    Calendar events showing on wrong day.
    66 Posts 3 Posters 38.0k Views 3 Watching
    • Coolie1101C
      Coolie1101 @sdetweil
      @sdetweil said in Calendar events showing on wrong day.:
      unless u didn’t stop pm2 running instance
      I did, “pm2 stop all”, then “npm start file_name.txt”
      u did add the “DEBUG”, right
      Yes.
      language: “en”,
      locale: “en-US”,
      logLevel: [“INFO”, “LOG”, “WARN”,“ERROR”,“DEBUG”], // Add “DEBUG” for even more logging
      timeFormat: 24,
      units: “imperial”,
      S 2 Replies Last reply
        sdetweil @Coolie1101
        @coolie1101 said in Calendar events showing on wrong day.:
        and with the > symbol
        npm start > file_name.txt
        • Coolie1101C
          @sdetweil So I deleted the entry for that day and added back just for that day, it shows up correct in the display but the following events still shows a day late.
            so, I need to see THAT vevent
            Coolie1101C 1 Reply Last reply
              @coolie1101 if you just do
              in the MagicMirror folder
              npm start
              you should have a stream of stuff so fast u can’t read
              • Coolie1101C
                BEGIN:VEVENT
                DTSTART:20211123T100000Z
                DTEND:20211123T150000Z
                DTSTAMP:20211119T151956Z
                UID:0g4190e8en06vs************@google.com
                CREATED:20211119T151237Z
                DESCRIPTION:
                LAST-MODIFIED:20211119T151237Z
                SEQUENCE:0
                STATUS:CONFIRMED
                SUMMARY:YARD WASTE
                TRANSP:OPAQUE
                END:VEVENT
                There’s no output in the ssh window except for the following.
                pi@magicmirror:~/MagicMirror $ npm start >cal_test_debug_log.txt
                [19.11.2021 10:25.12.563] [WARN]  (electron) Security Warning: A WebContents was just created with both webviewTag and contextIsolation enabled.  This combination is fundamentally less secure and effectively bypasses the protections of contextIsolation.  We strongly recommend you move away from webviews to OOPIF or BrowserView in order for your app to be more secure
                [19.11.2021 10:25.13.777] [ERROR] ERROR! Could not find main module js file for MMM-GABackground
                  @coolie1101 correct, you are sending all the output to the file (except the stuff to stderr)
                  if you remove everything from the > on you’ll get the output to the ssh window, BUT it will be so big, the top will scroll off and be lost… (which is why we are sending to a file)
                  • Coolie1101C
                    @sdetweil Got it, I didn’t realize the file continued on, it’s 2,486kb, which part do you need?
                      @coolie1101 see this post
                      https://forum.magicmirror.builders/topic/15878/calendar-events-showing-on-wrong-day/28?_=1636916667651
                      from processing entry thru saving for the vevent that is the problem
                      maybe 20-30 lines
                      • Coolie1101C
                        Event: {"type":"VEVENT","params":[],"start":"2021-11-23T10:00:00.000Z","datetype":"date-time","end":"2021-11-23T15:00:00.000Z","dtstamp":"2021-11-19T15:25:46.000Z","uid":"0g4190e8en06vs************@google.com","created":"2021-11-19T15:12:37.000Z","description":"","lastmodified":"2021-11-19T15:12:37.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}
                        [19.11.2021 10:26.06.439] [DEBUG] startDate (local): Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                        [19.11.2021 10:26.06.440] [DEBUG] endDate (local): Tue Nov 23 2021 10:00:00 GMT-0500 (Eastern Standard Time)
                        [19.11.2021 10:26.06.442] [DEBUG] duration: 18000000
                        [19.11.2021 10:26.06.443] [DEBUG] title: YARD WASTE
                        [19.11.2021 10:26.06.465] [DEBUG] initial tz=Etc/UTC
                        [19.11.2021 10:26.06.474] [DEBUG] corrected tz=Etc/UTC
                        [19.11.2021 10:26.06.478] [DEBUG] start date/time=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                        [19.11.2021 10:26.06.492] [DEBUG] start offset=0
                        [19.11.2021 10:26.06.495] [DEBUG] start date/time w tz =Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                        [19.11.2021 10:26.06.498] [DEBUG] event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                        [19.11.2021 10:26.06.500] [DEBUG] event offset=0 hour=10 event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                        [19.11.2021 10:26.06.514] [DEBUG] adjustHours=0
                        [19.11.2021 10:26.06.523] [DEBUG] Processing entry...
