    MMM-Buttons
    5 Posts 3 Posters 1.7k Views 3 Watching
      Johans
      Hi, I wanted more pages on my mirror and control them physically with a button.
      installed MMM-Pages / MMM-Page Selector / MMM-Buttons and MMM-Remote Control.
      (First I tried to use MPR-121 but that gives too many errors during installation so I gave up)
      3 buttons connected to Pin 23-34-25 (BCM numbering - RPI-4/4GB)
      Now when I press a button nothing happens. Can’t see what could be wrong.
      this my config:
          module: 'MMM-Buttons',
              buttons: [
                      pin: 23,
                      name: "page changes",
                      longPress: {
                          notification: "PAGE_DECREMENT",
                          payload: {action: ""}
                      shortPress: {
                          notification: "PAGE_INCREMENT",
                      pin: 24,
                      longPress: {
                          notification: "REMOTE_ACTION",
                          payload: {action: "MONITOROFF"}
                      shortPress: {
                          payload: {action: "MONITORON"}
                      pin: 25,
                      longPress: {
                          title: "Power off",
                          message: "Keep pressed for 3 seconds to shut down",
                          imageFA: "power-off",
                          payload: {action: "SHUTDOWN"}
      		 shortPress: {
                          title: "test page up",
                          notification: "PAGE_INCREMENT",   // as test
                          payload: {action: "1"}            // as test
      J FoziF 2 Replies Last reply Reply Quote 0
        Johans @Johans
        @johans - they are connected to ground or must the common be connected to the 3.3V pin?
          JohnBachini @Johans
          @johans
          I just started doing exactly what you are trying to do. I have managed to get MMM-Buttons working with one button, but not getting reliable results.
          I first tried MMM-Button and was able to confirm button press worked as was getting a message in the logs saying the button was pressed.
          Correct ground and i thought the other needs to be one of the green GPIO, sorry not at home so cant check
          • FoziF Offline
            Fozi Project Sponsor @Johans
            @johans I guess you need to use a pulldown resistor to avoid floating GND.
            Here is a sketch how to use the pull-down-resistor. I had the MMM-Button module installed in the past, but replaced with a gesture sensor (MMM-GorveGestures)
              Johans @Fozi
              @fozi - Thanks will check if a resistor does the trick - if not I order a gesture sensor
