MMM-cryptocurrency - v1.4
@SvenSommer Thank you! Great additions!
Is there a way to add a custom page within the module? I’m specifically looking to add more coins of my own that you don’t include by default, but every time I do it gets overwritten by a pull.
@rmeskill Hi, sure! You can contribute to the project if you want :)
You can either create a fork of my repository and develop it with your needs. But you’ll lose my updates.
Else, to keep updated, fork the repository and then make a pull request to merge your fork with my repository.
I’ll accept it and everyone will have your useful work :) -
@SvenSommer Amazing Changes.
Thank you both. My question:
How to change the font size?
I was in MMM-cryptocurrency.css but there is no font.
thanksedit: i found it
.mmm-cryptocurrency-icon > tr > td { padding-bottom: 10px; text-align: left; font-size: 80%; }How can i show other graphs?
@fox Hi,
About the graphs, you should add your currency inside sparklineIds array (in Js file), which have to be taken directly from coinmarketcap.com.Let me know if it works!
@matteodanelli thank you.
But i dont know where the sparkline Id is written in coinmarketcap.
e.g. for IOTA: https://coinmarketcap.com/currencies/iota/#tools ? -
@fox You can find id in the homepage of coinmarketcap. Just get the link of the image of the graph of the desired currency.
EG. For IOTA, link is https://files.coinmarketcap.com/generated/sparklines/1720.png, so id is 1720.
@matteodanelli Thank you! It worked and again - what an amazing module. Thank you very much.
@matteodanelli , @Klizzy
a portfolio view would be amazing, what do you think?
Like on the iOS app delta or on cryptocompare or etc. portfolios.
But its harder to implement i think because its the view of each MagicMirror User’s portfolio ?! -
@fox said in MMM-cryptocurrency - v1.4:
But its harder to implement i think because its the view of each MagicMirror User’s portfolio ?!alternate way, use maybe coinfolium.com, generate your link and use iframe in the mirror
@canadrian
thank you i will give it a try. But i have to maintain the link after every trade?@matteodanelli
what is my problem with bitcoin-gold?: { currency: [ "bitcoin", "monero", "iota", "eos", "bitcoin-gold" ],and the
sparklineIds: { bitcoin: 1, ethereum: 1027, ripple: 52, litecoin: 2, 'ethereum-classic': 1321, nem: 873, stratis: 1343, iota: 1720, monero: 328, eos: 1765, 'bitcoin-cash': 1831, 'bitcoin-gold': 2083 },Logo is bitcoin-gold.png
But is does not appear on my Magic mirror :/
@fox Because in the ranking is too low. You should change limit from 100 to at least 1000 in getTicker function to get it working.
@canadrian
thank you i will give it a try. But i have to maintain the link after every trade?Yes, you have to update your portfolio (holdings) and coinfolium url changes.
@matteodanelli thank you. That did it for me
@canadrian
Some of us have still problems with iFrame reloaded :)
https://forum.magicmirror.builders/topic/4607/show-webpage-iframe-and-reload -
@crypto Friends :-)
possible to use the daily chart instead of the 7days?
Thanks -
Is Bitcoin Cash available?
@Baxer Yes!
Just add bitcoin-cash to your config file. -
@matteodanelli danke dir nochmal.
Wie kann ich- die Schriftart (in gelb) und
- Den Abstand (rot)
ändern?
@fox Well, css is the right place.
You should get the class and fix in css file. Let me know if you need help. -
@matteodanelli
Thank you. But i dont find the distance. Only the font size for some entries
