    MMM-weatherchart sdetweil fork
    18 Posts 2 Posters 6.3k Views 2 Watching
      sdetweil @MajorC
      @majorc said in MMM-weatherchart sdetweil fork:
      customiseSVG: true, // change colours in hex values or “default” for no change
      background_colour: “#666666”,
      those parms are not used by the module…
      u will probably have to fiddle with css…
      the http:// address thing looks like u set a property in config.js
      these are the ones the module uses
      		country: 'Germany',
      		area: 'North_Rhine-Westphalia',
      		city: 'Duisburg',
      		updateInterval: 60 * 60 * 1000, // every hour
      		hideBorder: true,
      		negativeImage: true,
      		retryDelay: 2500,
      		domain: "www.yr.no",
      		path: "/place/",
      		mmDirectory: "/home/pi/MagicMirror/", // not sure whether it is possible to ask MM for this path?
      		hoursToShow: -1
      I’m guessing domain is the one u changed
      M 1 Reply Last reply
        MajorC Project Sponsor @sdetweil
        @sdetweil thank you.
        I cleaned up my configuration. Only MMM-weatherchart is in.
        			module: 'mmm-weatherchart',
        			position: 'bottom_right', // this can be any of the regions
        				country: 'Germany', // as determined above
        				area: 'Berlin', // as determined above
        				city: 'Berlin', // as determined above
        				updateInterval: 60 * 60 * 1000, // update every hour
        				hideBorder: true, // whether or not a border with city name should be shown
        				negativeImage: true, // whether or not the default white image should be inverted
        				retryDelay: 2500,
        				path: "/place/",
        				hoursToShow: 24
        the error message is:
        undefined:1 GET http://192.168.2.16:8080/undefined 404 (Not Found)
        I don’t know how I can provide better information to solve this?!?
        M S 2 Replies Last reply
          MajorC Project Sponsor @MajorC
          I would like to open this topic again.
          The error:
          is still present. Any advise is highly appreciated.
            sdetweil @MajorC
            @majorc where do u see that error? npm start or developers window?
              @sdetweil where is your mm installed? (path from root)
                I see the error in the developers window in google chrome if I connect remotely to the pi.
                /home/pi/MagicMirror is correct for my setup.
                  sdetweil @MajorC
                  @majorc the code tries to build the url from these settings
                  var mapLocal = this.config.path + this.config.country + "/" + this.config.area + "/" + this.config.city + "/meteogram.png";
                  the defaults are
                  		country: 'Germany',
                  		city: 'Duisburg',
                  		path: "/place/",
                  no spaces allowed in any
                    that is my config:
                    				negativeImage: false, // whether or not the default white image should be inverted
                    				retryDelay: 2500,
                    				path: "/place/",
                    				hoursToShow: 36
                    Ich wechsle mal kurz ins Deutsche. Das interessante ist, dass mir die Grafik auch angezeigt wird. Also gefühlt läuft der Code ohne Fehler. Mich wundert nur die Fehlermeldung, die in Chrome, wenn ich mich remote auf den Pi/MM einwähle, kommt. Als ob er noch irgend was versucht abzurufen, was nicht gefunden werden kann.
                      sdetweil @MajorC
                      @majorc das Interessante ist die Adresse
                      192.168.2.16 MUSS in Ihrem lokalen Netzwerk sein und ist vielleicht die Adresse des PI. Der Code versucht, Dinge auf der ned_helper-Seite zwischenzuspeichern, und ich weiß nicht, wie diese Informationen verwendet werden.
                        @sdetweil you are right. 192.168.2.16 is the IP adress of my PI.
                          sdetweil @MajorC
                          @majorc I’ll try to look at the code . busy this week, gone next
                            @sdetweil No problem. In principle, it works, too.
                              Hi @sdetweil
                              on the MM the widget says, that the forecast is being replaced by a new one. I think the url need to be changed.
                              Can you have a look on that?
                              https://developer.yr.no/doc/guides/deprecating-old-widgets/
                              Christian
                                sdetweil @MajorC
                                @majorc sorry, I don’t know anything about the module workings. I just tried to help out with the install problem
                                I think this module has been abandoned by it’s author.
                                  @sdetweil I see. Well, I opened an issue on GitHub, maybe something happend.
