    How to send a notification
    35 Posts 3 Posters 11.3k Views 3 Watching
      Alyx @Guest
      @hango Hi Hango!
      Ok so I’ll add that first line to my MMM-SelfieShoot.js (the module that needs to be actioned by another)
      And the second will be inside the MMM-AlexaControl.js? I’ll test it now :)
        Alyx @Alyx
        Did it there but doesn’t seem to appear in Alexa, The other functions such as restart and monitor off/on works but I’m having trouble having this appear/ work.
          sdetweil @Alyx
          @alyx so in alexacontrol, you have to create a notification device
          notifications: [
                  port: 11100,
                  OnOff: false,
                  notification: ["NOTIFICATION", "PAYLOAD"]
          name is the thing Alexa will know
          the tcp/ip port number to use for Alexa to contact this machine
          and the notification info should look familiar
          then u restart MagicMirror
          ( in the MagicMirror startup messages you should see a line listening on ??? where ??? is the port number you used in the notification entry)
          and then Alexa discover devices
          then whatever name is, should be discovered.
          then you invoke it with
          Alexa, turn on xxxx
          where xxxx is the name of your device
          (because alexacontrol creates fake wemo electric outlets)
          note that notifications shown above is a list [], so each {} is a notification device
          and this stuff goes in the alexacontrol module
          config:{}
          section
            Alyx @sdetweil
            @sdetweil I have that set up al;ready but my alexa cant discover it for some reason. If you need you can see it in my config.js file above
              sdetweil @Alyx
              @alyx nice, but you missed one key point
              config:{}
              section
              u have in the general module section not in the module config
                Alyx @sdetweil
                @sdetweil Ah! that worked thanks :) Next issue it doesnt call the module when activated lol
                  sdetweil @Alyx
                  @alyx so, now open the developers window, ctrl-shift-i, and look at the console tab
                  u may be able to see some module report the notification
                  or install my samplemodule as it reports all notifications received
                  https://github.com/sdetweil/SampleModule
                  in the Alexa app u can control devices manually, so that makes testing a lot easier
                    Alyx @sdetweil
                    @sdetweil Hi sam,
                    Great so i can see that the notification isnt being sent via the dev console, it shows up via Alexa app but isnt communicating to the MM. Would you happen to know the cause?
                            module: 'MMM-AlexaControl',
                            position: 'middle_center',
                    	config:{
                                image: true,
                    	    deviceName: "mirror",
                                pm2ProcessName: "mm",
                                vcgencmd: "hide",
                    	    startPort: 11001,
                    	    refresh: true,
                    	    restart: true,
                    	    //stop: true,
                    	    reboot: true,
                    	    shutdown: true,
                    	    monitorToggle: true,
                    	    //cecAddress: "0.0.0.0",
                    	    //usb: false
                    	    pages: 3,
                    	    notifications:[
                            port: 11102,
                            OnOff: false,
                            notification: ["PAGE_INCREMENT", 'payload']
                            port: 11103,
                            OnOff: false,
                            notification: ["PAGE_DECREMENT", 'payload']
                            port: 11104,
                            OnOff: false,
                            notification: ["SELFIE_SHOOT", 'payload']
                      sdetweil @Alyx
                      @alyx not really. if u stop MagicMirror, and then tell Alexa to turn on your notification device, you should get a ‘not responding’ message from alexa
                      that will tell you the two are really connected.
                      Alexa turn on selfie
                        Alyx @sdetweil
                        @sdetweil Yep that makes sense but it isnt popping up below is a quick snapshot of the dev panel
                        MMM-MotionDetector.js:75 MMM-MotionDetector: DiffCamEngine init successful.
                        module.js:195 MMM-AlexaControl is suspended.
                        module.js:195 MMM-NASA is suspended.
                        module.js:195 MMM-ISS-Live is suspended.
                        module.js:195 MMM-MotionDetector is suspended.
                        module.js:195 lifecounter is suspended.
                        module.js:195 compliments is suspended.
                        module.js:195 MMM-chromecast is suspended.
                        MMM-NASA.js:132 Hailing NASA
                        module.js:202 MMM-page-indicator is resumed.
                        module.js:202 MMM-Selfieshot is resumed.
                        module.js:202 MMM-Astro is resumed.
                        module.js:202 MMM-MoonPhase is resumed.
                        module.js:202 clock is resumed.
                        eventtracking-log.services.video.ibm.com/eventtracking.web.player/:1 Failed to load resource: net::ERR_BLOCKED_BY_CLIENT
                        MMM-AlexaControl.js:75 RECEIVE monitor NOTIFICATION=SLEEP_WAKE
                        MMM-AlexaControl.js:75 RECEIVE monitor NOTIFICATION=SLEEP_HIDE
                        MMM-pages.js:97
                        The errors lead to this page
                        400 Bad Request
                        ‘json’ or ‘msgpack’ parameter is required
                          sdetweil @Alyx
                          @alyx said in How to send a notification:
                          one thing at a time
                          you didn’t answer the question about connection
                            Alyx @sdetweil
                            @sdetweil Apoligies, tested there.
                            So I stopped magic mirror/ restarted the pi and it came up with device unresponsive.
                              sdetweil @Alyx
                              @alyx ok, and when MM is running you get the completion sound from alexa, correct?
                                Alyx @sdetweil
                                @sdetweil what do mean by a completion sound? Do you mean the confirmation of ‘ok’ after? If so then yes
                                  sdetweil @Alyx
                                  @alyx when u turn on or off a device, alexa does tada sound… to says it processed your request
                                    Alyx @sdetweil
                                    @sdetweil ah my one says ‘ok’ but id assume its the same
                                      sdetweil @Alyx
                                      @alyx I added your config to my MM and added debugging… and it works as expected
                                      samplemodule reports Selfie_shoot was received
                                      SampleModule received a module notification: SELFIE_SHOOT from sender: MMM-AlexaControl
                                      and because u have is as onOff:false
                                      u get a notification every time (on or off)
                                      I did this using the alexa app…
                                        Alyx @sdetweil
                                        @sdetweil oh… where do you think I went wrong so?
                                          sdetweil @Alyx
                                          @alyx i don’t know… i didn’t change anything in your config…
                                          if you use the alexa app to turn the plug on or off, do you see the notifications?
                                            Alyx @sdetweil
                                            @sdetweil ok I re added the selfie device on the alexa app and it found it fine but its now coming up as unresponsive
