    Monthly Calendar
    43 Posts 24 Posters 59.3k Views 24 Watching
      mirrX
      Is this module still working? I´ve set up a new system and the MM gives me an error and can´t start with this module. I have uploaded in the correct dir and also set up the config file correctly. But it won´t work.
        pjkoeleman @mirrX
        @mirrX said in Monthly Calendar:
        Mine is, so have a look at your config and check for errors
        • slametpsS
          slametps
          Mine is also with bug. It is not working well for new month. The calendar not showing nor highlight the 1st date. So, I must restart MM to make it works.
          regards,
          Slamet PS
          • N
            Novais
            Having an issue displaying the calendar. Got the config set properly as far as i can tell just using the defaults and i have confirmed the config doesn’t contain any errors but the monthly calendar wont display, MM does start up with the other modules.
              Jonae @slametps
              @slametps i have the same issue, calendar not refreshing at month start. no fix jet?
              • BKeyportB
                BKeyport Module Developer @Jonae
                @jonae I had so many problems I wrote my own version. mmm-multimonth
                  Jonae @BKeyport
                  @bkeyport said in Monthly Calendar:
                  mmm-multimonth
                  thanks, i will try that.
                    Jonae @BKeyport
                    @bkeyport
                    Thanks for the tip, it is perfect, exactly what i need! i hope at the and of the month it will change :)
                    • BKeyportB
                      @jonae It’s been working perfectly for me for months. There’s been a couple of quirks, but I’m re-writing it from scratch to eliminate some underpinnings that are difficult. Please, let me know if it continues to work for you.
                        Jonae @BKeyport
                        @bkeyport It is working perfectly so far, I modified it to my liking, I love it, it should replace the calendar monthly by default! I hope you succeed with the rewriting of the code. Can you give me the official GitHub? I want to follow you for updates! Many thanks.
                        • BKeyportB
                          @jonae I’m not github’ing the partial product. once I adapt the concept from jsfiddle to magic mirror, I’ll establish a develop branch
                            Jonae @BKeyport
                            @bkeyport Great!
                            • 3 / 3