                        [19.11.2021 10:26.06.527] [DEBUG]
                        [19.11.2021 10:26.08.304] [DEBUG] Title: YARD WASTE, with dates: ["2021-11-23T09:00:00.000Z","2021-11-30T09:00:00.000Z","2021-12-07T09:00:00.000Z","2021-12-14T09:00:00.000Z","2021-12-21T09:00:00.000Z","2021-12-28T09:00:00.000Z"]
                        The one in question at the moment is ““2021-11-30T09:00:00.000Z”” which display’s as 2021-12-01
                          @coolie1101 yes that’s what the correction should enable
                          05:00 ny, +4 (now est) =09:00 utc time
                            @coolie1101 but there is no time zone set in the appointment
                            • Coolie1101C
                              It shows as set in the calendar itself?
                                @coolie1101 yes, BUT it doesn’t show in the ics file…
                                anyhow…
                                show me the next entry from the debug output
                                or send me the debug output file via email
                                same userid at gmail
                                • Coolie1101C
                                  Event: {"type":"VEVENT","params":[],"start":"2022-01-26T10:00:00.000Z","datetype":"date-time","end":"2022-01-26T15:00:00.000Z","dtstamp":"2021-11-19T16:07:10.000Z","uid":"0idffl8ue0gac*************@google.com","created":"2021-11-19T13:18:54.000Z","description":"Recycling Bottles, Cans, and Plastic.","lastmodified":"2021-11-19T13:18:54.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"RECYCLING (BOTTLES, CANS and PLASTIC) ","transparency":"TRANSPARENT"}
                                  [19.11.2021 11:07.22.130] [DEBUG] startDate (local): Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                                  [19.11.2021 11:07.22.135] [DEBUG] endDate (local): Wed Jan 26 2022 10:00:00 GMT-0500 (Eastern Standard Time)
                                  [19.11.2021 11:07.22.141] [DEBUG] duration: 18000000
                                  [19.11.2021 11:07.22.146] [DEBUG] title: RECYCLING (BOTTLES, CANS and PLASTIC)
                                  [19.11.2021 11:07.22.160] [DEBUG] initial tz=Etc/UTC
                                  [19.11.2021 11:07.22.169] [DEBUG] corrected tz=Etc/UTC
                                  [19.11.2021 11:07.22.174] [DEBUG] start date/time=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                                  [19.11.2021 11:07.22.178] [DEBUG] start offset=0
                                  [19.11.2021 11:07.22.182] [DEBUG] start date/time w tz =Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                                  [19.11.2021 11:07.22.189] [DEBUG] event date=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                                  [19.11.2021 11:07.22.195] [DEBUG] event offset=0 hour=10 event date=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                                  [19.11.2021 11:07.22.202] [DEBUG] adjustHours=0
                                  [19.11.2021 11:07.22.209] [DEBUG] Processing entry...
                                  [19.11.2021 11:07.22.217] [DEBUG]
                                  This is the Calendar Event I believe we should be looking at
                                  BEGIN:VEVENT
                                  DTSTART;TZID=America/New_York:20210406T050000
                                  DTEND;TZID=America/New_York:20210406T100000
                                  RRULE:FREQ=WEEKLY;WKST=SU;UNTIL=20211230T045959Z;BYDAY=TU
                                  EXDATE;TZID=America/New_York:20211123T050000
                                  DTSTAMP:20211119T165604Z
                                  UID:0v89h5cit8nq6m************@google.com
                                  CREATED:20211026T075843Z
                                  DESCRIPTION:
                                  LAST-MODIFIED:20211026T080254Z
                                  SEQUENCE:1
                                  STATUS:CONFIRMED
                                  SUMMARY:YARD WASTE
                                  TRANSP:OPAQUE
                                  END:VEVENT
                                  This last event listed as “UNTIL=20211230T045959Z”, displays as Dec 1st.
                                    @coolie1101 I added 2 to the end, Yard Waste 2, and see this, with my system set to eastern time. I didn’t delete the prior ics entries
                                    • Coolie1101C
                                      @sdetweil I understand that it works, and it is indeed working, but why is it showing a day later is what I am trying to figure out, what about the entries for 11/23-12/6?
                                        @coolie1101 I don’t see a day late… the event is Tuesdays, weekly, 11/23 is tuesday, 11/30 is tuesday, 12/7 is tuesday
                                        I am looking for the 11/23 entry…
                                        DUH, it says exclude 11/23
                                        • Coolie1101C
                                          Those dates are correct, the 11/23 entry was deleted and re-added, so it’s not part of the yearly schedule anymore.
                                          For me the entry for 11/30 displays on the monitor as Dec 1st.
                                            its hard to tell which cal entry it comes from when the text is all the same.
                                            Coolie1101C 2 Replies Last reply
                                            • 3 / 4
