    [MMM-iFrameReload]: iFrame won't load
    iframe
    10 Posts 7 Posters 8.7k Views 7 Watching
    • binderthB Offline
      binderth
      I’m using https://github.com/TheBogueRat/MMM-iFrameReload to Display the “live feed” of my FOSCAM FI 9900P, which unfortunately doesn’t have an MJPEG-stream ready for MMM-IPCam (https://github.com/RedNax67/MMM-IPCam).
      my config.js:
      		module: 'iFrameReload',
      		position: 'top_left',	// This can be any of the regions.
      				url: "http://192.168.xx.xx:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture&usr=USER&pwd=PASS",
      				width: "640px", // Optional. Default: 100%
      				height: "360px", //Optional. Default: 100px
      				refreshInterval: 10  //Optional. Default: 3600 = 1 hour
      in the logfile, there’s only this:
      No helper found for module: iFrameReload.
      Do I miss something? there’s not even the slightest sign of an iFrame - even if I switched the URL to url: "https://www.google.de",
      Thanks!
      • yawnsY Offline
        yawns Moderator
        Please change it to (look at the module name):
        		module: 'MMM-iFrameReload',
        The readme of the module is wrong :)
        binderthB 1 Reply Last reply Reply Quote 1
        • binderthB Offline
          binderth @yawns
          @yawns said in [MMM-iFrameReload]: iFrame won’t load:
          that’s right!, but even after Setting the “MMM-” in front, it still doesn’t show. still the same entry in the log, but no iframe gets loaded.
          finally, after changing all " to ’ it worked:
          				url: 'http://192.168.178.xx:xx/cgi-bin/CGIProxy.fcgi?cmd=snapPicture&usr=USER&pwd=PASS',
          				width: '640px', // Optional. Default: 100%
          				height: '360px', //Optional. Default: 100px
          				refreshInterval: '10'  //Optional. Default: 3600 = 1 hour
          … only after 10 seconds there’s no reload sadly.
          • yawnsY Offline
            yawns Moderator
            Try removing the ’ ’ from the refreshInterval. Plain numbers should not be written with ’ ’
            binderthB 1 Reply Last reply Reply Quote 0
            • binderthB Offline
              binderth @yawns
              @yawns
              did that already, even played around with the comma at the end…
              see: https://forum.magicmirror.builders/topic/2640/mmm-iframereload-iframe-won-t-refresh
              • U Offline
                usafa43tsolo
                I’m having the same issue. I tried all the fix actions described, but I still can’t get the frame to display:
                module: ‘MMM-iFrameReload’,
                position: ‘upper_third’, // This can be any of the regions.
                // See ‘Configuration options’ for more information.
                url: ‘http://www.google.com’,
                width: ‘100%’, // Optional. Default: 400px
                height: ‘300px’, // Optional. Default: 800px
                refreshInterval: 360 //Optional. Default: 3600 = 1 hour
                Any thoughts?
                • foxF Offline
                  fox
                  No, here is the same problem
                  Does anybode has a module which shows a webpage and refreshes auto?
                  @binderth said in [MMM-iFrameReload]: iFrame won't load:
                  @yawns
                  the Comma would not be the problem or? i also added the
                  iframe.src =  this.config.url + '&' + new Date().getTime();
                  but no refresh
                    Shockwave
                    Adding square brackets around the URL got mine to work. (After changing the title to MMM-iFrameReload) I don’t recall if it still threw the error about the helper module loading or not.
                    change
                    url: ‘www.example.com’,
                    to
                    url: [‘www.example.com’],
                    • U Offline
                      Ultimatum22 Module Developer
                      @binderth said in [MMM-iFrameReload]: iFrame won’t load:
                      That is no error, the module doesn’t has a node_helper class so this log just tells you it didn’t found one so it won’t load. Not sure about your other problem. It looks like a plain string object in the source code. I’ll try to reproduce it over the weekend, to see if I can get it to work.
                      • C Offline
                        chassain 0
                        Hello,
                        Sorry for my english.
                        I’m using MagicMirror with different module. here my configuration :
                        module: “MMM-pages”,
                        disabled: false,
                        modules:
                        [[ ‘MMM-WunderGround’ ],
                        [ “calendar”, “calendar_monthly” ],
                        [ “MMM-GoogleMapsTraffic” , “MMM-MyCommute” ],
                        [ “MMM-iFrameReload” ]], // 3 webcam live on youtube
                        excludes: [ “clock” , “newsfeed” , “MMM-page-indicator” ],
                        rotationTime: 25000,
                        but i have some problems after time because MagicMirror stop to refresh (stop to a page). Maybe cause i have 3 webcam video to see. i changed memory GPU to 16 to allowed more place to video. It’s better but same problems after time.
                        So, i would like,with help, to see one video in page 4 (to reduce memory) and refresh iframe all 10 seconds. The module iFrame was better for my configuration but it doesn’t work.
                        I’m noob and it’s my first investigation with raspberry pi3.
                        Thanks for an idea to adapte my configuration or increase memory.
                        (and sorry for english) ;)
