    Calendar events showing on wrong day.
    66 Posts 3 Posters 36.9k Views 3 Watching
      sdetweil @Coolie1101
      @coolie1101 do you have the current version of the vevent? as that one expired in 2019, and has no repeating rule
      but when I adjusted to this year and nov 21
      BEGIN:VEVENT
      DTSTART:20211121T100000Z
      DTEND:20211121T150000Z
      DTSTAMP:20211119T124216Z
      UID:6h0hrr7t2gr6qopifribble@google.com
      RECURRENCE-ID:20191112T100000Z
      CREATED:20211026T075843Z
      DESCRIPTION:
      LAST-MODIFIED:20211026T080254Z
      SEQUENCE:1
      STATUS:CONFIRMED
      SUMMARY:YARD WASTE
      TRANSP:OPAQUE
      END:VEVENT
      i see the right display
      [19.11.2021 07:40.05.433] [DEBUG] startDate (local): Sun Nov 21 2021 04:00:00 GMT-0600 (Central Standard Time)
      [19.11.2021 07:40.05.433] [DEBUG] endDate (local): Sun Nov 21 2021 09:00:00 GMT-0600 (Central Standard Time)
      as there is no timezone associated with that time. and I am CST
      Coolie1101C 1 Reply Last reply
      • Coolie1101C
        Coolie1101 @sdetweil
        @sdetweil Yes, see below.
        BEGIN:VEVENT
        DTSTART;TZID=America/New_York:20210406T050000
        DTEND;TZID=America/New_York:20210406T100000
        RRULE:FREQ=WEEKLY;WKST=SU;UNTIL=20211230T045959Z;BYDAY=TU
        UID:0v89h5cit8nq6m************@google.com
        DESCRIPTION:
        SEQUENCE:1
        STATUS:CONFIRMED
        SUMMARY:YARD WASTE
        TRANSP:OPAQUE
        END:VEVENT
        I can share that calendar with you if it makes it easier for you to test.
        S 2 Replies Last reply
          @coolie1101 said in Calendar events showing on wrong day.:
          no, i just create an ics file… easy cut/paste
          • Coolie1101C
            @sdetweil said in Calendar events showing on wrong day.:
            npm start >somefile.txt
            What is this suppose to do?, seems something is missing from the command.
              @coolie1101 it directs the output of the command (npm start) to a file (somefile.txt)
              this is normal file output redirection, same as on windows
              the normal MM startup output looks like this
              > magicmirror@2.17.1 start /home/sam/MagicMirror
              [19.11.2021 07:50.19.980] [LOG]   Starting MagicMirror: v2.17.1
              [19.11.2021 07:50.19.981] [LOG]   Loading config ...
              [19.11.2021 07:50.19.982] [LOG]   Loading module helpers ...
              [19.11.2021 07:50.19.982] [LOG]   trying to load module=alert
              [19.11.2021 07:50.19.982] [LOG]   No helper found for module: alert.
              [19.11.2021 07:50.19.982] [LOG]   trying to load module=MMM-Tools
              [19.11.2021 07:50.19.999] [LOG]   Initializing new module helper ...
              [19.11.2021 07:50.19.999] [LOG]   Module helper loaded: MMM-Tools
              [19.11.2021 07:50.19.999] [LOG]   trying to load module=updatenotification
              [19.11.2021 07:50.20.000] [LOG]   Initializing new module helper ...
              [19.11.2021 07:50.20.000] [LOG]   Module helper loaded: updatenotification
              [19.11.2021 07:50.20.000] [LOG]   trying to load module=clock
              etc
                @coolie1101 after copying your new cal entry to ics, and running… it looks good to me…
                (with the edited calendarutils.js) (I am central US time)
                this ics with the other persons info in too
                Coolie1101C 2 Replies Last reply
                • Coolie1101C
                  @sdetweil Maybe I’m executing it in the wrong order, do i need to “pm2 start mm” and then do “npm start >somefile.txt”? eitherway, there isn’t error log entries for calendar.
                  0|mm  | [19.11.2021 08:55.52.292] [LOG]
                  0|mm  | Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 900000
                  0|mm  | [19.11.2021 08:55.52.362] [LOG]
                  0|mm  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/p07n98go11onam************%40group.calendar.google.com/public/basic.ics - Interval: 900000
                  0|mm  | [19.11.2021 08:55.52.434] [LOG]
                  0|mm  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/olrn3c2sf2k023************%40group.calendar.google.com/private-7d055c9f2a8b6bbfe674************/basic.ics - Interval: 900000
                  0|mm  | [19.11.2021 08:55.52.448] [LOG]
                  0|mm  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/mvdgcjroualavv************%40group.calendar.google.com/public/basic.ics - Interval: 900000
                  Calendar Display
                    @coolie1101 you cant run with pm2 AND with npm start
                    so, thats why I said
                    pm2 stop all
                    THEN (in the MagicMirror folder)
                    npm start
                    • Coolie1101C
                      Don’t sleep much :grinning_face:
                        Don’t sleep much
                        its past 8am… been up since 6 (cat wakes me reliably)
                        • Coolie1101C
                          pm2 stop all
                          npm start
                          Got it, I edited the “calendarutils.js” file again and restarted, no error or calendar entries in log, but the display is the same.
