    [MMM-PushBulletNotifications] Push stream error: Error: certificate has expired
    6 Posts 2 Posters 1.5k Views 2 Watching
    • Cr4z33C Offline
      Cr4z33
      Since a couple of days the module wasn’t showing new notifications.
      Giving a look at the terminal it now displays
      [2021-10-02 15:43:21.294] [LOG] [MMM-PushBulletNotifications][Error] 15:43:21.294 - Push stream error: Error: certificate has expired
      Does anybody know please how to sort it out?
        sdetweil @Cr4z33
        @cr4z33 install 2.17.1 which has a fix for this
        see last post in
        https://forum.magicmirror.builders/topic/15662/v2-17-0
        Cr4z33C 1 Reply Last reply Reply Quote 1
        • Cr4z33C Offline
          Cr4z33 @sdetweil
          @sdetweil thank you, but I am worried it might screw up my modules.
          I haven’t updated since like 2 years or so. 😅
            sdetweil @Cr4z33
            @cr4z33 fun times. make a copy of the folder, use my upgrade script.
            • Cr4z33C Offline
              Cr4z33 @sdetweil
              @sdetweil thanks it’s been a while since last time I made something to my MM, but I surely will do it tomorrow with your script!
                sdetweil @Cr4z33
                @cr4z33 my upgrade script is a two pass thing
                1. test the upgrade, without making any changes. let u know if there are files that would block it. give u opportunity to resolve them
                2. actually DO the upgrade. because electron and other things are changing, I also run thru all the modules with package.json files and redo the npm install there (or npm upgrade if they provide one)
                I do NOT git pull for modules
                note that in 2.16 (last release) we removed some deprecated libraries. many modules didn’t document that they were used so we get black screen problems.
                my upgrade does not test for that.
