    Magic mirror MMM-Google Assistant issue.
    7 Posts 3 Posters 2.7k Views 3 Watching
    • F
      Faizan
      I add the google assistant module and then run the magic mirror and shown the google assistant popup and error. I need help[ urgently. Thanks
      and the second module in mic error like this.
        DJBOOB66
        mic error
        what guide did you use if the one from youtube is outdated for v2 use v3 http://wiki.bugsounet.fr/en/MMM-GoogleAssistant
        F 1 Reply Last reply
        • F
          Faizan @DJBOOB66
          @djboob66 Now tell me a solution please
            DJBOOB66
            Did you install using Bugsounet Google assistant Wiki???
            • F
              Faizan @DJBOOB66
              @djboob66 yes but not work
                DJBOOB66
                Have you got any other module that uses a mic?
                Did you add MMM-Detector?
                Is your config right?
                Are you using a USB mic?
                Do you get errors when the mirror starts in terminal?
                bugsounetB 1 Reply Last reply
                • bugsounetB
                  bugsounet Banned @DJBOOB66
                  1. GA is installed, right and perfect
                  2. Mic Error is NOT from GA or Detector
                  @Faizan Now tell me a solution please
                  1. we are not responsible that what you install!
                  2. we are not at your service!
                  3. Thank you for telling us otherwise!
                  So, don’t count on our help anymore
                  You take too much advantage of our kindness!
                  Good luck to you …
                  @bugsounet