                            @coolie1101 weird
                            edit config.js and change
                            	logLevel: ["INFO", "LOG", "WARN", "ERROR"]
                            to
                            this
                            	logLevel: ["INFO", "LOG", "WARN","ERROR","DEBUG"]
                            and run again, then u will see the calendar processing
                              @coolie1101 and a reminder, there are TWO sections of code u have to comment out
                              two areas of two lines each
                              • Coolie1101C
                                @sdetweil Yes.
                                Line 348 & 358
                                //								if (event.start.tz === moment.tz.guess()) {
                                									// if the date hour is less than the offset
                                									if (24 - dh < Math.abs(dateoffset / 60)) {
                                										// apply the correction to the date/time back to right day
                                										date = new Date(date.getTime() + Math.abs(24 * 60) * 60000);
                                										// the duration was calculated way back at the top before we could correct the start time..
                                										// fix it for this event entry
                                										//duration = 24 * 60 * 60 * 1000;
                                										Log.debug("new recurring date2 is " + date);
                                Line 376 & 386
                                • Coolie1101C
                                  Will it work like this “npm start >cal_test_log.txt | grep calendar”?
                                    no…
                                    something like this (couple debug lines added for my testing)
                                    [19.11.2021 07:50.24.603] [DEBUG] Processing entry...
                                    Event: {"type":"VEVENT","params":[],"start":"2021-04-06T09:00:00.000Z","datetype":"date-time","end":"2021-04-06T14:00:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2021-04-06T09:00:00.000Z","freq":2,"wkst":{"weekday":6},"until":"2021-12-30T04:59:59.000Z","byweekday":[{"weekday":1}]},"options":{"freq":2,"dtstart":"2021-04-06T09:00:00.000Z","interval":1,"wkst":6,"count":null,"until":"2021-12-30T04:59:59.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[1],"bynweekday":null,"byhour":[9],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2021-11-19T12:42:16.000Z","uid":"0v89h5cit8nq6mfribble@google.com","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"1","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}
                                    [19.11.2021 07:50.24.603] [DEBUG] startDate (local): Tue Apr 06 2021 04:00:00 GMT-0500 (Central Daylight Time)
                                    [19.11.2021 07:50.24.603] [DEBUG] endDate (local): Tue Apr 06 2021 09:00:00 GMT-0500 (Central Daylight Time)
                                    [19.11.2021 07:50.24.604] [DEBUG] duration: 18000000
                                    [19.11.2021 07:50.24.604] [DEBUG] title: YARD WASTE
                                    [19.11.2021 07:50.24.604] [DEBUG] Search for recurring events between: Fri Nov 19 2021 07:50:24 GMT-0600 (Central Standard Time) and Fri Nov 18 2022 23:59:59 GMT-0600 (Central Standard Time)
                                    [19.11.2021 07:50.24.605] [DEBUG] Title: YARD WASTE, with dates: ["2021-11-23T09:00:00.000Z","2021-11-30T09:00:00.000Z","2021-12-07T09:00:00.000Z","2021-12-14T09:00:00.000Z","2021-12-21T09:00:00.000Z","2021-12-28T09:00:00.000Z"]
                                    [19.11.2021 07:50.24.605] [DEBUG] event.recurrences: undefined
                                    [19.11.2021 07:50.24.605] [DEBUG]  recurring date is Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time) offset is 360
                                    [19.11.2021 07:50.24.605] [DEBUG]  recurring date is Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time) offset is 6 Hour is 03
                                    [19.11.2021 07:50.24.606] [DEBUG] not full day
                                    [19.11.2021 07:50.24.606] [DEBUG] offset positive
                                    [19.11.2021 07:50.24.606] [DEBUG] Corrected startDate (local): Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time)
                                    [19.11.2021 07:50.24.606] [DEBUG] initial tz=America/New_York
                                    [19.11.2021 07:50.24.606] [DEBUG] corrected tz=America/New_York
                                    [19.11.2021 07:50.24.606] [DEBUG] start date/time=Tue Apr 06 2021 04:00:00 GMT-0500 (Central Daylight Time)
                                    [19.11.2021 07:50.24.606] [DEBUG] start offset=-240
                                    [19.11.2021 07:50.24.606] [DEBUG] start date/time w tz =Tue Apr 06 2021 04:00:00 GMT-0500 (Central Daylight Time)
                                    [19.11.2021 07:50.24.606] [DEBUG] event date=Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time)
                                    [19.11.2021 07:50.24.606] [DEBUG] event offset=-300 hour=4 event date=Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time)
                                    [19.11.2021 07:50.24.606] [DEBUG] adjust up 1 hour dst change
                                    [19.11.2021 07:50.24.606] [DEBUG] adjustHours=1
                                    [19.11.2021 07:50.24.606] [DEBUG] duration: 18000000
                                    [19.11.2021 07:50.24.607] [DEBUG] saving event: false
                                    • Coolie1101C
                                      @sdetweil It’s running, how long should I wait before checking the output file?, as there is no output in the ssh window.
