    Calendar events showing on wrong day.
    66 Posts 3 Posters 35.2k Views 3 Watching
    • Coolie1101C Offline
      Coolie1101 @sdetweil
      @sdetweil It’s running, how long should I wait before checking the output file?, as there is no output in the ssh window.
        sdetweil @Coolie1101
        @coolie1101 til the calendar comes up with the wrong displayed info
        then ctrl-c to end
        Coolie1101C 1 Reply Last reply Reply Quote 0
          @sdetweil Here’s the out in the file.
          > magicmirror@2.17.1 start /home/pi/MagicMirror
          [19.11.2021 09:42.53.017] [LOG]   Starting MagicMirror: v2.17.1
          [19.11.2021 09:42.53.028] [LOG]   Loading config ...
          [19.11.2021 09:42.53.041] [LOG]   Loading module helpers ...
          [19.11.2021 09:42.53.456] [LOG]   Initializing new module helper ...
          [19.11.2021 09:42.53.458] [LOG]   Module helper loaded: MMM-Remote-Control
          [19.11.2021 09:42.53.461] [LOG]   No helper found for module: alert.
          [19.11.2021 09:42.53.469] [LOG]   Initializing new module helper ...
          [19.11.2021 09:42.53.471] [LOG]   Module helper loaded: updatenotification
          [19.11.2021 09:42.53.472] [LOG]   No helper found for module: clock.
          [19.11.2021 09:42.53.782] [LOG]   Initializing new module helper ...
          [19.11.2021 09:42.53.784] [LOG]   Module helper loaded: calendar
          [19.11.2021 09:42.55.195] [LOG]   Initializing new module helper ...
          [19.11.2021 09:42.55.196] [LOG]   Module helper loaded: MMM-TelegramBot
          [19.11.2021 09:42.55.203] [LOG]   Initializing new module helper ...
          [19.11.2021 09:42.55.204] [LOG]   Module helper loaded: MMM-Detector
          [19.11.2021 09:42.55.987] [LOG]   Initializing new module helper ...
          [19.11.2021 09:42.55.997] [LOG]   Module helper loaded: MMM-GoogleAssistant
          [19.11.2021 09:42.55.999] [LOG]   No helper found for module: MMM-JokeAPI.
          [19.11.2021 09:42.56.001] [LOG]   No helper found for module: weather.
          [19.11.2021 09:42.56.181] [LOG]   Initializing new module helper ...
          [19.11.2021 09:42.56.183] [LOG]   Module helper loaded: MMM-Tools
          [19.11.2021 09:42.56.900] [LOG]   Initializing new module helper ...
          [19.11.2021 09:42.56.902] [LOG]   Module helper loaded: MMM-MotionDisplay
          [19.11.2021 09:42.56.955] [LOG]   Initializing new module helper ...
          [19.11.2021 09:42.56.957] [LOG]   Module helper loaded: newsfeed
          [19.11.2021 09:42.56.958] [LOG]   All module helpers loaded.
          [19.11.2021 09:42.57.123] [LOG]   Starting server on port 8080 ...
          [19.11.2021 09:42.57.139] [LOG]   Server started ...
          [19.11.2021 09:42.57.142] [LOG]   Connecting socket for: MMM-Remote-Control
          [19.11.2021 09:42.57.144] [LOG]   Starting node helper for: MMM-Remote-Control
          [19.11.2021 09:42.57.157] [LOG]   Connecting socket for: updatenotification
          [19.11.2021 09:42.57.159] [LOG]   Connecting socket for: calendar
          [19.11.2021 09:42.57.161] [LOG]   Starting node helper for: calendar
          [19.11.2021 09:42.57.163] [LOG]   Connecting socket for: MMM-TelegramBot
            @coolie1101 there should be lots more
            I only need to see the processing of that one cal entry
            Coolie1101C 2 Replies Last reply Reply Quote 0
              @sdetweil That’s everything in the file, I did tail the file, but the out is alot.
                @coolie1101 can’t be everything
                cause there are default messages for calendar not shown
                u did add the “DEBUG”, right
                  Event: {"type":"VEVENT","params":[],"start":"2021-04-06T09:00:00.000Z","datetype":"date-time","end":"2021-04-06T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"1","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE","recurrences":{"2021-11-02":{"type":"VEVENT","params":[],"start":"2021-11-03T09:00:00.000Z","datetype":"date-time","end":"2021-11-03T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-11-02T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-10-12":{"type":"VEVENT","params":[],"start":"2021-10-13T09:00:00.000Z","datetype":"date-time","end":"2021-10-13T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-10-12T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-09-07":{"type":"VEVENT","params":[],"start":"2021-09-08T09:00:00.000Z","datetype":"date-time","end":"2021-09-08T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-09-07T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-07-06":{"type":"VEVENT","params":[],"start":"2021-07-07T09:00:00.000Z","datetype":"date-time","end":"2021-07-07T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-07-06T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-06-01":{"type":"VEVENT","params":[],"start":"2021-06-02T09:00:00.000Z","datetype":"date-time","end":"2021-06-02T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-06-01T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2021-04-06T09:00:00.000Z","freq":2,"wkst":{"weekday":6},"until":"2021-12-30T04:59:59.000Z","byweekday":[{"weekday":1}]},"options":{"freq":2,"dtstart":"2021-04-06T09:00:00.000Z","interval":1,"wkst":6,"count":null,"until":"2021-12-30T04:59:59.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[1],"bynweekday":null,"byhour":[9],"byminute":[0],"bysecond":[0],"byeaster":null}}}
                    @coolie1101 unless u didn’t stop pm2 running instance
                      @sdetweil said in Calendar events showing on wrong day.:
                      I did, “pm2 stop all”, then “npm start file_name.txt”
                      Yes.
