    MMM-cryptocurrency - v1.4
    77 Posts 21 Posters 110.0k Views 25 Watching
      matteodanelli @ArkantosArk
      @ArkantosArk As @strawberry-3-141 mentioned, I use ES6 in the module and so some old browsers aren’t working. Midori uses an old version of the web engine, but I know that it’s the best browser on the RPi1.
      However, I tried to replace in my module a function which creates a problem. I am not sure to have solved totally the problem because I cannot test on Midori.
      I’ve updated the module so you can test it now, hoping that it’s working, or at least it shows less problems :)
      Let me know!
        ArkantosArk @matteodanelli
        @matteodanelli Now it’s working! thanks a lot for this I feel really privileged!. Thanks for taking the effort to update the module just for this.
          canadrian
          Thank you for this module.
          In order to add a new coin, I’ve added into sparklineIds the id, eg. chainlink: 1975,
          ran an nmp install into the MMM-cryptocurrency module, but still no luck,
          sparklineId is correct, am I missing something?
          Thanks in advance.
            matteodanelli @canadrian
            @canadrian said in MMM-cryptocurrency - v1.1:
            chainlink: 1975
            I had configured module to get only top 25 currencies, in order to be more efficient.
            Now I’ve updated module in order to get all 100. If you want to check it out last version you should be able to get it.
              canadrian @matteodanelli
              @matteodanelli works great, thank you!
              • SvenSommerS Offline
                SvenSommer
                Hey @matteodanelli ,
                thank you for this great module.
                I added an alternative display mode to see the changes within the logo view.
                I made a pull request. Here are the changes:
                • 1 hour , 1 day and 7days changes can be displayed by adding ‘logoWithChanges’ as display type.
                • option and screenshots added to README.md
                Looking for some building inspiration?
                Check out my large, thin and metal framed mirror on robstechlog.com.
                Modules released:
                MMM-GoogleAnalytics
                MMM-GrafanaChart
                MMM-GrafanaGauges
                M F 2 Replies Last reply Reply Quote 0
                  matteodanelli @SvenSommer
                  @SvenSommer Thank you! Great additions!
                    rmeskill
                    Is there a way to add a custom page within the module? I’m specifically looking to add more coins of my own that you don’t include by default, but every time I do it gets overwritten by a pull.
                      matteodanelli @rmeskill
                      @rmeskill Hi, sure! You can contribute to the project if you want :)
                      You can either create a fork of my repository and develop it with your needs. But you’ll lose my updates.
                      Else, to keep updated, fork the repository and then make a pull request to merge your fork with my repository.
                      I’ll accept it and everyone will have your useful work :)
                      • F Offline
                        fox @SvenSommer
                        @SvenSommer Amazing Changes.
                        Thank you both. My question:
                        How to change the font size?
                        I was in MMM-cryptocurrency.css but there is no font.
                        thanks
                        edit: i found it
                        .mmm-cryptocurrency-icon > tr > td {
                            padding-bottom: 10px;
                            text-align: left;
                        	font-size: 80%;
                        How can i show other graphs?
                        Bild Text
                        Issues With MMM-WatchDog known?
                        https://forum.magicmirror.builders/post/29827
                        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                          matteodanelli @fox
                          @fox Hi,
                          About the graphs, you should add your currency inside sparklineIds array (in Js file), which have to be taken directly from coinmarketcap.com.
                          Let me know if it works!
                          F 1 Reply Last reply Reply Quote 1
                          • F Offline
                            fox @matteodanelli
                            @matteodanelli thank you.
                            But i dont know where the sparkline Id is written in coinmarketcap.
                            e.g. for IOTA: https://coinmarketcap.com/currencies/iota/#tools ?
                              matteodanelli @fox
                              @fox You can find id in the homepage of coinmarketcap. Just get the link of the image of the graph of the desired currency.
                              EG. For IOTA, link is https://files.coinmarketcap.com/generated/sparklines/1720.png, so id is 1720.
                              • F Offline
                                fox @matteodanelli
                                @matteodanelli Thank you! It worked and again - what an amazing module. Thank you very much.
                                • F Offline
                                  fox
                                  @matteodanelli , @Klizzy
                                  a portfolio view would be amazing, what do you think?
                                  Like on the iOS app delta or on cryptocompare or etc. portfolios.
                                  But its harder to implement i think because its the view of each MagicMirror User’s portfolio ?!
                                    canadrian @fox
                                    @fox said in MMM-cryptocurrency - v1.4:
                                    alternate way, use maybe coinfolium.com, generate your link and use iframe in the mirror
                                    • F Offline
                                      fox @canadrian
                                      @canadrian
                                      thank you i will give it a try. But i have to maintain the link after every trade?
                                      @matteodanelli
                                      what is my problem with bitcoin-gold?
                                        currency: [
                                                 "bitcoin",
                                                  "monero",
                                                  "iota",
                                                  "eos",
                                                   "bitcoin-gold"
                                      and the
                                        sparklineIds: {
                                          bitcoin: 1,
                                          ethereum: 1027,
                                          ripple: 52,
                                          litecoin: 2,
                                          'ethereum-classic': 1321,
                                          nem: 873,
                                          stratis: 1343,
                                          iota: 1720,
                                          monero: 328,
                                          eos: 1765,
                                          'bitcoin-cash': 1831,
                                          'bitcoin-gold': 2083
                                      But is does not appear on my Magic mirror :/
                                      M C 2 Replies Last reply Reply Quote 0
                                        matteodanelli @fox
                                        @fox Because in the ranking is too low. You should change limit from 100 to at least 1000 in getTicker function to get it working.
                                          canadrian @fox
                                          @canadrian
                                          Yes, you have to update your portfolio (holdings) and coinfolium url changes.
                                          • F Offline
                                            fox @matteodanelli
                                            @matteodanelli thank you. That did it for me
                                            @canadrian
                                            Some of us have still problems with iFrame reloaded :)
                                            https://forum.magicmirror.builders/topic/4607/show-webpage-iframe-and-reload
                                            • 3 / 4
