    MMM-PublicTransportBerlin only displays "Loading..."
    7 Posts 3 Posters 1.6k Views 3 Watching
    • kaiK Offline
      kai
      Hi @MZ-BER,
      thanks a lot for the hint. I checked the connection (it’s a wired connection); it’s up and running.
      Maybe I should completely remove the module and re-install it…
      Does anyone know how to remove a module?
      Do I just need to delete the config part and the corresponding directory within the “modules” directory?
      Thank you very much.
      May the code be with you
      -kai
        sdetweil @kai
        @kai said in MMM-PublicTransportBerlin only displays "Loading...":
        yes and yes
        • kaiK Offline
          kai
          …re-install succeeded! I can see the departure dates again. :beaming_face_with_smiling_eyes:
          Thank you @MZ-BER and @sdetweil!
          (How do I add the nice “solved” icon to this issue?)
          -kai
            sdetweil @kai
            @kai click the 3 dots to the right on the post that ‘solved’ the issue and click mark this…
            • kaiK Offline
              kai
              …thank you very much, @sdetweil :clapping_hands_light_skin_tone:
