    Module Regions - Tutorial Requested
    9 Posts 4 Posters 7.0k Views 3 Watching
    • V Offline
      valid8r @mochman
      @mochman Thanks, I had/have that link and it is useful. I am trying to understand the way in which main.css defines the regions and how that structure actually works. I’m new to .css and find the code hard to understand. How for example are the horizontal dimensions set for a given region?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @valid8r
        @valid8r a couple of regions as you can see on the picture have full width and the others are generic
        they are placed with top, left, right and bottom properties and position: absolute on the screen
        • V Offline
          valid8r @strawberry 3.141
          @strawberry-3.141 If my questions get to be too frustrating, please feel free to say so and I will stop. So from this thread, how would I know what the right hand border size of a .top.left region was (in other words, how wide is the region)? The code I think from main.css for this is I believe the followingn, but it only defines the top for these regions is 100% of top, what are the width or border dimensions…?
          .region.top.right,
          .region.top.left,
          .region.top.center {
          top: 100%;
          • brobergB Offline
            broberg Project Sponsor
            They have no defined size per say,
            add
            outline: #fff solid;
            to all .regions, that will give you a sense of how they look.
            V 1 Reply Last reply Reply Quote 1
            • V Offline
              valid8r @broberg
              @broberg Thanks, will do so, but I don’t understand how they can not have a defined size??? how does that work? For example, I have calendar (.top.left), Advent (.top.center) and Weather (.top.right)… however, the default sizes of each region/module are not equal thirds… trying to understand this.
              • brobergB Offline
                broberg Project Sponsor @valid8r
                @valid8r they expand, adapting to the content of the
                They only need positioning and orientation.
                all
                without size constrains will adapt to it’s content and the
                or body it’s placed in.
                You can certainly add width and height constrains to the regions if you feel like it.
                The thing with
                is you can basically place them anywhere you want to, make them any size, make them lay over or under other
                and so on and so on.
                • V Offline
                  valid8r @broberg
                  @broberg Interesting… I didn’t know about
                  and am now reading up on it. Thanks for pointing me in the right direction that explains a lot. I’ll try to read up on this before asking any more questions!
