    I can't get the config to open
    7 Posts 3 Posters 3.8k Views 3 Watching
      DarthMosh
      I have the program installed, I went through thee complete setup guide, but now I don’t know how to open the config to change the weather, location, etc. I have already changed the file in the config folder to config.js.
        AAPS
        I have had the same problem. Was it necessary to change the file in the config folder to config.js? I never saw that in the tutorial. That might be exactly what I have been missing.
          AAPS
          Try going here: https://github.com/MichMich/MagicMirror/wiki#default-modules
          There is a complete guide to what to do. Click on one of the default modules to learn how to set it up. I am new to all of this, but I hope this helps.
            DarthMosh
            I might have solved the issue. I’m supposed to change the script in the folder not from the terminal aren’t I?
              AAPS
              That must have been it. I’ll take that into consideration.
              • impuislupusI Offline
                impuislupus
                so im stuck as well… so im clear we need 2 config files in the config folder? one being the one we have to edit and one being the orginal… as well if we throw in a module does that also has to be in the config …i ask cause my sytem is not detecting any config files. and.where do i download jslint from… sorry very new to this followed instruction to the T
                  AAPS
                  I am also very new to this, but it isn’t that hard once you’ve stay up till 1:00 3 or 4 times. Everything I needed to know was here: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6 @KirAsh4
                  The section you probably need is under “Installing MirrorMirror2” at the end.
                  I was able to do everything from the forum until I needed to change the weather settings. For that, I used file manager. It isn’t as hard as it may seem (even though to a newbie like me all of this stuff seems hard). After a long time just playing around with it I finally got the MagicMirror2 app set up with autostart, which has a tutorial at: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                  I hope this helps. I know how it feels to have no clue of what to do.
