    Calendar events showing on wrong day.
    66 Posts 3 Posters 38.0k Views 3 Watching
      sdetweil @Coolie1101
      @coolie1101 said in Calendar events showing on wrong day.:
      Will it work like this
      no…
      something like this (couple debug lines added for my testing)
      [19.11.2021 07:50.24.603] [DEBUG] Processing entry...
      Event: {"type":"VEVENT","params":[],"start":"2021-04-06T09:00:00.000Z","datetype":"date-time","end":"2021-04-06T14:00:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2021-04-06T09:00:00.000Z","freq":2,"wkst":{"weekday":6},"until":"2021-12-30T04:59:59.000Z","byweekday":[{"weekday":1}]},"options":{"freq":2,"dtstart":"2021-04-06T09:00:00.000Z","interval":1,"wkst":6,"count":null,"until":"2021-12-30T04:59:59.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[1],"bynweekday":null,"byhour":[9],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2021-11-19T12:42:16.000Z","uid":"0v89h5cit8nq6mfribble@google.com","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"1","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}
      [19.11.2021 07:50.24.603] [DEBUG] startDate (local): Tue Apr 06 2021 04:00:00 GMT-0500 (Central Daylight Time)
      [19.11.2021 07:50.24.603] [DEBUG] endDate (local): Tue Apr 06 2021 09:00:00 GMT-0500 (Central Daylight Time)
      [19.11.2021 07:50.24.604] [DEBUG] duration: 18000000
      [19.11.2021 07:50.24.604] [DEBUG] title: YARD WASTE
      [19.11.2021 07:50.24.604] [DEBUG] Search for recurring events between: Fri Nov 19 2021 07:50:24 GMT-0600 (Central Standard Time) and Fri Nov 18 2022 23:59:59 GMT-0600 (Central Standard Time)
      [19.11.2021 07:50.24.605] [DEBUG] Title: YARD WASTE, with dates: ["2021-11-23T09:00:00.000Z","2021-11-30T09:00:00.000Z","2021-12-07T09:00:00.000Z","2021-12-14T09:00:00.000Z","2021-12-21T09:00:00.000Z","2021-12-28T09:00:00.000Z"]
      [19.11.2021 07:50.24.605] [DEBUG] event.recurrences: undefined
      [19.11.2021 07:50.24.605] [DEBUG]  recurring date is Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time) offset is 360
      [19.11.2021 07:50.24.605] [DEBUG]  recurring date is Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time) offset is 6 Hour is 03
      [19.11.2021 07:50.24.606] [DEBUG] not full day
      [19.11.2021 07:50.24.606] [DEBUG] offset positive
      [19.11.2021 07:50.24.606] [DEBUG] Corrected startDate (local): Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time)
      [19.11.2021 07:50.24.606] [DEBUG] initial tz=America/New_York
      [19.11.2021 07:50.24.606] [DEBUG] corrected tz=America/New_York
      [19.11.2021 07:50.24.606] [DEBUG] start date/time=Tue Apr 06 2021 04:00:00 GMT-0500 (Central Daylight Time)
      [19.11.2021 07:50.24.606] [DEBUG] start offset=-240
      [19.11.2021 07:50.24.606] [DEBUG] start date/time w tz =Tue Apr 06 2021 04:00:00 GMT-0500 (Central Daylight Time)
      [19.11.2021 07:50.24.606] [DEBUG] event date=Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time)
      [19.11.2021 07:50.24.606] [DEBUG] event offset=-300 hour=4 event date=Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time)
      [19.11.2021 07:50.24.606] [DEBUG] adjust up 1 hour dst change
      [19.11.2021 07:50.24.606] [DEBUG] adjustHours=1
      [19.11.2021 07:50.24.606] [DEBUG] duration: 18000000
      [19.11.2021 07:50.24.607] [DEBUG] saving event: false
      Coolie1101C 1 Reply Last reply
      • Coolie1101C
        Coolie1101 @sdetweil
        @sdetweil It’s running, how long should I wait before checking the output file?, as there is no output in the ssh window.
          @coolie1101 til the calendar comes up with the wrong displayed info
          then ctrl-c to end
          • Coolie1101C
            @sdetweil Here’s the out in the file.
            > magicmirror@2.17.1 start /home/pi/MagicMirror
            [19.11.2021 09:42.53.017] [LOG]   Starting MagicMirror: v2.17.1
            [19.11.2021 09:42.53.028] [LOG]   Loading config ...
            [19.11.2021 09:42.53.041] [LOG]   Loading module helpers ...
            [19.11.2021 09:42.53.456] [LOG]   Initializing new module helper ...
            [19.11.2021 09:42.53.458] [LOG]   Module helper loaded: MMM-Remote-Control
            [19.11.2021 09:42.53.461] [LOG]   No helper found for module: alert.