                      language: “en”,
                      locale: “en-US”,
                      logLevel: [“INFO”, “LOG”, “WARN”,“ERROR”,“DEBUG”], // Add “DEBUG” for even more logging
                      timeFormat: 24,
                      units: “imperial”,
                        @coolie1101 said in Calendar events showing on wrong day.:
                        and with the > symbol
                        npm start > file_name.txt
                          @sdetweil So I deleted the entry for that day and added back just for that day, it shows up correct in the display but the following events still shows a day late.
                            so, I need to see THAT vevent
                              @coolie1101 if you just do
                              in the MagicMirror folder
                              npm start
                              you should have a stream of stuff so fast u can’t read
                                BEGIN:VEVENT
                                DTSTART:20211123T100000Z
                                DTEND:20211123T150000Z
                                DTSTAMP:20211119T151956Z
                                UID:0g4190e8en06vs************@google.com
                                CREATED:20211119T151237Z
                                DESCRIPTION:
                                LAST-MODIFIED:20211119T151237Z
                                SEQUENCE:0
                                STATUS:CONFIRMED
                                SUMMARY:YARD WASTE
                                TRANSP:OPAQUE
                                END:VEVENT
                                There’s no output in the ssh window except for the following.
                                pi@magicmirror:~/MagicMirror $ npm start >cal_test_debug_log.txt
                                [19.11.2021 10:25.12.563] [WARN]  (electron) Security Warning: A WebContents was just created with both webviewTag and contextIsolation enabled.  This combination is fundamentally less secure and effectively bypasses the protections of contextIsolation.  We strongly recommend you move away from webviews to OOPIF or BrowserView in order for your app to be more secure
                                [19.11.2021 10:25.13.777] [ERROR] ERROR! Could not find main module js file for MMM-GABackground
                                  @coolie1101 correct, you are sending all the output to the file (except the stuff to stderr)
                                  if you remove everything from the > on you’ll get the output to the ssh window, BUT it will be so big, the top will scroll off and be lost… (which is why we are sending to a file)
                                    @sdetweil Got it, I didn’t realize the file continued on, it’s 2,486kb, which part do you need?
                                      @coolie1101 see this post
                                      https://forum.magicmirror.builders/topic/15878/calendar-events-showing-on-wrong-day/28?_=1636916667651
                                      from processing entry thru saving for the vevent that is the problem
                                      maybe 20-30 lines
                                        Event: {"type":"VEVENT","params":[],"start":"2021-11-23T10:00:00.000Z","datetype":"date-time","end":"2021-11-23T15:00:00.000Z","dtstamp":"2021-11-19T15:25:46.000Z","uid":"0g4190e8en06vs************@google.com","created":"2021-11-19T15:12:37.000Z","description":"","lastmodified":"2021-11-19T15:12:37.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}
                                        [19.11.2021 10:26.06.439] [DEBUG] startDate (local): Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                        [19.11.2021 10:26.06.440] [DEBUG] endDate (local): Tue Nov 23 2021 10:00:00 GMT-0500 (Eastern Standard Time)
                                        [19.11.2021 10:26.06.442] [DEBUG] duration: 18000000
                                        [19.11.2021 10:26.06.443] [DEBUG] title: YARD WASTE
                                        [19.11.2021 10:26.06.465] [DEBUG] initial tz=Etc/UTC
                                        [19.11.2021 10:26.06.474] [DEBUG] corrected tz=Etc/UTC
                                        [19.11.2021 10:26.06.478] [DEBUG] start date/time=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                        [19.11.2021 10:26.06.492] [DEBUG] start offset=0
                                        [19.11.2021 10:26.06.495] [DEBUG] start date/time w tz =Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                        [19.11.2021 10:26.06.498] [DEBUG] event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                        [19.11.2021 10:26.06.500] [DEBUG] event offset=0 hour=10 event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                        [19.11.2021 10:26.06.514] [DEBUG] adjustHours=0
                                        [19.11.2021 10:26.06.523] [DEBUG] Processing entry...
                                        [19.11.2021 10:26.06.527] [DEBUG]
                                        [19.11.2021 10:26.08.304] [DEBUG] Title: YARD WASTE, with dates: ["2021-11-23T09:00:00.000Z","2021-11-30T09:00:00.000Z","2021-12-07T09:00:00.000Z","2021-12-14T09:00:00.000Z","2021-12-21T09:00:00.000Z","2021-12-28T09:00:00.000Z"]
                                        The one in question at the moment is ““2021-11-30T09:00:00.000Z”” which display’s as 2021-12-01
                                          @coolie1101 yes that’s what the correction should enable
                                          05:00 ny, +4 (now est) =09:00 utc time
                                            @coolie1101 but there is no time zone set in the appointment
                                            • 2 / 4
