    Calendar events showing on wrong day.
    66 Posts 3 Posters 38.0k Views 3 Watching
    • Coolie1101C
      Coolie1101 @sdetweil
      @sdetweil That’s everything in the file, I did tail the file, but the out is alot.
      S 2 Replies Last reply
        sdetweil @Coolie1101
        @coolie1101 can’t be everything
        cause there are default messages for calendar not shown
        u did add the “DEBUG”, right
        • Coolie1101C
          Event: {"type":"VEVENT","params":[],"start":"2021-04-06T09:00:00.000Z","datetype":"date-time","end":"2021-04-06T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"1","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE","recurrences":{"2021-11-02":{"type":"VEVENT","params":[],"start":"2021-11-03T09:00:00.000Z","datetype":"date-time","end":"2021-11-03T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-11-02T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-10-12":{"type":"VEVENT","params":[],"start":"2021-10-13T09:00:00.000Z","datetype":"date-time","end":"2021-10-13T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-10-12T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-09-07":{"type":"VEVENT","params":[],"start":"2021-09-08T09:00:00.000Z","datetype":"date-time","end":"2021-09-08T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-09-07T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-07-06":{"type":"VEVENT","params":[],"start":"2021-07-07T09:00:00.000Z","datetype":"date-time","end":"2021-07-07T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-07-06T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-06-01":{"type":"VEVENT","params":[],"start":"2021-06-02T09:00:00.000Z","datetype":"date-time","end":"2021-06-02T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-06-01T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2021-04-06T09:00:00.000Z","freq":2,"wkst":{"weekday":6},"until":"2021-12-30T04:59:59.000Z","byweekday":[{"weekday":1}]},"options":{"freq":2,"dtstart":"2021-04-06T09:00:00.000Z","interval":1,"wkst":6,"count":null,"until":"2021-12-30T04:59:59.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[1],"bynweekday":null,"byhour":[9],"byminute":[0],"bysecond":[0],"byeaster":null}}}
            @coolie1101 unless u didn’t stop pm2 running instance
            Coolie1101C 2 Replies Last reply
            • Coolie1101C
              @sdetweil said in Calendar events showing on wrong day.:
              I did, “pm2 stop all”, then “npm start file_name.txt”
              Yes.
              language: “en”,
              locale: “en-US”,
              logLevel: [“INFO”, “LOG”, “WARN”,“ERROR”,“DEBUG”], // Add “DEBUG” for even more logging
              timeFormat: 24,
              units: “imperial”,
                @coolie1101 said in Calendar events showing on wrong day.:
                and with the > symbol
                npm start > file_name.txt
                • Coolie1101C
                  @sdetweil So I deleted the entry for that day and added back just for that day, it shows up correct in the display but the following events still shows a day late.
                    so, I need to see THAT vevent
                    Coolie1101C 1 Reply Last reply
                      @coolie1101 if you just do
                      in the MagicMirror folder
                      npm start
                      you should have a stream of stuff so fast u can’t read
                      • Coolie1101C
                        BEGIN:VEVENT
                        DTSTART:20211123T100000Z
                        DTEND:20211123T150000Z
                        DTSTAMP:20211119T151956Z
                        UID:0g4190e8en06vs************@google.com
                        CREATED:20211119T151237Z
                        DESCRIPTION:
                        LAST-MODIFIED:20211119T151237Z
                        SEQUENCE:0
                        STATUS:CONFIRMED
                        SUMMARY:YARD WASTE
                        TRANSP:OPAQUE
                        END:VEVENT
                        There’s no output in the ssh window except for the following.
                        pi@magicmirror:~/MagicMirror $ npm start >cal_test_debug_log.txt
                        [19.11.2021 10:25.12.563] [WARN]  (electron) Security Warning: A WebContents was just created with both webviewTag and contextIsolation enabled.  This combination is fundamentally less secure and effectively bypasses the protections of contextIsolation.  We strongly recommend you move away from webviews to OOPIF or BrowserView in order for your app to be more secure
                        [19.11.2021 10:25.13.777] [ERROR] ERROR! Could not find main module js file for MMM-GABackground
                          @coolie1101 correct, you are sending all the output to the file (except the stuff to stderr)
                          if you remove everything from the > on you’ll get the output to the ssh window, BUT it will be so big, the top will scroll off and be lost… (which is why we are sending to a file)
                          • Coolie1101C
                            @sdetweil Got it, I didn’t realize the file continued on, it’s 2,486kb, which part do you need?
