    Any plan to replace "request" and "moment"?
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    61 Posts 8 Posters 42.7k Views 8 Watching
    • BKeyportB
      I give up.
      Suggestion for the main app -
      Create a date-time service that hides what library you’re using. If you decide to replace the library in the future, you’ll need to update only one file.
      That way, we don’t have to move at all - just convert from accessing moment directly to accessing the internal service.
      In the meantime, I’m indeed dropping it.
        sdetweil @BKeyport
        @bkeyport I don’t understand dropping the library…
        sadly its never that easy. code has to change.
        as for the other.
        can u do all you app in the browser side (module name.js)
        if so then u load the new moment library with
        npm install --save libname
        and then (check syntax)
        getScripts:
          return [ this.file("node_modules/libname/....")]
             // the file is whatever would be in the script tag
        of u need to use node_helper, and need moment like stuff,
        const ???? = require('libname')
        if u need both, then u have to do both
        BKeyportB 1 Reply Last reply
        • BKeyportB
          Dropping it = Not going to bother until I have to.
          mumblebajM 1 Reply Last reply
          • mumblebajM
            mumblebaj Module Developer @BKeyport
            EDIT: Reference path to luxon.min.js
            @bkeyport I think the following should work for you.
            Add luxon.min.js to your project in the root of your project.
            Then add the following to you project, I have used your MMM-Multimonth as an example project.
            getScripts: function() {
                          return[this.file("/node_modules/luxon/build/global/luxon.min.js")]
            Once added you should be able to use it like this:
            In your project you have the following for moment:
            monthTitle = moment().add(-1, "month").format("MMMM YYYY")
            You an now do the following in luxon:
            const luxMonth = luxon.DateTime.now().plus({month: -1}).toFormat("MMMM yyyy")
            Hope this gives you a start in the right direction.
            You can find luxon.min.js here
              sdetweil @mumblebaj
              @mumblebaj don’t copy the file to the root of your module. just use it from the linstalled location.
              • mumblebajM
                @sdetweil I have now found it in the /node_modules/luxon/build/global
                I should have searched some more. :beaming_face_with_smiling_eyes:
                But, yes, you are correct. You can just point to that location.
                • BKeyportB
                  BKeyport Module Developer @mumblebaj
                  @mumblebaj Yeah, I got irritated enough that it wasn’t working I realized I was being a total idiot and not pointing at the JS correctly. Why the hell it’s buried so deep, well…
                    sdetweil @BKeyport
                    @bkeyport
                    why is it buried so deep?
                    cause everybody does their own thing
                    • BKeyportB
                      @sdetweil heh.
                      Now, I’m down to the javascript exploding bug. A <= B == Crash. 😢
                      Oh well. Shelved.
                      I’ll tackle it when/if the main switches.
                      mumblebajM 2 Replies Last reply
                      • mumblebajM
                        @bkeyport You doing date comparison?
                        • mumblebajM
                          @bkeyport Can you adapt the following and see if it works for you?
                          var startDate = DateTime.fromISO("2021-09-06T17:22:49.916+02:00");
                          var someDate = DateTime.fromISO("2021-03-06T17:22:49.916+02:00");
                          var result = startDate.startOf("day") <= someDate.startOf("day");
                          console.log("Date Comparison Result: ", result) // => true;
                          • BKeyportB
                            @mumblebaj I’ll play with it later, We’ve hijacked the thread enough.
                            • 3 / 4
