    Background is white?
    18 Posts 3 Posters 5.1k Views 3 Watching
      martaaay
      I just installed a fresh copy of the ready to go Raspberry Pi image. It booted great on a mini monitor I have and looked right. But, when I hooked it into a 55" monitor, the little modules have a black background around them, but everywhere else is white. Any idea what could be causing this? It looks like it’s white anywhere a module has not explicitly written over pixels.
        sdetweil @martaaay
        @martaaay sounds like a bad cable or hmdi port
          martaaay @sdetweil
          @sdetweil Hmm, interesting. The linux bootup sequence seems to work just fine though. Then the screen goes white with a mouse cursor briefly in the middle. The mouse cursor disappears and then I have a white background with little black blocks containing things like the time and news. Is that still sounding like it could be a cable issue?
          I attached a pic to see if that helps with my description. ![0_1630008747296_IMG_7512_2.jpg](Uploading 100%)
            martaaay @martaaay
            Hmm, uploading not working. Trying this:alt text
              sdetweil @martaaay
              @martaaay what does the raspi desktop look like? the temple?
              • BKeyportB Offline
                BKeyport Module Developer
                For whatever reason, the screen is getting the initial white fill, then not getting the blanking as MM runs.
                I personally wonder what would happen if a full screen background module was used - example, https://github.com/darickc/MMM-BackgroundSlideshow
                  sdetweil @BKeyport
                  @bkeyport I wonder if electron thinks its a b&w display
                    martaaay @BKeyport
                    @sdetweil Sorry my ignorance - is there an easy way to boot to just the raspberry pi desktop?
                    @BKeyport I tried adding MMM-EasyBack, and used this config with the default background image. It seems to cause it to boot sometimes into an all white screen and stay that way, and sometimes it boots into my weird white background with some items in the foreground, but no background. So odd!
                    Is there a log for errors somewhere?
                      martaaay @sdetweil
                      @sdetweil FWIW on the B&W issue, I used MMM-EasyBack with a youtubeid, and the youtube video appeared, though only taking part of the screen with white behind the elements as before. The youtube video had color in it, IIRC.
                      I think I’ve sufficiently messed things up tinkering around. Haha. I’m going to reflash this sd card and try again.
                        sdetweil @martaaay
                        @martaaay use my install script…
                        see https://github.com/sdetweil/MagicMirror_scripts
                          martaaay @sdetweil
                          @sdetweil Is that intended to be run from a fresh Raspbian install?
                            sdetweil @martaaay
                            @martaaay said in Background is white?:
                            just alt-spacebar, n
                            to minimize MM after startup
                            then u can open a terminal window (ctrl-alt-t)
                            and pm2 stop all
                              sdetweil @martaaay
                              @martaaay yes, altho u can rename the MM folder to something else and install again
                                martaaay @sdetweil
                                @sdetweil Ah ok, so would you prefer I install fresh Raspian instead of this: http://unofficialpi.org/Distros/MagicMirrorOS/ ?
                                (hehe, any chance somebody can bump my account reputation so i can post faster than 120s :) )
                                  sdetweil @martaaay
                                  @martaaay i don’t do MMOS, so I don’t know…
                                    martaaay @sdetweil
                                    @sdetweil I’ll go ahead with a fresh latest stable Raspian and use your script. Will take me a bit. Thanks for the help so far!
                                      martaaay @martaaay
                                      I verified that the raspberry pi desktop boots up and looks fine
                                        martaaay @martaaay
                                        @sdetweil Thanks for that script! I started from fresh Raspian, ran you script, and now this looks like it’s working far better.
