    Calendar events showing on wrong day.
    66 Posts 3 Posters 27.6k Views 3 Watching
    • Coolie1101C Offline
      Coolie1101 @sdetweil
      Event: {"type":"VEVENT","params":[],"start":"2021-11-23T10:00:00.000Z","datetype":"date-time","end":"2021-11-23T15:00:00.000Z","dtstamp":"2021-11-19T15:25:46.000Z","uid":"0g4190e8en06vs************@google.com","created":"2021-11-19T15:12:37.000Z","description":"","lastmodified":"2021-11-19T15:12:37.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}
      [19.11.2021 10:26.06.439] [DEBUG] startDate (local): Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
      [19.11.2021 10:26.06.440] [DEBUG] endDate (local): Tue Nov 23 2021 10:00:00 GMT-0500 (Eastern Standard Time)
      [19.11.2021 10:26.06.442] [DEBUG] duration: 18000000
      [19.11.2021 10:26.06.443] [DEBUG] title: YARD WASTE
      [19.11.2021 10:26.06.465] [DEBUG] initial tz=Etc/UTC
      [19.11.2021 10:26.06.474] [DEBUG] corrected tz=Etc/UTC
      [19.11.2021 10:26.06.478] [DEBUG] start date/time=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
      [19.11.2021 10:26.06.492] [DEBUG] start offset=0
      [19.11.2021 10:26.06.495] [DEBUG] start date/time w tz =Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
      [19.11.2021 10:26.06.498] [DEBUG] event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
      [19.11.2021 10:26.06.500] [DEBUG] event offset=0 hour=10 event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
      [19.11.2021 10:26.06.514] [DEBUG] adjustHours=0
      [19.11.2021 10:26.06.523] [DEBUG] Processing entry...
      [19.11.2021 10:26.06.527] [DEBUG]
      [19.11.2021 10:26.08.304] [DEBUG] Title: YARD WASTE, with dates: ["2021-11-23T09:00:00.000Z","2021-11-30T09:00:00.000Z","2021-12-07T09:00:00.000Z","2021-12-14T09:00:00.000Z","2021-12-21T09:00:00.000Z","2021-12-28T09:00:00.000Z"]
      The one in question at the moment is ““2021-11-30T09:00:00.000Z”” which display’s as 2021-12-01
        sdetweil @Coolie1101
        @coolie1101 yes that’s what the correction should enable
        05:00 ny, +4 (now est) =09:00 utc time
          @coolie1101 but there is no time zone set in the appointment
          Coolie1101C 1 Reply Last reply Reply Quote 0
            @sdetweil said in Calendar events showing on wrong day.:
            It shows as set in the calendar itself?
              @coolie1101 yes, BUT it doesn’t show in the ics file…
              anyhow…
              show me the next entry from the debug output
              or send me the debug output file via email
              same userid at gmail
                Event: {"type":"VEVENT","params":[],"start":"2022-01-26T10:00:00.000Z","datetype":"date-time","end":"2022-01-26T15:00:00.000Z","dtstamp":"2021-11-19T16:07:10.000Z","uid":"0idffl8ue0gac*************@google.com","created":"2021-11-19T13:18:54.000Z","description":"Recycling Bottles, Cans, and Plastic.","lastmodified":"2021-11-19T13:18:54.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"RECYCLING (BOTTLES, CANS and PLASTIC) ","transparency":"TRANSPARENT"}
                [19.11.2021 11:07.22.130] [DEBUG] startDate (local): Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 11:07.22.135] [DEBUG] endDate (local): Wed Jan 26 2022 10:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 11:07.22.141] [DEBUG] duration: 18000000
                [19.11.2021 11:07.22.146] [DEBUG] title: RECYCLING (BOTTLES, CANS and PLASTIC)
                [19.11.2021 11:07.22.160] [DEBUG] initial tz=Etc/UTC
                [19.11.2021 11:07.22.169] [DEBUG] corrected tz=Etc/UTC
                [19.11.2021 11:07.22.174] [DEBUG] start date/time=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 11:07.22.178] [DEBUG] start offset=0
                [19.11.2021 11:07.22.182] [DEBUG] start date/time w tz =Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 11:07.22.189] [DEBUG] event date=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 11:07.22.195] [DEBUG] event offset=0 hour=10 event date=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 11:07.22.202] [DEBUG] adjustHours=0
                [19.11.2021 11:07.22.209] [DEBUG] Processing entry...
                [19.11.2021 11:07.22.217] [DEBUG]
                This is the Calendar Event I believe we should be looking at
                BEGIN:VEVENT
                DTSTART;TZID=America/New_York:20210406T050000
                DTEND;TZID=America/New_York:20210406T100000
                RRULE:FREQ=WEEKLY;WKST=SU;UNTIL=20211230T045959Z;BYDAY=TU
                EXDATE;TZID=America/New_York:20211123T050000
                DTSTAMP:20211119T165604Z
                UID:0v89h5cit8nq6m************@google.com
                CREATED:20211026T075843Z
                DESCRIPTION:
                LAST-MODIFIED:20211026T080254Z
                SEQUENCE:1
                STATUS:CONFIRMED
                SUMMARY:YARD WASTE
                TRANSP:OPAQUE
                END:VEVENT
                This last event listed as “UNTIL=20211230T045959Z”, displays as Dec 1st.
                  @coolie1101 I added 2 to the end, Yard Waste 2, and see this, with my system set to eastern time. I didn’t delete the prior ics entries
                    @sdetweil I understand that it works, and it is indeed working, but why is it showing a day later is what I am trying to figure out, what about the entries for 11/23-12/6?
                      @coolie1101 I don’t see a day late… the event is Tuesdays, weekly, 11/23 is tuesday, 11/30 is tuesday, 12/7 is tuesday
                      I am looking for the 11/23 entry…
                      DUH, it says exclude 11/23
                        Those dates are correct, the 11/23 entry was deleted and re-added, so it’s not part of the yearly schedule anymore.
                        For me the entry for 11/30 displays on the monitor as Dec 1st.
                        • 5 / 7
