    Rotating IR-Frame
    8 Posts 5 Posters 2.0k Views 5 Watching
    • F Offline
      fordi @Bender352
      • F Offline
        fordi @Bender352
        @bender352
        Hi there, thank you for assisting. Here you go!
        Realised the image I was trying to send before was far too big, so have made it smaller.
        There are slot of spaces in the name. Why can’t the manufacturer keep it simple? When I copy paste the text spaces are removed in this forum so i sent a photo.
          Bender352 @fordi
          @fordi
          you could try to reference to you IR-Fram via the ID (instead of the device name). But in case you change the USB port it my change so you also have to change the ID number in your script.
          try this
          xinput set-prop 6 --type=float "Coordinate Transformation Matrix" 0 1 0 -1 0 1 0 0 1
          • F Offline
            fordi @Bender352
            @bender352 that’s kind of you thank you. So sorry for the delayed reply!!
            • E Offline
              elatt @Bender352
              @bender352 late reply but whenever I try to make it executable it tells me
              chmod: cannot access ‘/home/pi/startup_scripts/portrait.sh’ : No such file or directory
              I completed all the steps but wondering if I’m missing something
