MMM-PublicTransportBerlin only displays "Loading..."
7 Posts 3 Posters 959 Views 3 Watching
  • K Offline
    kai
    Hi there,
    the MMM-PublicTransportBerlin module doesn’t update anymore since yesterday (last shown departure times at “my” station were 13:34).
    I restarted my mirror’s Raspi, and I changed the module’s configuration to see if other stations (station IDs) might work but no success. After the restart the module only displays “Loading…”; the update interval is set to 2 minutes. (Both my mirror and all its other modules are up to date and work fine.)
    I checked the BVG-rest API documentation as well as the REST API itself - it works fine using a playground like swagger. Hence it’s obviously not their problem, but mine… ;-)
    Does anybody currently have a similar problem and/or any ideas?
    Any hints appreciated. Thanks a lot.
    May the code be with you
    -kai
    M 1 Reply Last reply Nov 12, 2021, 9:53 AM Reply Quote 0
      sdetweil @kai
      @kai said in MMM-PublicTransportBerlin only displays "Loading...":
      Do I just need to delete the config part and the corresponding directory within the “modules” directory?
      yes and yes
        MZ-BER @kai
        Hi @kai - just want to tell you, that the module works for me perfectly. It update as requested (2min). My station ID is 900000140005.
        Are you sure that the your Raspi is connected to your internet? I had a similar issue a long time ago and noticed that my Wifi was down.
        • K Offline
          kai
          Hi @MZ-BER,
          thanks a lot for the hint. I checked the connection (it’s a wired connection); it’s up and running.
          Maybe I should completely remove the module and re-install it…
          Does anyone know how to remove a module?
          Thank you very much.
          -kai
          S 1 Reply Last reply Nov 12, 2021, 6:30 PM Reply Quote 0
            sdetweil @kai
            yes and yes
            • K Offline
              kai
              …re-install succeeded! I can see the departure dates again. :beaming_face_with_smiling_eyes:
              Thank you @MZ-BER and @sdetweil!
              (How do I add the nice “solved” icon to this issue?)
              -kai
              S 1 Reply Last reply Nov 12, 2021, 7:01 PM Reply Quote 0
                sdetweil @kai
                @kai click the 3 dots to the right on the post that ‘solved’ the issue and click mark this…
                • K Offline
                  kai
                  …thank you very much, @sdetweil :clapping_hands_light_skin_tone:
