @fox Yes, because padding is set at default value. You should set it explicitly where needed.
                                • F
                                  fox @matteodanelli
                                  @matteodanelli
                                  Would it be possible that you could give me an example? I dont know how to work with padding.
                                  Thank you in advance
                                  • H
                                    Honsbeek
                                    where can i find the sparkline id’s ?
                                    is it possible to add the NLG.
                                    https://coinmarketcap.com/currencies/gulden/
                                    thanks
                                      canadrian @Honsbeek
                                      @Honsbeek go to coinmarketcap, in the list where you see all of the coins, right click on the graph of the desired coin, “open image in new tab” (in chrome), read the number from the url
                                      for gulden is 254
                                        marinswk
                                        hello! can someone explain me how can i add a coin that is not in the list of coins? (by the way great module!!)
                                          marinswk @marinswk
                                          @marinswk well i managed alone at the end…you just need to increase the limit
                                          • F
                                            fox @marinswk
                                            @marinswk said in MMM-cryptocurrency - v1.4:
                                            Yes! And the symbol you take from Coinmarketcap, thats all for now
                                            E 1 Reply Last reply
                                            • 3 / 4
