    Update from 2.15 to 2.16
    35 Posts 5 Posters 15.0k Views 5 Watching
      sdetweil @bdream
      @bdream no. u are probably missing some modules that mm removed
      read the startup messages
      npm start
      or
      if using pm2
      pm2 logs --lines=100
      • FoziF Offline
        Fozi Project Sponsor @bdream
        @bdream I strongly guess that one of the 3rd party modules is not compatible vith MM2.16.0. I had the same issues with MMM-MyCalendar, which caused a black screen after starting MM. My approach is to disable all 3rd party modules by adding the line
        disabled: true;
        for each module and enable it one after the other by setting it to
        disabled: false;
        Taht might discover quicker, which module is the culprit instead of poking in logs (that is my personal approach!).
        When you found the module, that causes issues, contact the developer on github, or look for an alternative fork which seems to be maintained.
        Regarding the above mentioned MMM-MyCalendar module, I reverted to the default calendar module, which works just fine and delivers the same features.
          sdetweil @Fozi
          @fozi come on, this is easy. get the messages. it will tell you which lib to install
            bdream @sdetweil
            @sdetweil okay, I’m going to try with messages.
            pi@MagicMirror:~ $ pm2 logs --lines=100
            0|mm       | Require stack:
            0|mm       | - /home/pi/MagicMirror/modules/MMM-DWD-Pollen/node_helper.js
            0|mm       | - /home/pi/MagicMirror/js/app.js
            0|mm       | - /home/pi/MagicMirror/js/electron.js
            0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
            0|mm       | -
            0|mm       |     at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
            0|mm       |     at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
            0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
            0|mm       |     at Module._load (internal/modules/cjs/loader.js:848:27)
            0|mm       |     at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
            0|mm       |     at Module.require (internal/modules/cjs/loader.js:1032:19)
            0|mm       |     at require (internal/modules/cjs/helpers.js:72:18)
            0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DWD-Pollen/node_helper.js:7:15)
            0|mm       |     at Module._compile (internal/modules/cjs/loader.js:1152:30)
            0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
            0|mm       | [31.07.2021 03:30.08.854] [ERROR] Whoops! There was an uncaught exception...
            0|mm       | [31.07.2021 03:30.08.865] [ERROR] Error: Cannot find module 'request'
            0|mm       | -
            0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10) {
            0|mm       |   code: 'MODULE_NOT_FOUND',
            0|mm       |   requireStack: [
            0|mm       |     '/home/pi/MagicMirror/modules/MMM-DWD-Pollen/node_helper.js',
            0|mm       |     '/home/pi/MagicMirror/js/app.js',
            0|mm       |     '/home/pi/MagicMirror/js/electron.js',
            0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
            0|mm       |     undefined
            0|mm       |   ]
            0|mm       | }
            0|mm       | [31.07.2021 03:30.08.868] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|mm       | [31.07.2021 03:30.08.869] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            0|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
            0|mm       | [02.08.2021 08:40.08.979] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
            0|mm       | -
            0|mm       | [02.08.2021 08:40.09.001] [ERROR] App threw an error during load
            0|mm       | [02.08.2021 08:40.09.005] [ERROR] Error: Cannot find module 'request'
            0|mm       | -
            0|mm       | [02.08.2021 08:40.09.007] [ERROR] Whoops! There was an uncaught exception...
            0|mm       | [02.08.2021 08:40.09.018] [ERROR] Error: Cannot find module 'request'
            0|mm       | -
            0|mm       |     undefined
            0|mm       |   ]
            0|mm       | }
            0|mm       | [02.08.2021 08:40.09.021] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|mm       | [02.08.2021 08:40.09.022] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            0|mm       |
            0|mm       | > magicmirror@2.16.0 start
            0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
            0|mm       |
            0|mm       | [30.07.2021 03:30.08.295] [LOG]   Starting MagicMirror: v2.16.0
            0|mm       | [30.07.2021 03:30.08.304] [LOG]   Loading config ...
            So it looks to me as MMM-DWD-Pollen will be the problem.
            That is faster, than going with disabled: true; and disabled: false; over all my modules :crossed_fingers: even it was a guess with the related module to me.
            @Fozi now i have to see how to deal with your statement “When you found the module, that causes issues, contact the developer on github, or look for an alternative fork which seems to be maintained.”
            Comment out this module in config and it works again.
