    Update from 2.15 to 2.16
    35 Posts 5 Posters 14.0k Views 5 Watching
      sdetweil @andyyy
      @andyyy can u send me the ~/MagiMirror/installers/upgrade.log
      | doah, not install , upgrade log… yeesh
      my email is the same user ID at gmail
        I can recreate the problem in my script
        I bet u tried the develop branch. and switched back to master, and these files aren’t in master on 2.15, but the final versions are different than the develop versions.
          andyyy @sdetweil
          Solved for now :)
          I did:
          sudo git fetch --all
          sudo git reset --hard origin/master
          sudo git pull origin master
          My system is still very fragile. When do npm install after that, the screen turn black after reboot.
            sdetweil @andyyy
            @andyyy said in Update from 2.15 to 2.16:
            again, this si because libraries in 2.15 were removed in 2.16 and some modules didn’t document their requirements properly…
            find the MM startup messages (npm start or pm2 logs)
            and look for ‘module not found’
            I REALLY hate reset --hard…
              sdetweil @andyyy
              @andyyy I uploaded fixes to the upgrade script to handle this…
              A 2 Replies Last reply Reply Quote 1
                bdream
                Hi!
                I did the upgrade to my system to 2.16
                Uploading upgrade.log with 600 lines is not possible… because of file format.
                After reboot I have only the mouse in the middle of the screen but MM is not working.
                Also I’m not able to get a connection wit ma Web-Browser.
                Raspberry itself is accessible via SSH.
                Any idea?
                cheers, bdream
                S FoziF 2 Replies Last reply Reply Quote 0
                  sdetweil @bdream
                  @bdream yes look at the mm startup messages
                  we call this the black screen
                    bdream
                    @sdetweil does it mean I have to do in MagicMirror folder?
                    cheers, bdream
                      sdetweil @bdream
                      @bdream no. u are probably missing some modules that mm removed
                      read the startup messages
                      npm start
                      or
                      if using pm2
                      pm2 logs --lines=100
                      • FoziF Offline
                        Fozi Project Sponsor @bdream
                        @bdream I strongly guess that one of the 3rd party modules is not compatible vith MM2.16.0. I had the same issues with MMM-MyCalendar, which caused a black screen after starting MM. My approach is to disable all 3rd party modules by adding the line
                        disabled: true;
                        for each module and enable it one after the other by setting it to
                        disabled: false;
                        Taht might discover quicker, which module is the culprit instead of poking in logs (that is my personal approach!).
                        When you found the module, that causes issues, contact the developer on github, or look for an alternative fork which seems to be maintained.
                        Regarding the above mentioned MMM-MyCalendar module, I reverted to the default calendar module, which works just fine and delivers the same features.
                          sdetweil @Fozi
                          @fozi come on, this is easy. get the messages. it will tell you which lib to install
                            bdream @sdetweil
                            @sdetweil okay, I’m going to try with messages.
                            pi@MagicMirror:~ $ pm2 logs --lines=100
                            0|mm       | Require stack:
                            0|mm       | - /home/pi/MagicMirror/modules/MMM-DWD-Pollen/node_helper.js
                            0|mm       | - /home/pi/MagicMirror/js/app.js
                            0|mm       | - /home/pi/MagicMirror/js/electron.js
                            0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                            0|mm       | -
                            0|mm       |     at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
                            0|mm       |     at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
                            0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                            0|mm       |     at Module._load (internal/modules/cjs/loader.js:848:27)
                            0|mm       |     at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
                            0|mm       |     at Module.require (internal/modules/cjs/loader.js:1032:19)
                            0|mm       |     at require (internal/modules/cjs/helpers.js:72:18)
                            0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DWD-Pollen/node_helper.js:7:15)
                            0|mm       |     at Module._compile (internal/modules/cjs/loader.js:1152:30)
                            0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
                            0|mm       | [31.07.2021 03:30.08.854] [ERROR] Whoops! There was an uncaught exception...
