    Running on Pi Zero 2 W?
    25 Posts 9 Posters 14.4k Views 11 Watching
    • U Offline
      undeterred @sdetweil
      @sdetweil Be interesting to read about your experience on installing on the pi0w-2.
      I have a small 4" magicmirror displaying one module at a time using the pi0w. The animations are sometimes laggy however, hence my interest at upgrading the hardware.
      Thanks.
        musson @undeterred
        @undeterred I am trying to get it working, just got my pi zero w2 today. doesn’t work using the lite version of pi, trying the desktop version now. Not sure I fully understand how chromium is supposed to be installed by the script.
          sdetweil @musson
          @musson chromium is installed on the full desktop (which is required because the browser draws graphics)
          but the script only sets up for chromium if the electron install fails(sometimes on x86) , or is not available…(armv6l)
          this should be same as pi3…(armv7l)
            sdetweil @musson
            @musson mm never works with lite version
            from the doc , under requirements
            NOTE
            To run Electron, you need a desktop environment.
            Using a Lite Version of Raspbian will not work.
              musson @sdetweil
              @sdetweil ok, trying desktop now.
                sdetweil @musson
                @musson mine doesnt come til tuesday
                  musson
                  At one point I had MagicMirror working on a lite version, I installed X11 and Chromium but when Electron updated and needed a node.js version that didn’t work on the arm6 CPU I gave up and used a pi 4.
                  I want to free up the pi 4 and am hoping I can use the new pi zero 2w for MagicMirror.
                    sdetweil @musson
                    @musson said in Running on Pi Zero 2 W?:
                    well, thats not lite really!..
                    reports are its 5x faster than pi 0… same as pi 3
                    don’t remember how much memory on board…
                    make sure to increase the swap space…
                    and maybe run off a USB SSD (I boot most of mine from sd card, but run from ssd…
                    TGW (Total Gigabytes Written, measure of SSD memory capacity usage) on micro SD is pretty low
                      musson @sdetweil
                      @sdetweil Its working with the desktop version!!!
                      Thanks for you help and comments.
                        SmartReflectons @undeterred
                        @undeterred I should receive mine next week and look forward to building a mirror to check performance.
