    Alexa to Selfie
    5 Posts 2 Posters 1.0k Views 3 Watching
      Alyx
      Hi Guys,
      I’m quite new to magic mirror and would be considered new to Linux also.
      I’ve been playing around with modules and I llove the work that out but the documentation is hard to understand my my level. I want to control MMM-SelfieShoot with MMM-AlexaControl.
      I was able to work out the default start stop PM2 process for the Magic Mirror bur I dont know how to incorporate new notifications. Also I kinda broke the config file while playing around but sure thats the fun of it all I suppose.
      Any help would be great I’ve been quite some time with this!
      Please see below for my configs.
      MAagicMirror config
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/getting-started/configuration.html#general
       * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	locale: "en-UK",
      	timeFormat: 12,
      	units: "metric",
              disabled: false,
              module: 'MMM-Astro',
              position: 'top_left',
      		      sign: "leo",
      		      iconset: "4",
      		      extend: false,
              module: 'MMM-AlexaControl',
              position: 'middle_center',
              config:{
                  image: false,
                  pm2ProcessName: "Smart_Mirror",
                  monitorToggle: true,
                  vcgencmd: "hide",
                  deviceName: "Smart Mirror"
          module: 'MMM-SleepWake',
          config:{
             mode: 'DPMS'
          module: "MMM-MotionDetector",
             captureIntervalTime: 1000,
          	scoreThreshold: 20,
          	timeout: 12
      	disabled: false,
      	module: "MMM-Selfieshot",
      	storePath: "./Storage/Photos",
      	width:1280,
      	height:720,
      	quality: 100,
      	device: null,
      	shootMessage: "Smile!",
      	shootCountdown: 3,
      	displayCountdown: true,
      	displayResult: true,
      	playShutter: true,
      	shutterSound: "shutter.mp3",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_center"
        		module: "MMM-OpenWeatherMapForecast",
        		header: "Weather",
        		classes: "default everyone",
        		disabled: false,
          			apikey: "f,
          			latitude: "
          			iconset: "4c",
          			units: "metric",
          			useAnimatedIcons: true,
          			concise: false,
          			forecastLayout: "table",
          			showWind: true
      MMM-AlexaControl config
       * Magic Mirror
       * Module: MMM-AlexaControl
       * By JoChef2
       * MIT Licensed.
      Module.register("MMM-AlexaControl",{
          defaults:{
              image: true,    //  shows the image
              height: 265,    // heigth of the image
              width: 265,     // width of the image
              pages: 0,       //  number off pages in MMM-Pages module. 0 means you doesn't use it
              devices: {      //  empty object for your custom devices
                  devices: []
              notifications: [
              port: 11100,
              OnOff: false,
              notification: [this.sendNotification("SELFIE_SHOOT")]
          //  empty array for your notification devices
              commands: [this.sendNotification("SELFIE_SHOOT")],       // empty array for your command devices
              startPort: 11000,   //  the lowest used port
              refresh: false,      //  refresh your Mirror
              restart: false,
              selfie: true,      //  restart your Mirror with pm2
              stop: false,         //  stops your Mirror with pm2
              reboot: false,      //  reboot your pi
              shutdown: false,    //  shutdown your pi
              pm2ProcessName: "Selfie",  //  name of your pm2 process
              monitorToggle: false,   //  switch your monitor on and off
              vcgencmd: 'vcgencmd',  //  command you use for monitor toggle
              cecAddress: "0.0.0.0", //  Address for the cec-client
              usb: false          // toggle usb power of your pi
          getTranslations: function(){            // add more translations
              return {
                  en: "translations/en.json",
                  de: "translations/de.json"
          start: function(){
              Log.log('Starting module: ' + this.name);
              // send all translations to node_helper
              this.sendSocketNotification('TRANSLATIONS', {"monitor": this.translate("MONITOR"), "shutdown": this.translate("SHUTDOWN"), "reboot": this.translate("REBOOT"), "page": this.translate("PAGE"), "refresh": this.translate("REFRESH"), "restart": this.translate("RESTART"), "stop": this.translate("STOP"), "selfie": this.translate("SELFIE_SHOOT"), "usb": this.translate("USB"), "deviceName":this.translate(this.config.deviceName)});
              this.sendSocketNotification('SET_DEVICE', this.config);  // send the config to node_helper
          getDom: function(){             // returns only an image or an empty div (necessary for MMM-Pages)
              if(this.config.image){
                  let img = document.createElement("img");
                  img.classList = "img";
                  img.src = "MMM-AlexaControl/AlexaLogoGrey.png";
                  img.height = this.config.height;
                  img.width = this.config.width;
                  return img;
              }else{
                  return document.createElement("div");
              if(notification === "PAGE_CHANGED"){              //  change pages of MMM-Pages
                  this.sendNotification("PAGE_CHANGED", payload);
              if(notification === "ACTION"){                    //  refresh the Mirror
                  if(payload === "refresh"){
                      window.location.reload(true);
              if(notification === "selfie"){
                  this.sendNotification("SELFIE_SHOOT");  //  send any notification to any module
              if(notification =='MONITOR_ACTION'){
                  Log.log('RECEIVE monitor NOTIFICATION='+payload)
                  this.sendNotification(notification,payload)
        sdetweil @Alyx
        @alyx 1st NEVER edit the module source.
        all config goes in config.js, for every module
        anything in config.js will replace the same item in the module defaults section
        for config syntax. see
        https://forum.magicmirror.builders/topic/15743/no-javascript-experience-config-js-not-working/16?_=1634583021802
        to diagnose errors
        in the MagicMirror folder do
        npm run config:check
        repeat til no errors…(see the step above about syntax)
          @Alyx
          for AC
                  notifications: [
                  port: 11100,
                  OnOff: false,
          in config.js
          u put JUST THE TEXT and data for the notification
                  notifications: [
                  port: 11100,
                  OnOff: false,
                  notification: ["SELFIE_SHOOT", ""]
          A 1 Reply Last reply Reply Quote 1
            Alyx @sdetweil
            @sdetweil Yes I did try that but it was when my source script for the alexa module was tampered with. I’ll give it another shot and let you guys know how it goes!
              Alyx
              @sdetweil Sound advise I’ll be sure to remember it! Honeslty makes thing easier too I hate having to edit scripts to communicate to each other in other forms of development haha