                            0|mm       | [31.07.2021 03:30.08.865] [ERROR] Error: Cannot find module 'request'
                            0|mm       | -
                            0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10) {
                            0|mm       |   code: 'MODULE_NOT_FOUND',
                            0|mm       |   requireStack: [
                            0|mm       |     '/home/pi/MagicMirror/modules/MMM-DWD-Pollen/node_helper.js',
                            0|mm       |     '/home/pi/MagicMirror/js/app.js',
                            0|mm       |     '/home/pi/MagicMirror/js/electron.js',
                            0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                            0|mm       |     undefined
                            0|mm       |   ]
                            0|mm       | }
                            0|mm       | [31.07.2021 03:30.08.868] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            0|mm       | [31.07.2021 03:30.08.869] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            0|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                            0|mm       | [02.08.2021 08:40.08.979] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
                            0|mm       | -
                            0|mm       | [02.08.2021 08:40.09.001] [ERROR] App threw an error during load
                            0|mm       | [02.08.2021 08:40.09.005] [ERROR] Error: Cannot find module 'request'
                            0|mm       | -
                            0|mm       | [02.08.2021 08:40.09.007] [ERROR] Whoops! There was an uncaught exception...
                            0|mm       | [02.08.2021 08:40.09.018] [ERROR] Error: Cannot find module 'request'
                            0|mm       | -
                            0|mm       |     undefined
                            0|mm       |   ]
                            0|mm       | }
                            0|mm       | [02.08.2021 08:40.09.021] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            0|mm       | [02.08.2021 08:40.09.022] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            0|mm       |
                            0|mm       | > magicmirror@2.16.0 start
                            0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                            0|mm       |
                            0|mm       | [30.07.2021 03:30.08.295] [LOG]   Starting MagicMirror: v2.16.0
                            0|mm       | [30.07.2021 03:30.08.304] [LOG]   Loading config ...
                            So it looks to me as MMM-DWD-Pollen will be the problem.
                            That is faster, than going with disabled: true; and disabled: false; over all my modules :crossed_fingers: even it was a guess with the related module to me.
                            @Fozi now i have to see how to deal with your statement “When you found the module, that causes issues, contact the developer on github, or look for an alternative fork which seems to be maintained.”
                            Comment out this module in config and it works again.
                            Many thanks for your fast help!!!
                            cheers, bdream
                              andyyy @sdetweil
                              I tried it again. Now the electron does not even start.
                              sh: 1: ./node_modules/.bin/electron: not found
                              I tried to re-install electron with "sudo npm install electron@latest
                              ", but no change.
                                sdetweil @bdream
                                @bdream so you need to go to the
                                MMM-DWD-Pollen folder and do
                                npm install request --save
                                  bdream @sdetweil
                                  @sdetweil I did it but don’t know what to do with these messages :face_with_rolling_eyes:
                                  pi@MagicMirror:~/MagicMirror/modules/MMM-DWD-Pollen $  npm install request --save
                                  npm WARN EBADENGINE Unsupported engine { package: 'magicmirror@2.16.0',
                                  npm WARN EBADENGINE   required: { node: '>=12' },
                                  npm WARN EBADENGINE   current: { node: 'v10.23.1', npm: '7.15.1' } }
                                  npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jsdoc@35.4.0',
                                  npm WARN EBADENGINE Unsupported engine { package: 'jsdoc-type-pratt-parser@1.0.4',
                                  npm WARN EBADENGINE   required: { node: '>=12.0.0' },
                                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                  added 628 packages, and audited 921 packages in 12m
                                  110 packages are looking for funding
                                    run `npm fund` for details
                                  found 0 vulnerabilities
                                  cheers, bdream
                                    andyyy @sdetweil
                                    I got electron installed again with specifying a version (sudo npm install electron@6.1.12). No idea, why electron disappeared in the first place.
                                    @Fozi
                                    The MMM-MyCalender has indeed an issue with 2.16. causing a black screen. And MMM-Fuel is saying “undefined” for an unknown reason. Both modules are disabled for now.
                                    My MM boots and shows the all other modules again.
                                    With each MM update something crashes, mostly one of the 3rd party modules because one or more dependencies are lost/changed or deleted.
                                    Thanks for your help. Great community!
                                      sdetweil @andyyy
                                      @andyyy yeh, version 2.1.6 is on electron 11.4.9
                                        sdetweil @andyyy
                                        @andyyy i see you have npm version 7 installed… causes quite a few problems…
                                        I would fall back to npm 6
                                        A 2 Replies Last reply Reply Quote 0
                                          andyyy @sdetweil
                                          How do I revert to npm v6?
                                            sdetweil @andyyy
                                            @andyyy sudo npm install -g npm@6.14.3
                                            you will then have to cleanup from 7
                                            rm -rf node_modules
                                            npm install
                                            u may have to do the same in any module folder with a package.json file
