    Duplicate Modules w Different CSS
    11 Posts 2 Posters 3.5k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      When reusing a module, in this case the default weather module, how do you apply unique CSS to each one separately?
      I can see same thing arising with the default calendar module.
        sdetweil @ankonaskiff17
        @ankonaskiff17 use the module identifier as the selector instead of the module name
        u can look in the developer window, elements tab, to locate the ‘position’ and then the module
        identifiers will be stable top down in config.js
        ankonaskiff17A 1 Reply Last reply Reply Quote 1
          ankonaskiff17 @sdetweil
          @sdetweil module_3_weather.module.weather and module_4_weather.module.weather would be what I would use to distinguish between the two in my css?
            @ankonaskiff17 module_3_weather
            is enough
            with dot in front, as it’s a class
            ankonaskiff17A 1 Reply Last reply Reply Quote 0
              @sdetweil This about duplicate modules and how to address them in config.js file. On my two calendar modules, how do I distinguish between the first and second modules in the config when module name is the same. The CSS name as you described above didn’t fly. The first module getRelative: 0,works as described but it is using the default getRelative: 6,in the second module
                look in the dev window, elements tab, and select the modules 1 at a time and see their identifier , use #id in custom.css
                note if u add/remove modules before this one, its ID will change
                  @sdetweil Are you saying to use that identifier in the config file too. I did that and it made the second module disappear.
                  I replaced module: 'calendar', with module: 'module_2_calendar',
                  This is the line in Developer Tools
                  <div id="module_2_calendar" class="module calendar calendar"
                    @ankonaskiff17 no. only in custom.css
                    identifier is created by mm
                      @ankonaskiff17 right, so #module_2_calendar
                        @sdetweil You want me to start as new topic since it relates to config?
                          @ankonaskiff17 n
                          custom.css entry
                          #module_2_calendar  {
                            background-color:lightblue;
                          sorry, I had used my cal identifier
                          changed to yours