            [19.11.2021 09:42.53.469] [LOG]   Initializing new module helper ...
            [19.11.2021 09:42.53.471] [LOG]   Module helper loaded: updatenotification
            [19.11.2021 09:42.53.472] [LOG]   No helper found for module: clock.
            [19.11.2021 09:42.53.782] [LOG]   Initializing new module helper ...
            [19.11.2021 09:42.53.784] [LOG]   Module helper loaded: calendar
            [19.11.2021 09:42.55.195] [LOG]   Initializing new module helper ...
            [19.11.2021 09:42.55.196] [LOG]   Module helper loaded: MMM-TelegramBot
            [19.11.2021 09:42.55.203] [LOG]   Initializing new module helper ...
            [19.11.2021 09:42.55.204] [LOG]   Module helper loaded: MMM-Detector
            [19.11.2021 09:42.55.987] [LOG]   Initializing new module helper ...
            [19.11.2021 09:42.55.997] [LOG]   Module helper loaded: MMM-GoogleAssistant
            [19.11.2021 09:42.55.999] [LOG]   No helper found for module: MMM-JokeAPI.
            [19.11.2021 09:42.56.001] [LOG]   No helper found for module: weather.
            [19.11.2021 09:42.56.181] [LOG]   Initializing new module helper ...
            [19.11.2021 09:42.56.183] [LOG]   Module helper loaded: MMM-Tools
            [19.11.2021 09:42.56.900] [LOG]   Initializing new module helper ...
            [19.11.2021 09:42.56.902] [LOG]   Module helper loaded: MMM-MotionDisplay
            [19.11.2021 09:42.56.955] [LOG]   Initializing new module helper ...
            [19.11.2021 09:42.56.957] [LOG]   Module helper loaded: newsfeed
            [19.11.2021 09:42.56.958] [LOG]   All module helpers loaded.
            [19.11.2021 09:42.57.123] [LOG]   Starting server on port 8080 ...
            [19.11.2021 09:42.57.139] [LOG]   Server started ...
            [19.11.2021 09:42.57.142] [LOG]   Connecting socket for: MMM-Remote-Control
            [19.11.2021 09:42.57.144] [LOG]   Starting node helper for: MMM-Remote-Control
            [19.11.2021 09:42.57.157] [LOG]   Connecting socket for: updatenotification
            [19.11.2021 09:42.57.159] [LOG]   Connecting socket for: calendar
            [19.11.2021 09:42.57.161] [LOG]   Starting node helper for: calendar
            [19.11.2021 09:42.57.163] [LOG]   Connecting socket for: MMM-TelegramBot
              @coolie1101 there should be lots more
              I only need to see the processing of that one cal entry
              Coolie1101C 2 Replies Last reply
              • Coolie1101C
                @sdetweil That’s everything in the file, I did tail the file, but the out is alot.
                S 2 Replies Last reply
                  @coolie1101 can’t be everything
                  cause there are default messages for calendar not shown
                  u did add the “DEBUG”, right
                  • Coolie1101C
                    Event: {"type":"VEVENT","params":[],"start":"2021-04-06T09:00:00.000Z","datetype":"date-time","end":"2021-04-06T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"1","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE","recurrences":{"2021-11-02":{"type":"VEVENT","params":[],"start":"2021-11-03T09:00:00.000Z","datetype":"date-time","end":"2021-11-03T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-11-02T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-10-12":{"type":"VEVENT","params":[],"start":"2021-10-13T09:00:00.000Z","datetype":"date-time","end":"2021-10-13T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-10-12T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-09-07":{"type":"VEVENT","params":[],"start":"2021-09-08T09:00:00.000Z","datetype":"date-time","end":"2021-09-08T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-09-07T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-07-06":{"type":"VEVENT","params":[],"start":"2021-07-07T09:00:00.000Z","datetype":"date-time","end":"2021-07-07T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-07-06T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-06-01":{"type":"VEVENT","params":[],"start":"2021-06-02T09:00:00.000Z","datetype":"date-time","end":"2021-06-02T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-06-01T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2021-04-06T09:00:00.000Z","freq":2,"wkst":{"weekday":6},"until":"2021-12-30T04:59:59.000Z","byweekday":[{"weekday":1}]},"options":{"freq":2,"dtstart":"2021-04-06T09:00:00.000Z","interval":1,"wkst":6,"count":null,"until":"2021-12-30T04:59:59.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[1],"bynweekday":null,"byhour":[9],"byminute":[0],"bysecond":[0],"byeaster":null}}}
                      @coolie1101 unless u didn’t stop pm2 running instance
                      • Coolie1101C
                        @sdetweil said in Calendar events showing on wrong day.:
                        I did, “pm2 stop all”, then “npm start file_name.txt”
                        Yes.
