    add request to modules
    8 Posts 3 Posters 3.1k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      Appears that two modules I’m using are dead because of “request”
      How do we add it back into the affected modules?
      (MMM-CalendarExt2 and MMM-SystemStats, FWIW)
      BKeyportB S 2 Replies Last reply Reply Quote 0
      • BKeyportB Offline
        Nevermind, I got it figured out.
        npm install request in the directory after the regular npm install.
        Likely gonna have to keep doing it, though. :|
          sdetweil @BKeyport
          @bkeyport said in add request to modules:
          in the module folder
          if the module does NOT have a package.json file do
          npm init -y
          and then for all cases do
          npm install request -- save
            the module author should add an updated package.json to the module
            And migrate to something else
            also
            rrule-alt
            valid-url
            • BKeyportB Offline
              @sdetweil I have a feeling the update isn’t gonna happen in either of those modules… :)
              I’d love someone to come up with a better CX2, tho… 😉😉😉
                bert269
                My is totally messed up now too, after the upgrade from 2.16.
                Blank screen.
                I tried the upgrade script with “force” but it’s still the same.
                THANKS!
                  sdetweil @bert269
                  @bert269 show the errors where you do npm start
                  if you use pm2, then do
                  pm2 logs --lines=100
                  • BKeyportB Offline
                    BKeyport Module Developer @bert269
                    @bert269 It’s likely a missing required piece, like it was for me.
                    take a look at logs.
                    if using PM2, I suggest multiple terminal windows to your system, then on one:
                    pm2 logs and the other pm2 restart MagicMirror (or other name that you use for MagicMirror)
                    • BKeyportB BKeyport referenced this topic on
