    Building an Image Module.
    10 Posts 2 Posters 8.7k Views 2 Watching
    • shadymapleS Offline
      shadymaple
      Hi everyone, we have the MagicMirror up and running, and we’ve modified a little bit, by adding our own Text and included an ESPN rss feed as well. We’d like to add an image (school logo) to our mirror. Where can I find information - quite specific information - that would show us how to build an image module? We’ve tried a few things already, but have not had success. Thanks, hope someone can assist.
      Re: Displaying a Black and White .png Image
      shadymapleS 1 Reply Last reply Reply Quote 0
        shadymaple @shadymaple
        @shadymaple I should add, that I did try the GitHub thing, added the Logo image and even added that to our Raspberry-Pi - I see the folder in the MagicMirror area.
        LukeCodewalkerL 1 Reply Last reply Reply Quote 0
        • LukeCodewalkerL Offline
          LukeCodewalker Module Developer @shadymaple
          @shadymaple
          You could just use my module and put the path of your image in the “ownImagePath” value of the config. It’s explained in the README but if you need help, let me now.
          [card:LukeSkywalker92/MMM-Globe]
          shadymapleS 1 Reply Last reply Reply Quote 1
            shadymaple
            Thanks, we tried that, we did get your image to display, but when we placed our image in the ownImagePath, we would just get three lines around the border of the image (left, right, bottom). Not sure…I will try attaching a picture as well to show you.
              shadymaple
                shadymaple @LukeCodewalker
                  @shadymaple
                  Could you please try to comment out line 61 of MMM-Globe.js and tell me if it works then?
                    shadymaple
                    To comment out, I did the ¨//¨ before that line, correct? If so, it now shows the outline of my image, but image doesn´t load. Is that maybe a GitHub issue for me - maybe I did that wrong? This part of my code in the config.js is:
                    	 module: 'MMM-Globe',
                    	 position: 'center',
                        		style: 'geoColor',
                        		imageSize: 300,
                        		ownImagePath:'https://github.com/ddzurko/Mirror/blob/master/Gear.png',
                        		updateInterval: 10*60*1000
                      @shadymaple
                      ok now i got the problem.
                      can you please update the module. To do that just type git pullin the module directory (…/modules/MMM-Globe/). And in your config file you have to change your path to https://github.com/ddzurko/Mirror/blob/master/Gear.png?raw=true.
                      Then it should work.
                        shadymaple