                              @coolie1101 see this post
                              https://forum.magicmirror.builders/topic/15878/calendar-events-showing-on-wrong-day/28?_=1636916667651
                              from processing entry thru saving for the vevent that is the problem
                              maybe 20-30 lines
                              • Coolie1101C
                                Event: {"type":"VEVENT","params":[],"start":"2021-11-23T10:00:00.000Z","datetype":"date-time","end":"2021-11-23T15:00:00.000Z","dtstamp":"2021-11-19T15:25:46.000Z","uid":"0g4190e8en06vs************@google.com","created":"2021-11-19T15:12:37.000Z","description":"","lastmodified":"2021-11-19T15:12:37.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}
                                [19.11.2021 10:26.06.439] [DEBUG] startDate (local): Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                [19.11.2021 10:26.06.440] [DEBUG] endDate (local): Tue Nov 23 2021 10:00:00 GMT-0500 (Eastern Standard Time)
                                [19.11.2021 10:26.06.442] [DEBUG] duration: 18000000
                                [19.11.2021 10:26.06.443] [DEBUG] title: YARD WASTE
                                [19.11.2021 10:26.06.465] [DEBUG] initial tz=Etc/UTC
                                [19.11.2021 10:26.06.474] [DEBUG] corrected tz=Etc/UTC
                                [19.11.2021 10:26.06.478] [DEBUG] start date/time=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                [19.11.2021 10:26.06.492] [DEBUG] start offset=0
                                [19.11.2021 10:26.06.495] [DEBUG] start date/time w tz =Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                [19.11.2021 10:26.06.498] [DEBUG] event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                [19.11.2021 10:26.06.500] [DEBUG] event offset=0 hour=10 event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                                [19.11.2021 10:26.06.514] [DEBUG] adjustHours=0
                                [19.11.2021 10:26.06.523] [DEBUG] Processing entry...
                                [19.11.2021 10:26.06.527] [DEBUG]
                                [19.11.2021 10:26.08.304] [DEBUG] Title: YARD WASTE, with dates: ["2021-11-23T09:00:00.000Z","2021-11-30T09:00:00.000Z","2021-12-07T09:00:00.000Z","2021-12-14T09:00:00.000Z","2021-12-21T09:00:00.000Z","2021-12-28T09:00:00.000Z"]
                                The one in question at the moment is ““2021-11-30T09:00:00.000Z”” which display’s as 2021-12-01
                                  @coolie1101 yes that’s what the correction should enable
                                  05:00 ny, +4 (now est) =09:00 utc time
                                    @coolie1101 but there is no time zone set in the appointment
                                    • Coolie1101C
                                      It shows as set in the calendar itself?
                                        @coolie1101 yes, BUT it doesn’t show in the ics file…
                                        anyhow…
                                        show me the next entry from the debug output
                                        or send me the debug output file via email
                                        same userid at gmail
                                        • Coolie1101C
                                          Event: {"type":"VEVENT","params":[],"start":"2022-01-26T10:00:00.000Z","datetype":"date-time","end":"2022-01-26T15:00:00.000Z","dtstamp":"2021-11-19T16:07:10.000Z","uid":"0idffl8ue0gac*************@google.com","created":"2021-11-19T13:18:54.000Z","description":"Recycling Bottles, Cans, and Plastic.","lastmodified":"2021-11-19T13:18:54.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"RECYCLING (BOTTLES, CANS and PLASTIC) ","transparency":"TRANSPARENT"}
                                          [19.11.2021 11:07.22.130] [DEBUG] startDate (local): Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 11:07.22.135] [DEBUG] endDate (local): Wed Jan 26 2022 10:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 11:07.22.141] [DEBUG] duration: 18000000
                                          [19.11.2021 11:07.22.146] [DEBUG] title: RECYCLING (BOTTLES, CANS and PLASTIC)
                                          [19.11.2021 11:07.22.160] [DEBUG] initial tz=Etc/UTC
                                          [19.11.2021 11:07.22.169] [DEBUG] corrected tz=Etc/UTC
                                          [19.11.2021 11:07.22.174] [DEBUG] start date/time=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 11:07.22.178] [DEBUG] start offset=0
                                          [19.11.2021 11:07.22.182] [DEBUG] start date/time w tz =Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 11:07.22.189] [DEBUG] event date=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 11:07.22.195] [DEBUG] event offset=0 hour=10 event date=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                                          [19.11.2021 11:07.22.202] [DEBUG] adjustHours=0
                                          [19.11.2021 11:07.22.209] [DEBUG] Processing entry...
                                          [19.11.2021 11:07.22.217] [DEBUG]
                                          This is the Calendar Event I believe we should be looking at
                                          BEGIN:VEVENT
                                          DTSTART;TZID=America/New_York:20210406T050000
                                          DTEND;TZID=America/New_York:20210406T100000
                                          RRULE:FREQ=WEEKLY;WKST=SU;UNTIL=20211230T045959Z;BYDAY=TU
                                          EXDATE;TZID=America/New_York:20211123T050000
                                          DTSTAMP:20211119T165604Z
                                          UID:0v89h5cit8nq6m************@google.com
                                          CREATED:20211026T075843Z
                                          DESCRIPTION:
                                          LAST-MODIFIED:20211026T080254Z
                                          SEQUENCE:1
                                          STATUS:CONFIRMED
                                          SUMMARY:YARD WASTE
                                          TRANSP:OPAQUE
                                          END:VEVENT
                                          This last event listed as “UNTIL=20211230T045959Z”, displays as Dec 1st.
                                            @coolie1101 I added 2 to the end, Yard Waste 2, and see this, with my system set to eastern time. I didn’t delete the prior ics entries
                                            • 3 / 4
