    Duplicate Modules w Different CSS
    11 Posts 2 Posters 3.4k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @sdetweil
      @sdetweil This about duplicate modules and how to address them in config.js file. On my two calendar modules, how do I distinguish between the first and second modules in the config when module name is the same. The CSS name as you described above didn’t fly. The first module getRelative: 0,works as described but it is using the default getRelative: 6,in the second module
        sdetweil @ankonaskiff17
        @ankonaskiff17 use the module identifier
        look in the dev window, elements tab, and select the modules 1 at a time and see their identifier , use #id in custom.css
        note if u add/remove modules before this one, its ID will change
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          @sdetweil Are you saying to use that identifier in the config file too. I did that and it made the second module disappear.
          I replaced module: 'calendar', with module: 'module_2_calendar',
          This is the line in Developer Tools
          <div id="module_2_calendar" class="module calendar calendar"
            @ankonaskiff17 no. only in custom.css
            identifier is created by mm
              @ankonaskiff17 right, so #module_2_calendar
                @sdetweil You want me to start as new topic since it relates to config?
                  @ankonaskiff17 n
                  custom.css entry
                  #module_2_calendar  {
                    background-color:lightblue;
                  sorry, I had used my cal identifier
                  changed to yours
