    Motion Detector
    213 Posts 38 Posters 584.2k Views 39 Watching
      DirkS
      @bib you are providing a bit less information to give you some tipp.
      B 2 Replies Last reply
        bibi @DirkS
        @DirkS ok here you go. 1st: when the Pi is started the screen directly goes into sleep. it’s a bit annoying but i can live with that as i will not reboot it everyday. 2nd: to wake up the system with a motion during this sleep mode, it takes quite a while (don’t know why) 3rd: when motion is detected, screen wakes up and stays up accordingly the time defined in config.js and goes sleep again (this is fine) but suddently it wakes up again without motion and this last behavior is unpredictable. i hope it’s enough info for you but don’t hesitate to ask more if needed. thx
        moreover your script is i guess different from the one of this pull…
        B 1 Reply Last reply
          bibi @bibi
          @DirkS and i see now after few hours, it won’t wake up anymore :(
            bibi @DirkS
            @DirkS forget my last posts… i restarted (reinstall MM) everything and i m trying to figure out how to avoid the black screen now…
              chrisvanlaar
              C 1 Reply Last reply
                chrisvanlaar @chrisvanlaar
                @chrisvanlaar said in Motion Detector:
                After reading here the motion works on my MM.
                Now ik want to go out of the sleep mode when a new mail or i get a phonecall. (it reads from my Fritzbox).
                Can i build in this option also? or is it better in the phone/mail module.
                Chris
                I mean that i have the camera module connected to my PI3. In the /boot/config.txt i had the (@reboot sudo modprobe bcm2835-v4l2 ) and it works! :-)
                Chris
                • A
                  alexyak
                  Hi All,
                  I’ve revamped the motiondetector module to use a more optimised code to detect the motion from the web camera. The old one was performing very poorly. The new code works many times better. Just pull the latest from
                  https://github.com/alexyak/motiondetector
                  • Alex
                  • T
                    trividar
                    Hi Alex,
                    thank you so much for your work! Unfortunately my MM start with a black screen after the update. I tried to reboot my Raspi but it didn’t help. Should I make a npm install after the update?
                    THX
                    • T
                      trividar
                      and this is the error:
                      error
                      A 1 Reply Last reply
                      • A
                        alexyak @trividar
                        @trividar My apologies. This should be fixed. Just pull the latest.
                        • T
                          trividar
                          @alexyak Now my MM start. But after awhile (2 min) i got this error and my MM freeze:
                          alt text
                          I disabled the DHT module but than i got this error:
                          alt text
                          Do you have also a solution for this? THX a lot!
                          • A
                            alexyak @trividar
                            @trividar I don’t see anything related to the motiondetector in your logs. It seems the error coming from the mmm-systemperature/node_helper.js
                            • T
                              trividar
                              I disabled mmm-systemperature and now I have no errors on my log but after first deactivation of the monitor my raspberry freeze completely. Before the pull everything works perfekt beside DHT, now nothing works ;o( strange…
                              J 1 Reply Last reply
                                jdahli1 @trividar
                                @trividar I’m having a similar issue. My mirror will turn on and off a few times, but after a few minutes it will peg the RAM and completely lock up the pi. Not sure what to try next.
                                in_a_daysI 1 Reply Last reply
                                • in_a_daysI
                                  in_a_days @jdahli1
                                  @jdahli1
                                  I have also experienced something similar, always while running under a heavy load. Are you running a lot of modules, or anything that is very intensive? Some tasks like video streaming are incredibly demanding on the CPU.
                                  My working solution was to modify my module selection so I’m not overworking the processor, and to increase the ‘updateInterval’ in my SystemStats section of config.js. Maybe try 15000 or 20000ms, see if it the crash occurs less often. I also run WatchDog and it would register the SystemStats failure. I don’t see WatchDog in these logs so this may not apply, but I also added increased ‘interval’ and ‘timeout’ settings to config.js. I have not seen this SystemStats crash for quite a while.
                                  FWIW - after this crash WatchDog/pm2 does NOT restart my mm shell. All the other failures auto-restart, but something about this one crashes to the desktop. Also - sorry for threadjacking a “Motion Detection” thread!
                                  • T
                                    trividar
                                    I tried to increase the updateInterval to 200000ms and disabled all other modules, but always after the second time the monitor turn off my raspberry freeze completely and I have to reboot. My CPU is around 9 -15% when they freeze. I try again with the old version oft he motion-detector and it works, not perfect but works.
                                      jdahli1 @in_a_days
                                      @in_a_days I guess I do run more modules than what “fit” the screen, but they’re cool and I can’t make up my mind which ones I want to keep lol.
                                      However, I don’t believe that is the issue here. I have disabled all but three modules and still face the same issue. The second time the screen goes to sleep, it will not wake up. It doesn’t seem to matter what the CPU load or RAM is at.
                                      Watching the pm2 logs, I get an uncaught exception error when the screen is supposed to wake up, but that is all the details I get from it. (That I know how to see, still new to this)
                                      • in_a_daysI
                                        in_a_days @jdahli1
                                        @jdahli1
                                        Unfortunately, I’m pretty new too!
                                        To update - my mirror would still freeze (though it might take a couple hours) even after the changes I suggested. For me, the last error before the crash ALWAYS comes from the system status module (same exact ENOMEM error from the @trividar post). With the sys stat module disabled, I seem to be crash free. May not be the same thing you’re experiencing.
                                        I also removed Watchdog after reading a bit more about it’s purpose.
                                        If you are able to copy the log file from your most recent crash, someone smarter than me may be able to help.
                                        M 1 Reply Last reply
                                          mydiva @in_a_days
                                          @in_a_days how did you disabled sys stat module? and what is that? by the way I have the same thing happen like @trividar
                                          • in_a_daysI
                                            in_a_days @mydiva
                                            @mydiva
                                            The system stat module I’m referring to is this one.
                                            https://github.com/BenRoe/MMM-SystemStats
                                            It would have to be specifically installed by the user. But looking at the screenshot from @trividar, there are a couple different modules throwing up errors. These couple lines show the modules that appear to be crashing the system:
                                            You can see mmm-systemtemperature and MMM-DHT22 producing error events. I would start by commenting out these modules. Just add a
                                            before and a
                                            after the section of your config.js file that loads these modules. If that eliminates the crashing you can be confident it is these modules causing the problem, and you can either try to fix them or look for alternatives.
                                            EDIT: The common theme between my error and the error posted here is the ENOMEM code, and the fact that all these modules are measuring system temperature. MMM-SystemStats, mmm-systemtemperature, and MMM-DHT22 are all reading temperatures. I would be willing to bet there’s a bug or memory leak somewhere in the code that is pulling or logging temperature info. I’m not convinced any of these particular errors are related to the Motion Detector module.
                                            • 10
                                            • 11
                                            • 7 / 11