                                        @coolie1101 til the calendar comes up with the wrong displayed info
                                        then ctrl-c to end
                                        • Coolie1101C
                                          @sdetweil Here’s the out in the file.
                                          > magicmirror@2.17.1 start /home/pi/MagicMirror
                                          [19.11.2021 09:42.53.017] [LOG]   Starting MagicMirror: v2.17.1
                                          [19.11.2021 09:42.53.028] [LOG]   Loading config ...
                                          [19.11.2021 09:42.53.041] [LOG]   Loading module helpers ...
                                          [19.11.2021 09:42.53.456] [LOG]   Initializing new module helper ...
                                          [19.11.2021 09:42.53.458] [LOG]   Module helper loaded: MMM-Remote-Control
                                          [19.11.2021 09:42.53.461] [LOG]   No helper found for module: alert.
                                          [19.11.2021 09:42.53.469] [LOG]   Initializing new module helper ...
                                          [19.11.2021 09:42.53.471] [LOG]   Module helper loaded: updatenotification
                                          [19.11.2021 09:42.53.472] [LOG]   No helper found for module: clock.
                                          [19.11.2021 09:42.53.782] [LOG]   Initializing new module helper ...
                                          [19.11.2021 09:42.53.784] [LOG]   Module helper loaded: calendar
                                          [19.11.2021 09:42.55.195] [LOG]   Initializing new module helper ...
                                          [19.11.2021 09:42.55.196] [LOG]   Module helper loaded: MMM-TelegramBot
                                          [19.11.2021 09:42.55.203] [LOG]   Initializing new module helper ...
                                          [19.11.2021 09:42.55.204] [LOG]   Module helper loaded: MMM-Detector
                                          [19.11.2021 09:42.55.987] [LOG]   Initializing new module helper ...
                                          [19.11.2021 09:42.55.997] [LOG]   Module helper loaded: MMM-GoogleAssistant
                                          [19.11.2021 09:42.55.999] [LOG]   No helper found for module: MMM-JokeAPI.
                                          [19.11.2021 09:42.56.001] [LOG]   No helper found for module: weather.
                                          [19.11.2021 09:42.56.181] [LOG]   Initializing new module helper ...
                                          [19.11.2021 09:42.56.183] [LOG]   Module helper loaded: MMM-Tools
                                          [19.11.2021 09:42.56.900] [LOG]   Initializing new module helper ...
                                          [19.11.2021 09:42.56.902] [LOG]   Module helper loaded: MMM-MotionDisplay
                                          [19.11.2021 09:42.56.955] [LOG]   Initializing new module helper ...
                                          [19.11.2021 09:42.56.957] [LOG]   Module helper loaded: newsfeed
                                          [19.11.2021 09:42.56.958] [LOG]   All module helpers loaded.
                                          [19.11.2021 09:42.57.123] [LOG]   Starting server on port 8080 ...
                                          [19.11.2021 09:42.57.139] [LOG]   Server started ...
                                          [19.11.2021 09:42.57.142] [LOG]   Connecting socket for: MMM-Remote-Control
                                          [19.11.2021 09:42.57.144] [LOG]   Starting node helper for: MMM-Remote-Control
                                          [19.11.2021 09:42.57.157] [LOG]   Connecting socket for: updatenotification
                                          [19.11.2021 09:42.57.159] [LOG]   Connecting socket for: calendar
                                          [19.11.2021 09:42.57.161] [LOG]   Starting node helper for: calendar
                                          [19.11.2021 09:42.57.163] [LOG]   Connecting socket for: MMM-TelegramBot
                                            @coolie1101 there should be lots more
                                            I only need to see the processing of that one cal entry
                                            • 2 / 4
