Unsolved Calendar events showing on wrong day.
@sdetweil That’s everything in the file, I did tail the file, but the out is alot.
@coolie1101 can’t be everything
cause there are default messages for calendar not shown
u did add the “DEBUG”, right
Event: {"type":"VEVENT","params":[],"start":"2021-04-06T09:00:00.000Z","datetype":"date-time","end":"2021-04-06T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"1","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE","recurrences":{"2021-11-02":{"type":"VEVENT","params":[],"start":"2021-11-03T09:00:00.000Z","datetype":"date-time","end":"2021-11-03T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-11-02T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-10-12":{"type":"VEVENT","params":[],"start":"2021-10-13T09:00:00.000Z","datetype":"date-time","end":"2021-10-13T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-10-12T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-09-07":{"type":"VEVENT","params":[],"start":"2021-09-08T09:00:00.000Z","datetype":"date-time","end":"2021-09-08T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-09-07T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-07-06":{"type":"VEVENT","params":[],"start":"2021-07-07T09:00:00.000Z","datetype":"date-time","end":"2021-07-07T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-07-06T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-06-01":{"type":"VEVENT","params":[],"start":"2021-06-02T09:00:00.000Z","datetype":"date-time","end":"2021-06-02T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-06-01T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2021-04-06T09:00:00.000Z","freq":2,"wkst":{"weekday":6},"until":"2021-12-30T04:59:59.000Z","byweekday":[{"weekday":1}]},"options":{"freq":2,"dtstart":"2021-04-06T09:00:00.000Z","interval":1,"wkst":6,"count":null,"until":"2021-12-30T04:59:59.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[1],"bynweekday":null,"byhour":[9],"byminute":[0],"bysecond":[0],"byeaster":null}}}
@coolie1101 unless u didn’t stop pm2 running instance
@sdetweil said in Calendar events showing on wrong day.:
I did, “pm2 stop all”, then “npm start file_name.txt”
Yes.
language: “en”,
locale: “en-US”,
logLevel: [“INFO”, “LOG”, “WARN”,“ERROR”,“DEBUG”], // Add “DEBUG” for even more logging
timeFormat: 24,
units: “imperial”, -
@coolie1101 said in Calendar events showing on wrong day.:
and with the > symbol
npm start > file_name.txt
@sdetweil So I deleted the entry for that day and added back just for that day, it shows up correct in the display but the following events still shows a day late.
so, I need to see THAT vevent
@coolie1101 if you just do
in the MagicMirror folder
npm start
you should have a stream of stuff so fast u can’t read
BEGIN:VEVENT DTSTART:20211123T100000Z DTEND:20211123T150000Z DTSTAMP:20211119T151956Z UID:0g4190e8en06vs************@google.com CREATED:20211119T151237Z DESCRIPTION: LAST-MODIFIED:20211119T151237Z LOCATION: SEQUENCE:0 STATUS:CONFIRMED SUMMARY:YARD WASTE TRANSP:OPAQUE END:VEVENT
There’s no output in the ssh window except for the following.
pi@magicmirror:~/MagicMirror $ npm start >cal_test_debug_log.txt [19.11.2021 10:25.12.563] [WARN] (electron) Security Warning: A WebContents was just created with both webviewTag and contextIsolation enabled. This combination is fundamentally less secure and effectively bypasses the protections of contextIsolation. We strongly recommend you move away from webviews to OOPIF or BrowserView in order for your app to be more secure [19.11.2021 10:25.13.777] [ERROR] ERROR! Could not find main module js file for MMM-GABackground