            Many thanks for your fast help!!!
            cheers, bdream
              andyyy @sdetweil
              I tried it again. Now the electron does not even start.
              sh: 1: ./node_modules/.bin/electron: not found
              I tried to re-install electron with "sudo npm install electron@latest
              ", but no change.
                sdetweil @bdream
                @bdream so you need to go to the
                MMM-DWD-Pollen folder and do
                npm install request --save
                  bdream @sdetweil
                  @sdetweil I did it but don’t know what to do with these messages :face_with_rolling_eyes:
                  pi@MagicMirror:~/MagicMirror/modules/MMM-DWD-Pollen $  npm install request --save
                  npm WARN EBADENGINE Unsupported engine { package: 'magicmirror@2.16.0',
                  npm WARN EBADENGINE   required: { node: '>=12' },
                  npm WARN EBADENGINE   current: { node: 'v10.23.1', npm: '7.15.1' } }
                  npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jsdoc@35.4.0',
                  npm WARN EBADENGINE Unsupported engine { package: 'jsdoc-type-pratt-parser@1.0.4',
                  npm WARN EBADENGINE   required: { node: '>=12.0.0' },
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  added 628 packages, and audited 921 packages in 12m
                  110 packages are looking for funding
                    run `npm fund` for details
                  found 0 vulnerabilities
                  cheers, bdream
                    andyyy @sdetweil
                    I got electron installed again with specifying a version (sudo npm install electron@6.1.12). No idea, why electron disappeared in the first place.
                    @Fozi
                    The MMM-MyCalender has indeed an issue with 2.16. causing a black screen. And MMM-Fuel is saying “undefined” for an unknown reason. Both modules are disabled for now.
                    My MM boots and shows the all other modules again.
                    With each MM update something crashes, mostly one of the 3rd party modules because one or more dependencies are lost/changed or deleted.
                    Thanks for your help. Great community!
                      sdetweil @andyyy
                      @andyyy yeh, version 2.1.6 is on electron 11.4.9
                        sdetweil @andyyy
                        @andyyy i see you have npm version 7 installed… causes quite a few problems…
                        I would fall back to npm 6
                        A 2 Replies Last reply Reply Quote 0
                          andyyy @sdetweil
                          How do I revert to npm v6?
                            sdetweil @andyyy
                            @andyyy sudo npm install -g npm@6.14.3
                            you will then have to cleanup from 7
                            rm -rf node_modules
                            npm install
                            u may have to do the same in any module folder with a package.json file
                              andyyy @sdetweil
                              made it with npm install -g npm@6.14.14.
                              I still have issues with the default wheater module. The old “currentweather” module works but new default “weather” module just says “loading”.
                                sdetweil @andyyy
                                @andyyy I would look in the window where u start mm
                                npm start or pm2
                                if pm2, the pm2 logs --lines=100
                                for any messages
                                loading is the default output til data arrives.
                                so it didn’t get the content from the api
                                is that forecast u are waiting for?
                                there is a timing issue, workaround with setting
                                (look it up for exact spelling)
                                initialLoadDelay:100
                                  andyyy @sdetweil
                                  I screwed up my MM entirely. pm2 crashed randomly for an unkown reason.
                                  When did “npm intall” on all modules after the update to 2.16, mostly npm complaints about some vulnerabilites. So I did “npm audit fix” on all them all. Maybe some dependencies broke rather than being fixed.
                                  Another thing; npm complaint that 2.16 is uncompatible with node 10.x and npm version. So upgraded both to the latest one.
                                  Mostly like all that ruined my MM.
                                  Thus, I loaded back last working backup and just did “npm install” on all modules. Npm is still complaints about the node version, but all module run except MMM-MyCalender which seems to be uncompatible with 2.16.
                                    sdetweil @andyyy
                                    @andyyy don’t run audit fix… ever… makes more of a mess than it fixes
                                    what is the problem with MyCalendar?
                                    • karsten13K Offline
                                      karsten13 @sdetweil
                                      @sdetweil no package.json and requesting valid-url …
                                        sdetweil @karsten13
                                        @karsten13 fun times!
                                          sdetweil @andyyy
                                          @andyyy valid-url was removed in 2.16 as the library it uses was also removed…
                                          but you can add it back for this module
                                          cd ~/MagicMirror/modules/MMM-MyCalendar
                                          npm init
                                          hit enter thru the prompts
                                          npm install valid-url --save
                                          the author should fix the module, but many authors are no longer maintaining their modules
                                            andyyy @sdetweil
                                            Thx, after fixing this the next lib is missing. I just give up using that module.
                                            I have a vision for the future MM development. All modules should run in a separate container/sandbox or capasulated/isolated somehow. So when they fail for whatever reason, the MM stays alive and reporting a specific error message.
                                            Don’t get me wrong I highly appreciate the work/effort of michmich and his team.
