    Update from 2.15 to 2.16
    35 Posts 5 Posters 15.2k Views 5 Watching
      bdream @sdetweil
      @sdetweil I did it but don’t know what to do with these messages :face_with_rolling_eyes:
      pi@MagicMirror:~/MagicMirror/modules/MMM-DWD-Pollen $  npm install request --save
      npm WARN EBADENGINE Unsupported engine { package: 'magicmirror@2.16.0',
      npm WARN EBADENGINE   required: { node: '>=12' },
      npm WARN EBADENGINE   current: { node: 'v10.23.1', npm: '7.15.1' } }
      npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jsdoc@35.4.0',
      npm WARN EBADENGINE Unsupported engine { package: 'jsdoc-type-pratt-parser@1.0.4',
      npm WARN EBADENGINE   required: { node: '>=12.0.0' },
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      added 628 packages, and audited 921 packages in 12m
      110 packages are looking for funding
        run `npm fund` for details
      found 0 vulnerabilities
      cheers, bdream
        andyyy @sdetweil
        I got electron installed again with specifying a version (sudo npm install electron@6.1.12). No idea, why electron disappeared in the first place.
        @Fozi
        The MMM-MyCalender has indeed an issue with 2.16. causing a black screen. And MMM-Fuel is saying “undefined” for an unknown reason. Both modules are disabled for now.
        My MM boots and shows the all other modules again.
        With each MM update something crashes, mostly one of the 3rd party modules because one or more dependencies are lost/changed or deleted.
        Thanks for your help. Great community!
          sdetweil @andyyy
          @andyyy yeh, version 2.1.6 is on electron 11.4.9
            sdetweil @andyyy
            @andyyy i see you have npm version 7 installed… causes quite a few problems…
            I would fall back to npm 6
            A 2 Replies Last reply Reply Quote 0
              andyyy @sdetweil
              How do I revert to npm v6?
                sdetweil @andyyy
                @andyyy sudo npm install -g npm@6.14.3
                you will then have to cleanup from 7
                rm -rf node_modules
                npm install
                u may have to do the same in any module folder with a package.json file
                  andyyy @sdetweil
                  made it with npm install -g npm@6.14.14.
                  I still have issues with the default wheater module. The old “currentweather” module works but new default “weather” module just says “loading”.
                    sdetweil @andyyy
                    @andyyy I would look in the window where u start mm
                    npm start or pm2
                    if pm2, the pm2 logs --lines=100
                    for any messages
                    loading is the default output til data arrives.
                    so it didn’t get the content from the api
                    is that forecast u are waiting for?
                    there is a timing issue, workaround with setting
                    (look it up for exact spelling)
                    initialLoadDelay:100
                      andyyy @sdetweil
                      I screwed up my MM entirely. pm2 crashed randomly for an unkown reason.
                      When did “npm intall” on all modules after the update to 2.16, mostly npm complaints about some vulnerabilites. So I did “npm audit fix” on all them all. Maybe some dependencies broke rather than being fixed.
                      Another thing; npm complaint that 2.16 is uncompatible with node 10.x and npm version. So upgraded both to the latest one.
                      Mostly like all that ruined my MM.
                      Thus, I loaded back last working backup and just did “npm install” on all modules. Npm is still complaints about the node version, but all module run except MMM-MyCalender which seems to be uncompatible with 2.16.
                        sdetweil @andyyy
                        @andyyy don’t run audit fix… ever… makes more of a mess than it fixes
                        what is the problem with MyCalendar?
                        • karsten13K Offline
                          karsten13 @sdetweil
                          @sdetweil no package.json and requesting valid-url …
                            sdetweil @karsten13
                            @karsten13 fun times!
                              sdetweil @andyyy
                              @andyyy valid-url was removed in 2.16 as the library it uses was also removed…
                              but you can add it back for this module
                              cd ~/MagicMirror/modules/MMM-MyCalendar
                              npm init
                              hit enter thru the prompts
                              npm install valid-url --save
                              the author should fix the module, but many authors are no longer maintaining their modules
                                andyyy @sdetweil
                                Thx, after fixing this the next lib is missing. I just give up using that module.
                                I have a vision for the future MM development. All modules should run in a separate container/sandbox or capasulated/isolated somehow. So when they fail for whatever reason, the MM stays alive and reporting a specific error message.
                                Don’t get me wrong I highly appreciate the work/effort of michmich and his team.
                                  sdetweil @andyyy
                                  @andyyy i think that MM should fail when a module fails and make it easier to find
