    Running on Pi Zero 2 W?
    25 Posts 9 Posters 16.6k Views 11 Watching
    • karsten13K Offline
      karsten13 @sdetweil
      @sdetweil said in Running on Pi Zero 2 W?:
      as addition: pi zero 2 is armv7l
      nice article: https://blog.alexellis.io/raspberry-pi-zero-2/
      • U Offline
        undeterred @sdetweil
        @sdetweil Be interesting to read about your experience on installing on the pi0w-2.
        I have a small 4" magicmirror displaying one module at a time using the pi0w. The animations are sometimes laggy however, hence my interest at upgrading the hardware.
        Thanks.
          musson @undeterred
          @undeterred I am trying to get it working, just got my pi zero w2 today. doesn’t work using the lite version of pi, trying the desktop version now. Not sure I fully understand how chromium is supposed to be installed by the script.
            sdetweil @musson
            @musson chromium is installed on the full desktop (which is required because the browser draws graphics)
            but the script only sets up for chromium if the electron install fails(sometimes on x86) , or is not available…(armv6l)
            this should be same as pi3…(armv7l)
              sdetweil @musson
              @musson mm never works with lite version
              from the doc , under requirements
              NOTE
              To run Electron, you need a desktop environment.
              Using a Lite Version of Raspbian will not work.
                musson @sdetweil
                @sdetweil ok, trying desktop now.
                  sdetweil @musson
                  @musson mine doesnt come til tuesday
                    musson
                    At one point I had MagicMirror working on a lite version, I installed X11 and Chromium but when Electron updated and needed a node.js version that didn’t work on the arm6 CPU I gave up and used a pi 4.
                    I want to free up the pi 4 and am hoping I can use the new pi zero 2w for MagicMirror.
                      sdetweil @musson
                      @musson said in Running on Pi Zero 2 W?:
                      well, thats not lite really!..
                      reports are its 5x faster than pi 0… same as pi 3
                      don’t remember how much memory on board…
                      make sure to increase the swap space…
                      and maybe run off a USB SSD (I boot most of mine from sd card, but run from ssd…
                      TGW (Total Gigabytes Written, measure of SSD memory capacity usage) on micro SD is pretty low
                        musson @sdetweil
                        @sdetweil Its working with the desktop version!!!
                        Thanks for you help and comments.
                          SmartReflectons @undeterred
                          @undeterred I should receive mine next week and look forward to building a mirror to check performance.
                            musson @SmartReflectons
                            @smartreflectons Its quite responsive.
                              great power analysis of pi2w
                              https://hackaday.com/2021/11/01/the-pi-zero-2-w-is-the-most-efficient-pi/
                                actually PI os 64 bit now shows aarch64, as does ubuntu on pi. (and jetson nano as I recall)…
                                • L Offline
                                  Lofty73
                                  I am running it a Pi Zero 2W and it seems ok
                                  New to the Magic mirror scene so still learning but up and running on an old 19" toshiba TV
                                    sdetweil @Lofty73
                                    @lofty73 got mine today, unplugged the pi 0w, and moved the sd card over… up we run…
                                    installed electron (cause it wasn’t on the armv6)
                                    and runs nice…
                                    pretty low cpu usage
                                      MajorC Project Sponsor @sdetweil
                                      @sdetweil Thank you for the test. I ordered one today after I read your post!
                                        sdetweil @MajorC
                                        @majorc another benchmark report
                                        https://medium.com/@ghalfacree/benchmarking-the-raspberry-pi-zero-2-w-b868accdbb50
                                          karsten13 @sdetweil
                                          my pi zero 2w was delivered today and I’m really surprised about the good performance.
                                          Tested 2 apps:
                                          • mm as docker setup
                                          • motioneye with google drive upload (also docker)
                                          Both worked out of the box and felt not slower as on my old pi 3b.
                                            sdetweil @karsten13
                                            @karsten13 memory is a little slower than PI3b… but not too terrible
                                            see benchmarks from prior post