                        language: “en”,
                        locale: “en-US”,
                        logLevel: [“INFO”, “LOG”, “WARN”,“ERROR”,“DEBUG”], // Add “DEBUG” for even more logging
                        timeFormat: 24,
                        units: “imperial”,
                          and with the > symbol
                          npm start > file_name.txt
                          • Coolie1101C
                            @sdetweil So I deleted the entry for that day and added back just for that day, it shows up correct in the display but the following events still shows a day late.
                              so, I need to see THAT vevent
                                @coolie1101 if you just do
                                in the MagicMirror folder
                                npm start
                                you should have a stream of stuff so fast u can’t read
                                • Coolie1101C
                                  BEGIN:VEVENT
                                  DTSTART:20211123T100000Z
                                  DTEND:20211123T150000Z
                                  DTSTAMP:20211119T151956Z
                                  UID:0g4190e8en06vs************@google.com
                                  CREATED:20211119T151237Z
                                  DESCRIPTION:
                                  LAST-MODIFIED:20211119T151237Z
                                  SEQUENCE:0
                                  STATUS:CONFIRMED
                                  SUMMARY:YARD WASTE
                                  TRANSP:OPAQUE
                                  END:VEVENT
                                  There’s no output in the ssh window except for the following.
                                  pi@magicmirror:~/MagicMirror $ npm start >cal_test_debug_log.txt
                                  [19.11.2021 10:25.12.563] [WARN]  (electron) Security Warning: A WebContents was just created with both webviewTag and contextIsolation enabled.  This combination is fundamentally less secure and effectively bypasses the protections of contextIsolation.  We strongly recommend you move away from webviews to OOPIF or BrowserView in order for your app to be more secure
                                  [19.11.2021 10:25.13.777] [ERROR] ERROR! Could not find main module js file for MMM-GABackground
                                    @coolie1101 correct, you are sending all the output to the file (except the stuff to stderr)
                                    if you remove everything from the > on you’ll get the output to the ssh window, BUT it will be so big, the top will scroll off and be lost… (which is why we are sending to a file)
                                    • Coolie1101C
                                      @sdetweil Got it, I didn’t realize the file continued on, it’s 2,486kb, which part do you need?
                                        @coolie1101 see this post
                                        https://forum.magicmirror.builders/topic/15878/calendar-events-showing-on-wrong-day/28?_=1636916667651
                                        from processing entry thru saving for the vevent that is the problem
                                        maybe 20-30 lines
                                        • Coolie1101C
                                          Event: {"type":"VEVENT","params":[],"start":"2021-11-23T10:00:00.000Z","datetype":"date-time","end":"2021-11-23T15:00:00.000Z","dtstamp":"2021-11-19T15:25:46.000Z","uid":"0g4190e8en06vs************@google.com","created":"2021-11-19T15:12:37.000Z","description":"","lastmodified":"2021-11-19T15:12:37.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}
                                          [19.11.2021 10:26.06.439] [DEBUG] startDate (local): Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 10:26.06.440] [DEBUG] endDate (local): Tue Nov 23 2021 10:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 10:26.06.442] [DEBUG] duration: 18000000
                                          [19.11.2021 10:26.06.443] [DEBUG] title: YARD WASTE
                                          [19.11.2021 10:26.06.465] [DEBUG] initial tz=Etc/UTC
                                          [19.11.2021 10:26.06.474] [DEBUG] corrected tz=Etc/UTC
                                          [19.11.2021 10:26.06.478] [DEBUG] start date/time=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 10:26.06.492] [DEBUG] start offset=0
                                          [19.11.2021 10:26.06.495] [DEBUG] start date/time w tz =Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 10:26.06.498] [DEBUG] event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 10:26.06.500] [DEBUG] event offset=0 hour=10 event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 10:26.06.514] [DEBUG] adjustHours=0
                                          [19.11.2021 10:26.06.523] [DEBUG] Processing entry...
                                          [19.11.2021 10:26.06.527] [DEBUG]
                                          [19.11.2021 10:26.08.304] [DEBUG] Title: YARD WASTE, with dates: ["2021-11-23T09:00:00.000Z","2021-11-30T09:00:00.000Z","2021-12-07T09:00:00.000Z","2021-12-14T09:00:00.000Z","2021-12-21T09:00:00.000Z","2021-12-28T09:00:00.000Z"]
                                          The one in question at the moment is ““2021-11-30T09:00:00.000Z”” which display’s as 2021-12-01
                                            @coolie1101 yes that’s what the correction should enable
                                            05:00 ny, +4 (now est) =09:00 utc time
                                            • 2 / 4
