MMM-Buttons
5 Posts 3 Posters 1.2k Views 3 Watching
    Johans
    Hi, I wanted more pages on my mirror and control them physically with a button.
    installed MMM-Pages / MMM-Page Selector / MMM-Buttons and MMM-Remote Control.
    (First I tried to use MPR-121 but that gives too many errors during installation so I gave up)
    3 buttons connected to Pin 23-34-25 (BCM numbering - RPI-4/4GB)
    Now when I press a button nothing happens. Can’t see what could be wrong.
    this my config:
        module: 'MMM-Buttons',
            buttons: [
                    pin: 23,
                    name: "page changes",
                    longPress: {
                        notification: "PAGE_DECREMENT",
                        payload: {action: ""}
                    shortPress: {
                        notification: "PAGE_INCREMENT",
                    pin: 24,
                    longPress: {
                        notification: "REMOTE_ACTION",
                        payload: {action: "MONITOROFF"}
                    shortPress: {
                        payload: {action: "MONITORON"}
                    pin: 25,
                    longPress: {
                        title: "Power off",
                        message: "Keep pressed for 3 seconds to shut down",
                        imageFA: "power-off",
                        payload: {action: "SHUTDOWN"}
    		 shortPress: {
                        title: "test page up",
                        notification: "PAGE_INCREMENT",   // as test
                        payload: {action: "1"}            // as test
    J F 2 Replies Last reply Nov 21, 2021, 8:11 PM Reply Quote 0
      Johans @Johans
      @johans - they are connected to ground or must the common be connected to the 3.3V pin?
      J 1 Reply Last reply Nov 22, 2021, 9:43 AM Reply Quote 0
        JohnBachini @Johans
        @johans
        I just started doing exactly what you are trying to do. I have managed to get MMM-Buttons working with one button, but not getting reliable results.
        I first tried MMM-Button and was able to confirm button press worked as was getting a message in the logs saying the button was pressed.
        Correct ground and i thought the other needs to be one of the green GPIO, sorry not at home so cant check
        • F Offline
          Fozi Project Sponsor @Johans
          @johans I guess you need to use a pulldown resistor to avoid floating GND.
          Here is a sketch how to use the pull-down-resistor. I had the MMM-Button module installed in the past, but replaced with a gesture sensor (MMM-GorveGestures)
          J 1 Reply Last reply Nov 23, 2021, 4:57 PM Reply Quote 0
            Johans @Fozi
            @fozi - Thanks will check if a resistor does the trick - if not I order a gesture sensor
