    Show webpage / iframe and reload
    14 Posts 4 Posters 12.3k Views 4 Watching
    • F Offline
      fox
      Due to the massiv problems in the iFrame-reloaded modules,
      • https://forum.magicmirror.builders/topic/2064/loading-website-and-display-it-in-my-mm
      • https://forum.magicmirror.builders/topic/1954/iframe-module-not-showing-content
      • https://forum.magicmirror.builders/topic/2637/mmm-iframereload-iframe-won-t-load
      • https://forum.magicmirror.builders/topic/1126/display-web-widget-on-mirror-through-iframe
      i would like to request a new, stable and working one
      • U Offline
        usafa43tsolo
        I have the same problem - I followed all the fix actions in one of the threads but nothing works for me. I’d be happy to re-post code snips and everything if it helps troubleshooting. Any help would be appreciated! Thanks!
          barnosch
          i had the same and i could fix it, in my special case, by simply reloading the webpage periodically i want to show.
          (i use a wepage that crawls the status of my automatic lawn mower and shows me informations like status and battery)
          If you handle the webpage yourself, thats an easy option.
          If you want to show a external source, it’s not working.
          • strawberry 3.141S Offline
            @fox @usafa43tsolo which modules did you try, there are several of them
            U 1 Reply Last reply Reply Quote 0
            • U Offline
              usafa43tsolo @strawberry 3.141
              @strawberry-3.141 I used this module, which I found from the wiki: https://github.com/alberttwong/MMM-iFrame
                strawberry 3.141 Project Sponsor Module Developer @usafa43tsolo
                @usafa43tsolo you could give this one a try https://github.com/TheBogueRat/MMM-iFrameReload
                https://github.com/desertblade/iFrame
                • U Offline
                  usafa43tsolo
                  Those are the two I’ve tried, specifically the first one. There was a thread that fox referenced that had the same issue and was supposedly fixed but I installed it correctly and fixed (I think) the config file. However, nothing ever shows up.
                    @usafa43tsolo which one of those 4?
                    • U Offline
                      usafa43tsolo
                      https://forum.magicmirror.builders/topic/2637/mmm-iframereload-iframe-won-t-load/7
                        @usafa43tsolo did you try to apply this fix i suggested here a few months ago? https://github.com/TheBogueRat/MMM-iFrameReload/issues/2#issuecomment-291011351
                        • U Offline
                          @strawberry-3.141 That did it. Loads perfectly now. Thank you for pointing that out!
                          • F Offline
                            fox
                            @strawberry-3-141 you mean that fix?
                            adding the line:
                            iframe.setAttribute("timestamp", new Date().getTime());
                            this results in:
                            getDom: function() {
                                            var iframe = document.createElement("IFRAME");
                                            iframe.style = "border:0"
                                            iframe.width = this.config.width;
                                            iframe.height = this.config.height;
                                            iframe.src =  this.config.url + new Date().getTime();
                                            return iframe;
                            but no result
                            @usafa43tsolo could you share your .js file please?
                            edit:
                            i reinstalled it and then put the fix from @strawberry-3-141 from github.
                            now i see in my browser (in the respective frame)
                            Cannot GET /www.google.com
                              strawberry 3.141 Project Sponsor Module Developer @fox
                              @fox did you try another webpage? I think it’s possible for a webpage to deny rendering in an iframe
                              EDIT: See, when I’m testing this in a simple html file < iframe src="https://www.google.com">< /iframe> (without the spaces)
                              I get this error Refused to display 'https://www.google.com/' in a frame because it set 'X-Frame-Options' to 'SAMEORIGIN'.
                              • F Offline
                                fox
                                @strawberry-3-141
                                i saw something similar.
                                But with your hint of deny i created a .htaccess in the folder of the called page with content
                                Options -Indexes
                                and now i can see the page !
                                Thank you for your hint now we can proceed here.
